Topic: Sending byte arrays (Read 11531 times) previous topic - next topic
hardcorehead87
Hi everybody,
I'm trying to send byte arrays from a C# appication to the arduino.
Using very big delays I can get it to work but the point is to constantly send data over
If I remove the delays I'm getting an acceptable result.
I'm sending the data in chuncks of 6 bytes but this will need to change in other situations.
This is the c# code I use to send the data to the arduino;
Code: [Select]
static void Main(string[] args)
    var port = new SerialPort("COM4", 115200);
    port.DataReceived += PortOnDataReceived;
    port.Open();
    while (true)
        port.Write(new byte[] { 0, 0, 0, 0, 0, 126 }, 0, 6);
        port.Write(new byte[] { 4, 0, 0, 0, 0, 190 }, 0, 6);
        port.Write(new byte[] { 8, 0, 0, 0, 0, 222 }, 0, 6);
        port.Write(new byte[] { 12, 0, 0, 0, 0, 238 }, 0, 6);
        port.Write(new byte[] { 16, 0, 0, 0, 0, 246 }, 0, 6);
        Thread.Sleep(1000);
        port.Write(new byte[] { 0, 0, 255, 255, 255, 127 }, 0, 6);
        port.Write(new byte[] { 4, 0, 255, 255, 255, 191 }, 0, 6);
        port.Write(new byte[] { 8, 0, 255, 255, 255, 223 }, 0, 6);
        port.Write(new byte[] { 12, 0, 255, 255, 255, 239 }, 0, 6);
        port.Write(new byte[] { 16, 0, 255, 255, 255, 247 }, 0, 6);
        Thread.Sleep(1000);
private static void PortOnDataReceived(object sender, SerialDataReceivedEventArgs e)
    var port = sender as SerialPort;
    if (port == null) return;
    var readData = port.ReadLine();
    Console.WriteLine("Received: " + readData);
This is the code on the arduino side that just echo's the first byte.
Code: [Select]
byte rawData[6];
while (Serial.available())
Serial.readBytes(rawData, 6);
Serial.println(rawData[0], DEC);
At the moment I'm still trying to get everything to work.
The arduino should use the data elsewhere instead of echoing it.
Eventually the arduino will push the bytes out of it's SPI port.
Or the bytes will be stored in array on the arduino and a timer will push it to the SPI.
Using the delays of 1 second between burts I receive the correct first bytes.
When using anything less then 1 second I don't get the same results.
I've been trying to get things to play nice with each other without succes.
Hopefully somebody will be able to point me in the right direction ;-)
CrossRoads
You're checking that at least 1 is received, then attempting to read 6.
while (Serial.available()>=5) // 6 bytes available?
rawData[0] = Serial.read(); // read & save 6 bytes
rawData[1] = Serial.read();
rawData[2] = Serial.read();
rawData[3] = Serial.read();
rawData[4] = Serial.read();
rawData[5] = Serial.read();
CrossRoads
This is better
if (Serial.available()>=5) // 6 bytes available?
AWOL
Even better would be >= 6.
hardcorehead87
That makes sence.
I thought readBytes would wait for the data to reach 6 bytes unless it reaches the timeout.
I'm still having problems but this would explain why with the long delay it was working.
I think that when I open the serial connection in C# there are some bytes sent over the line.
This would completely mess up my order as I expect chucks of 6 bytes.
With the big delay these initial few bytes are read and then the timeout hits.
The next read I do is into my array again but starting at index 0.
So what I'm getting at is how would I sync up the sending and receiving of these chucks?
If I send 1 2 3 4 5 6 then I don't want to receive 5 6 1 2 3 4..
CrossRoads
Add a 7th sync byte, such as 0xAA or some other combination you are not likely to receive. Or a pair, like 0xAA 0x55
hardcorehead87
When I check if the 7th (and 8th) byte are the correct sync bytes I know that the arduino is in sync or not.
But  if that's not the case, how would I get them to sync up? I have tried using Serial.find() without luck.
Maybe I was doing something wrong but what would be the adviced way to do this?
AWOL
Quote
Keep reading (and dumping the result) until they are in sync.
Robin2
If you want to send a lot of data in fixed length chunks I suggest you get the Arduino to "request" the chunks - perhaps by sending an 'M' (for more :) ). That way synchonization is ensured.
Sending small chunks of data will not permit a large overall throughput. You could probably send chunks of 36 bytes as quickly as chunks of 6 bytes.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
CrossRoads
Here's one way:
Code: [Select]
// assume one sync byte
if (Serial.available()>0){  //
  if (Serial.read() == syncbyte){ // got a sync byte?
  while (Serial.available() <5){
  // hang out for 6 bytes
// got 6, now read them
   array[0] = Serial.read();
   array[1] = Serial.read();
   array[2] = Serial.read();
   array[3] = Serial.read();
   array[4] = Serial.read();
   array[5] = Serial.read();
AWOL
Code: [Select]
{ polite cough }
CrossRoads
What, I'm making it up on fly, trying  to post  before I get bumped into the "Warming:someone else posted" window, which locks up IE8 on me, and then I have to close down IE altogether and start all over, and if lucky I'll have remembered to copy so I can paste & post quick. If you see an error, just say so! I'm open for corrections. Modify locks me up too. Major PITA!
Robin2
Firefox ???
...R
PaulS
Quote
So.
The comment does not agree with the first line of code in AWOL's snippet. The following code expects the comment to be right.
