Topic: Problem with sd card (Read 626 times) previous topic - next topic
tonytony72
Hello there. I have a problem with my sd module and my arduino uno. when I connect everything with wire 10cm works well. But when I connect everything with wire 30cm it stops working! there is there a maximum length for the isp? connects I like this  tutorial http://www.instructables.com/id/Playing-Wave-file-using-arduino/
  Then I place Condensator somewhere to solve the problem? thank you
mart256
You'll have to increase cable area size to reduce resistance.
Add decoupling capacitors on Vcc of SD module.
tonytony72
thank you for your reply. I already spend in wire bigger. I try with capacitor (0.1, 0.22, 1, 10, 100UF) between 5v sd module and gnd, but it works once out of 10! (I tested the SD module with the example sketch "cardinfo" of Arduino).
mart256
How big are we talkin' about.
tonytony72
Sorry for my google translate :) .i said  "I used a larger section of wire.
