I have spent many hours trying to solve this problem. Using the GetWeather choreo returns a complete response if no output filters are used. Trouble is, output filters are nice for grabbing the data I am interested in, e.g.: current temp and humidity, forecasted highs and lows, and the weather code for forecasted conditions (to later convert to text, e.g. "Thundershowers").
So, the issue is that when I use multiple output filters (~5), the response is incomplete. Some of the attributes I have requested from the XML file are not returned. I thought this might be an Arduino RAM issue, so I have checked the free memory, but it is unclear to me whether or not it is running out of RAM while sending the Temboo process to Linino. I shortened the XML paths and labels in an effort to use less memory, which has appeared to let me display more output filters (e.g. only ~1 with full XML paths, but ~2-3 with simplified paths). If I switch the order of the .OutputFilters in the source it appears to pick up the first couple and omit the rest. Is there a way to check the Process command that the TembooChoreo class instance is storing at a given time?
Any ideas on how to diagnose this problem further would be much appreciated. I am sure it is not a unique problem... Thanks in advance.
Almost certainly a memory issue... Adding a few more freeMemory() calls to the code, I can see that adding the first two OutputFilters uses about 42 bytes each, and after those two the memory only goes drops by 1 byte for each of the next AddOutputFilter attempts. So is there a bottom limit on RAM for certain methods (e.g. ~330 bytes) or is the TembooChoreo class method of AddOutputFilter not working properly (e.g. bug)?
opkg update
opkg install python-expat
opkg install python-openssl #adds ssl support to python
opkg install distribute #it contains the easy_install command line tool (this can take some time)
easy_install pip #installs pip (this can take some time)
pip install pywapi --allow-external pywapi --allow-unverified pywapi
#!/usr/bin/python
import pywapi
import string
import sys
sys.path.insert(0, '/usr/lib/python2.7/bridge/')
from bridgeclient import BridgeClient as bridgeclient
yahoo_result = pywapi.get_weather_from_yahoo('10001')
print "Yahoo says: It is " + string.lower(yahoo_result['condition']['text']) + " and " + yahoo_result['condition']['temp'] + "C now in New York.\n"
value = bridgeclient()
value.put('t',yahoo_result['condition']['temp'])
print value.get('t')
chmod 755 /mnt/sda1/pyw.py
Test python code at teminal:
root@Arduino:/mnt/sda1# /mnt/sda1/pyw.py
Yahoo says: It is fair and 28C now in New York.
28
Arduino code:
Running process using Process class.
This sketch demonstrate how to run linux processes
using an Arduino Yún.
created 5 Jun 2013
by Cristian Maglie
This example code is in the public domain.
http://arduino.cc/en/Tutorial/Process
#include <Process.h>
Bridge.begin();
// Initialize Serial
// Wait until a Serial Monitor is connected.
while (!Serial);
// Do nothing here.
Process p;
p.begin("/mnt/sda1/pyw.py");
//p.addParameter("--connect-timeout");
p.run();
// Print command output on the Serial.
// A process output can be read with the stream methods
while (p.available() > 0) {
char c = p.read();
Serial.print(c);
// Ensure the last bit of data is sent.
Serial.flush();
char temp[10];
Bridge.get("t", temp, sizeof(temp));
Serial.print(temp);
delay(5000);
While I agree that not using the Temboo wrapper would be preferable (less efficient - perhaps the problem, and limited # of calls per month for free), I was implementing my solution with Temboo in the hopes of it being quick and easy! Turns out it wasn't... but I'm still curious to understand the issues I am having. Not saying I won't be implementing your great suggestion though...!
Thanks for the input. Any explanation on the issue I am having?
While I can't help with your issue, I would like to point out that temboo has a python sdk as well. So you can call temboo services and do all the filtering you wish on the linux side, and have the arduino side happily consume only the interesting data.
[quote author=Federico Fissore link=topic=264822.msg1868172#msg1868172 date=1409814504]
While I can't help with your issue, I would like to point out that temboo has a python sdk as well. So you can call temboo services and do all the filtering you wish on the linux side, and have the arduino side happily consume only the interesting data.[/quote]
Thanks for the input! I agree that moving this to the Linux side is the best solution, and also for any future additions. I wasn't aware that Temboo had a Python SDK... too fixated on "Arduino" ;).
