Topic: Changing PWM value in function of an other pin value (Read 3439 times) previous topic - next topic
doctor_t
Hi guys,
I  m to ask for your help once again.
I made a wattmeter for monitoring of consuption of a brushless motor and everything works fine.
I control the ESC via manual PWM signal
Now i would like to get a value of PWM in funcion of analog read of watt sensor
Example:
Automatic acceleration writing PWM signal on pin 11 (1,2,3,4...10....50...2000...255), at the same moment reading the value of the analog pin for wattmeter and change the value of PWM tryin to make costant the value po analog pin for wattmeter that i chiose
Something like this
Value o range i chiose  : 30-35 watt
Read anog pin 10 watt,  and accelerate till the value will be between 30 and 35 and decelerate in case will go over
Thank you
doctor_t
I use this code to change the value of PWM pin
Code: [Select]
int ESCpin = 11;    // ESC signal wire connected to pin 11 on arduino
int val = 0;        //variable to store PWM value
  for(val = 178; val <= 255; val += 1)
    analogWrite(ESCpin, val);
    delay(8000);
    Serial.println (val);
and this code to find the value of watt
Code: [Select]
  float average = 0;
  for(int i = 0; i < 1000; i++) {
    average = average + (0.0049 * analogRead(A4)/0.185 -13.5447) / 1000;
    delay(1);
  Serial.print("mAmp...");
  Serial.println(average*1000);
  Serial.print("Watt...");
  Serial.println(average*37);
how can i combine them?
PaulS
Quote
First, you define what the combined program should do. After that, it's really a matter of cut and paste.
Of course, in the combined program you are NOT going to be using delay() at all.
doctor_t
thank you PoulS
so the combination should be like this
Code: [Select]
int Throttle= 0;        //variable to store PWM value
  float average = 0;
    delay(1);
      for(Throttle= 0; Throttle<= 255; Throttle+= 1)
    analogWrite(ESCpin, Throttle);
  Serial.print("PWM...");
  Serial.println(Throttle);
but i would like to make an algorithm that will check all the time the value of Watt and adapt the value of throttle to the value of watts
is ti possible?
doctor_t
i thought about something like this but didn't get  any result
Code: [Select]
int Throttle = 1;
int MaxWatt= 10.0;
    if (Energy < MaxWatt)
    for(Throttle > 0; Throttle <= 255; Throttle += 1)
   if (Energy > MaxWatt)
    for(Throttle > 0; Throttle <= 255; Throttle -= 1)
    {analogWrite(ESCpin, Throttle);
JasonK
doctor_t,
From what you are describing, it sounds like you are looking to make a PID controller.
Sudo code that could get you a first pass on what you are wanting:
Code: [Select]
Throttle = start point
loop start
   Check Current Power
   if Current Power < Target Power: increase Throttle
   if Current power > Target Power: decrease Throttle
loop end
Your power sample code snippet is taking an average over a full second, is that needed for your application?
If so, how rapidly do you need your Throttle to adjust to variations in power usage?
doctor_t
doctor_t,
Code: [Select]
loop start
   Check Current Power
loop end
Yes it is exactly what i need!!! :) :) :)
how can i put this code on my sketch?
for sure i would like to make this change as fast as it possible, how fast can it be?
JasonK
To answer how fast it can be, I need to know why your example was averaging 1000 (slightly over one second of time) samples for the power measurement.
JasonK
This is putting your code segments together to fit with my sudo code.  It compiles, but I don't have your hardware setup to test its functionality.  As written it will only update the Throttle at less then 1 time a second because your code to gather the power average takes 1 second in delay time alone.  If you don't need a 1 second average or can use a rolling average (all depends on your application), you could get a more frequently update cycle.
With the current update cycle it will take more then 4.25 minutes to go from no power to full power or full power to no power.
Code: [Select]
int Throttle = 0;       // variable to store PWM value
float GoalWatt = 10.0;   // Set point for Goal wattage
  float average = 0;
    delay(1);
  if(average > GoalWatt) {          // Higher then goal
    if(Throttle > 0) Throttle--;    // decrease Throttle if greater then min
  } else if (average < GoalWatt) {  // Lower then goal
    if(Throttle < 255) Throttle++;  // increase Throttle if less then max
  analogWrite(ESCpin, Throttle);    // Update PIN output
doctor_t
thx very much Jason
i will may be put 150 in the cycle of calculation of the amps to make the cycle faster because 4.25 min are a bit long
by the way i was trying to read about PID and applications
how can i use pid in my case?
JasonK
It looks like there is a PID library here: http://playground.arduino.cc/Code/PIDLibrary
As my experience with PID is limited at this point, it would reference you to that documentation.
doctor_t
i really appreciate your help and it seems to work well but i understood that with pid you can have a smoother or more aggressive answer of PWM
