Topic: USB power jack needed (Read 3518 times) previous topic - next topic
larryd
My brain is stuck.
Trying to get away from the jack on the left, what to go to the jack on the right, however, i am looking for a smaller form factor, USB chassis mount version.
Any suggestions?
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
AJITnayak
please elobrate your question properly. You need to mention from where u want to getraid of.
Quote
what is purpose??
AMPS
CrossRoads
This looks to be a little less deep/less intrusive into the enclosure.
http://www.taydaelectronics.com/hardware/dc-power/dc-power-jack-2-1mm-enclosed-frame-with-switch-external.html
[img[http://www.taydaelectronics.com/media/catalog/product/cache/1/image/211x211/9df78eab33525d08d6e5fb8d27136e95/a/-/a-868_1.jpg[/img]
CrossRoads
Or are you after a different version of USB connector?
CrossRoads
Like this, but not nearly so expensive?
http://www.digikey.com/product-search/en?pv69=4&FV=fff40016%2Cfff802e4&k=usb+connector&mnonly=0&newproducts=0&ColumnSort=0&page=1&stock=1&quantity=0&ptm=0&fid=0&pageSize=25
CrossRoads
FTDI also offers some panel mount options
http://www.ftdichip.com/Products/Modules/USBRSxxx.htm
"The DB9-USB range of modules provide a simple and fast method of migrating existing DB9 based connector UART interfaces to USB 2.0. In some cases this can be done without the need to redesign the PCB. In some cases they can reduce system costs by removing an RS232 level shifter from a design. The modules feature a USB2.0 mini-B connector within a module which fits a standard 9-pin DB9 connector footprint."
fungus
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
larryd
#7
Aug 25, 2014, 06:47 pm Last Edit: Aug 25, 2014, 06:55 pm by LarryD Reason: 1
Thanks for the responses.
Quote
please elaborate your question properly. You need to mention from where u want to getraid of.
- I am using the jack on the left as a power connector and want to change to a USB type similar to the one on the right.
- I'll only be using the jack for +5V power.
- However the jack on the right is too large on the back end.
- I was hoping someone had used a chassis mount USB jack they were happy with which has a smaller back end.
- Possibly not more than the dimensions of a PC mount without a shell but with mounting ears.
@Crossroads
funny, the one you mentioned from Tayda was the first one I used then I went to the one on the left which is a bit noisy, trying to find one similar to the one on the right.
I will probably go with this one (has the advantage of duplex) unless there is a better suggestion.
EDIT: just noticed you put 12-24 VDC on the spade lugs and get out 5 volts from the duplex. So this won't work as I am trying to bring 5 volts into the unit through the connector from an external USB 5 volt source.
No technical PMs.
CrossRoads
You are bringing power in? That could work, if you can find a USB-A to USB-A cable. Usually it USB-A on host end to something else: B, mini-B, micro-B
CrossRoads
https://www.google.com/search?hl=en&source=hp&q=usb-a+to+usb-a+cable&gbv=2&oq=usb-a+to+&gs_l=heirloom-hp.1.3.0l6j0i22i30l4.1248.2855.0.6630.9.8.0.0.0.0.390.1123.2-3j1.4.0....0...1ac.1.34.heirloom-hp..5.4.1123.NNedPH4Rtp4
Looks like some sources can be found.
larryd
Quote
oops, I see this unit is 12-24V to 5V converter :smiley-roll-blue:   HERE
Yes I a trying to bring 5 volts into the unit.
I would use a USB to USB cable to do bring the power to the unit.
A or B or a combination of, would work, current is about 400ma.
No technical PMs.
Henry_Best
I got a USB panel mounting B socket to USB line B plug extension lead from China. I believe Adafruit also sell something similar. The socket is about 1.5" (35mm) deep, inside the enclosure. I imagine a mini or micro B socket, if you can get a panel mounting one, would be smaller but might not carry sufficient current.
larryd
Looks like this one from Sparkfun will work.
https://www.sparkfun.com/products/11370
939 bubble displays left there Bob
No technical PMs.
CrossRoads
Still 15 boards left from the first batch, I'm not in a rush to stock up with more just yet.
larryd
The next time I order I'll take 5 more complete kits.
No technical PMs.
