I am trying to make a steady hand game (the kind with a loop and a wiggly path to follow). The path is connected to a pin configured as INPUT with INPUT_PULLUP set to enable its internal pullup resistor, the loop is GND. Touching the loop against the path triggers a serial FAIL message. I also have a start and a finish section which are also INPUT pins with pullups enabled. I am controlling a 12v car horn which is triggered on fail via a transistor but since connecting my 12v power supply the noise levels seem to have gone up and the FAIL and COMPLETE pins get triggered arbitrarily as if they were floating.
Could it be that the internal pullups are now not enough? The copper path is actually copper pipe, over 4 meters of it, so it is one big ol' conductor.
roowilliams:
It will only take a few seconds to add a 1K pullup to it and find out...
(or whatever other resistor you have handy....so long as it's over 150 Ohms and less than 30,000)
I agree, the reason why I asked is because the whole thing is soldered onto one of those proto strip boards and they're horrible to work with; shorts etc.
I just wondered if it might be a potential case before I go meddling.
groundfungus:
Just a thought, but is the ring insulted where the person is touching it? It may help to isolate the person (big ol' antenna) from the ring.
The way I read it, the thing the person is holding is connected to GND.
roowilliams:
So? The resistor can go on the end of a wire which is connected to +5V. No need to modify the PCB, just wrap one leg around your "path" and try it.
