Topic: L298 different output voltages (Read 4198 times) previous topic - next topic
mateoar
Hi, Im currently working on a project that involves the use of two 6V dc motors controlled by a L298 driver. The problem im facing is that my motors are running at different speeds which is apparently caused by different output voltages for both motors which i measured. I atached the circuit im using.
I also measured the in1, in2, in3, in4, enA, inB voltages and they seem to be fine.
Any help would be really apreciated.
raschemmel
Arduino UNOs, Pro-Minis, ATMega328, ATtiny85, LCDs, MCP4162, keypads,<br />DS18B20s,74c922,nRF24L01, RS232, SD card, RC fixed wing, quadcopter
mateoar
post your code. Don't ask why.
If you insist, the motor control is on the bottom, btw, i already measured the pwm outputs and they are ok.
Quote
#include<Wire.h>
const int GyroA=0x68;
const byte pin_motor1_dir = 2;
const byte pin_motor1_en = 3;
const byte pin_motor2_dir = 4;
const byte pin_motor2_en = 5;
const byte pin_buzzer = 6;
const byte pin_echo = 7;
const byte pin_trigger = 8;
const byte pin_led1 = 9;
const byte pin_led2 = 10;
const byte pin_btn = 12;
const byte pin_reflex_1 = A0;
const byte pin_reflex_2 = A1;
const byte pin_reflex_3 = A2;
const byte pin_reflex_4 = A3;
byte motor1_speed = 0;
int data_ultrasonido;
int data_reflex[4];
int buttonState;
int lastButtonState = LOW;
long debounceDelay = 50;
long lastDebounceTime = 0;
float data_imu[7];
byte z = 0;
  pinMode(pin_motor1_dir,OUTPUT);
  pinMode(pin_motor1_en,OUTPUT);
  pinMode(pin_motor2_dir,OUTPUT);
  pinMode(pin_motor2_en,OUTPUT);
  pinMode(pin_buzzer,OUTPUT);
  pinMode(pin_trigger,OUTPUT);
  pinMode(pin_echo,INPUT);
  pinMode(pin_led1,OUTPUT);
  pinMode(pin_led2,OUTPUT);
  pinMode(pin_btn,INPUT);
  pinMode(pin_reflex_1,INPUT);
  pinMode(pin_reflex_2,INPUT);
  pinMode(pin_reflex_3,INPUT);
  pinMode(pin_reflex_4,INPUT);
  Wire.begin();
  Wire.beginTransmission(GyroA);
  Wire.write(0x6B);
  Wire.write(0); //Wake up
  Wire.endTransmission(true);
  //digitalWrite(pin_buzzer,HIGH);
  //digitalWrite(pin_led1,HIGH);
  //digitalWrite(pin_led2,HIGH);
  //delay(350);
  //debug_imu();
  //debug_reflex();
  //debug_ultrasonido();
  debounce();
void debug_reflex()
  sensar_reflex();
  for(int i = 0;i<4;i++)
    Serial.print("Reflex ");
    Serial.print(i);
    Serial.print(": ");
    Serial.println(data_reflex);
void debug_ultrasonido()
  sensar_ultrasonido();
  Serial.print("Distancia: ");
  Serial.println(data_ultrasonido);
void debug_imu()
  sensar_imu();
  Serial.print("AcX: ");
  Serial.println(data_imu[2]);
  Serial.print("AcY: ");
  Serial.println(data_imu[1]);
  Serial.print("AcZ: ");
  Serial.println(data_imu[0]);
  Serial.print("GyX: ");
  Serial.println(data_imu[3]);
  Serial.print("GyY: ");
  Serial.println(data_imu[4]);
  Serial.print("GyZ: ");
  Serial.println(data_imu[5]);
  Serial.print("Temp: ");
  Serial.println(data_imu[6]);
void sensar_ultrasonido()
  long duration;
  digitalWrite(pin_trigger, LOW);
  delayMicroseconds(2);
  digitalWrite(pin_trigger, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(pin_echo, HIGH,11765);
  if(duration!=0)
    data_ultrasonido = duration/59;
    data_ultrasonido = -1;
void sensar_reflex()
  data_reflex[0] = analogRead(pin_reflex_1);
  data_reflex[1] = analogRead(pin_reflex_2);
  data_reflex[2] = analogRead(pin_reflex_3);
  data_reflex[3] = analogRead(pin_reflex_4);
void sensar_imu()
  Wire.write(0x3B);
  Wire.endTransmission(false);
  Wire.requestFrom(GyroA,14,true);
  data_imu[0] = Wire.read()*256+Wire.read();
  data_imu[1]=Wire.read()*256+Wire.read();
  data_imu[2]=Wire.read()*256+Wire.read();
  data_imu[6]=(Wire.read()*256+Wire.read())/340.00+36.53;
  data_imu[3]=Wire.read()*256+Wire.read();
  data_imu[4]=Wire.read()*256+Wire.read();
  data_imu[5]=Wire.read()*256+Wire.read();
  data_imu[3]/=131;
  data_imu[4]/=131;
  data_imu[5]/=131;
  data_imu[0]/=16384;
  data_imu[1]/=16384;
  data_imu[2]/=16384;
void debounce()
  int state = digitalRead(pin_btn);
  if(state!=lastButtonState)
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay)
    if (state != buttonState)
      buttonState = state;
      if (buttonState == HIGH)
        //tone(pin_buzzer,1760,50);
        if(motor1_speed < 255)
          motor1_speed+=51;
          motor1_speed = 0;
        analogWrite(pin_motor1_en,motor1_speed);
        analogWrite(pin_motor2_en,motor1_speed);
  lastButtonState = state;
raschemmel
Quote
click the MODIFY button in the upper right of the post window.
Highlight all you code.
click the "#" CODE TAGS button on the toolbar above just to the left of the QUOTE button.
click SAVE (at the bottom).
When you post code on the forum, please make a habit of using the code tags "#" button.
Quote
http://arduino.cc/en/Reference/analogWrite
WHAT DOES THIS SAY ABOUT YOUR MOTOR-2 PWM PIN   ?
The frequency of the PWM signal on most pins is approximately 490 Hz. On the Uno and similar boards, pins 5 and 6 have a frequency of approximately 980 Hz.
Now do you see why I asked you to post your code ?
mateoar
Quote
Quote
Thanks for the help, ill check if that solves it.
raschemmel
You know what you need to do to correct it I assume ?
mateoar
I guess changing the pins so both pwm outputs operate at the same frequency?
raschemmel
raschemmel
That was easy wasn't it ?
Aren't you glad it wasn't a hardware problem ?
Now you see why I asked you to post your code ?
mateoar
Haha yea, i honestly thought the l298 was broken, but as usual it was just one of those little details you completely ignore
raschemmel
Can you post the link of your particular L298 module ? I assume it is a premade module on a pcb and not a breadboarded chip , correct ?
mateoar
Yeap, here's the sparkfun link and datasheet:
https://www.sparkfun.com/products/9479
https://www.sparkfun.com/datasheets/Robotics/L298_H_Bridge.pdf
raschemmel
You don't have a heatsink or PCB ?
mateoar
Im currently testing it in a breadboard, but i do have a heatsink attached to it
