Topic: paar TM1637 sketchen die ik vond op het net (Read 1 time) previous topic - next topic
vanschagen
paar sketchen van het net.
Code: [Select]
//  Author:Frankie.Chu
//  Date:9 April,2012
//  This library is free software; you can redistribute it and/or
//  modify it under the terms of the GNU Lesser General Public
//  License as published by the Free Software Foundation; either
//  version 2.1 of the License, or (at your option) any later version.
//  This library is distributed in the hope that it will be useful,
//  but WITHOUT ANY WARRANTY; without even the implied warranty of
//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
//  Lesser General Public License for more details.
//  You should have received a copy of the GNU Lesser General Public
//  License along with this library; if not, write to the Free Software
//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
//  Modified record:
#include <TimerOne.h>
#include "TM1637.h"
#define ON 1
#define OFF 0
int8_t TimeDisp[] = {0x00,0x00,0x00,0x00};
unsigned char ClockPoint = 1;
unsigned char Update;
unsigned char halfsecond = 0;
unsigned char second;
unsigned char minute = 6;
unsigned char hour = 21;
#define CLK 2//pins definitions for TM1637 and can be changed to other ports
#define DIO 3
TM1637 tm1637(CLK,DIO);
  tm1637.set();
  tm1637.init();
  Timer1.initialize(500000);//timing for 500ms
  Timer1.attachInterrupt(TimingISR);//declare the interrupt serve routine:TimingISR
  if(Update == ON)
    TimeUpdate();
    tm1637.display(TimeDisp);
void TimingISR()
  halfsecond ++;
  Update = ON;
  if(halfsecond == 2){
    second ++;
    if(second == 60)
      minute ++;
      if(minute == 60)
        hour ++;
        if(hour == 24)hour = 0;
        minute = 0;
      second = 0;
    halfsecond = 0;
// Serial.println(second);
  ClockPoint = (~ClockPoint) & 0x01;
void TimeUpdate(void)
  if(ClockPoint)tm1637.point(POINT_ON);
  else tm1637.point(POINT_OFF);
  TimeDisp[0] = hour / 10;
  TimeDisp[1] = hour % 10;
  TimeDisp[2] = minute / 10;
  TimeDisp[3] = minute % 10;
  Update = OFF;
Code: [Select]
// Author: RSP @ Embedded System Lab (ESL), KMUTNB, Thailand
// Date: 29-Apr-2014
// Target Board: Arduino Uno (ATmega328P, 5V, 16MHz)
// Arduino IDE: version 1.0.5
// Description:
//   This Arduino Sketch shows how to interface the Arduino Uno
//   to a four-digit 7-segment display that utilizes the TM1637
//   LED driver chip.
#define CLK_PIN   (2)
#define DIO_PIN   (3)
#define bit_delay()   asm("nop\n nop\n nop\n nop\n")
#define TM1637_CMD1  (0x40)
#define TM1637_CMD2  (0xC0)
#define TM1637_CMD3  (0x80)
const uint8_t SEVEN_SEG_DIGITS[] = {
//  gfedcba
  0b00111111, // 0
  0b00000110, // 1
  0b01011011, // 2
  0b01001111, // 3
  0b01100110, // 4
  0b01101101, // 5
  0b01111101, // 6
  0b00000111, // 7
  0b01111111, // 8
  0b01101111, // 9
void tm1637_init() {
  pinMode( CLK_PIN, OUTPUT );
  pinMode( DIO_PIN, OUTPUT );
  digitalWrite( CLK_PIN, HIGH );
  digitalWrite( DIO_PIN, HIGH );
void tm1637_start_bit() {
  digitalWrite( DIO_PIN, LOW );  bit_delay();
  digitalWrite( CLK_PIN, LOW );  bit_delay();
void tm1637_stop_bit() {
  digitalWrite( CLK_PIN, HIGH ); bit_delay();
  digitalWrite( DIO_PIN, HIGH ); bit_delay();
int tm1637_send_byte( uint8_t data ) {
  uint8_t ack;
  for( uint8_t i = 0; i < 8; i++ ) { // Send 8-bit data, LSB first
    digitalWrite( DIO_PIN, ( data & 0x01 ) ? HIGH : 0 );
    data >>= 1; // shift bit to the right
  pinMode( DIO_PIN, INPUT );     // make DIO pin floating (input)
  digitalWrite( DIO_PIN, HIGH ); // enable pull-up
  ack = digitalRead( DIO_PIN );  // read ACK bit
  return (ack==0);
boolean showDigits( uint8_t digits[],
       boolean colon=false, uint8_t brightness=7 )
  // send the first command
  tm1637_start_bit();
  tm1637_send_byte( TM1637_CMD1 );
  tm1637_stop_bit();
  // send the second command
  tm1637_start_bit();
  tm1637_send_byte( TM1637_CMD2 );
  for ( uint8_t i=0, value; i < 4; i++ ) {
    value = SEVEN_SEG_DIGITS[ digits[i] ];
    if ( (i == 1) && colon ) {
      value |= 0x80; // turn on the colon on the display
    tm1637_send_byte( value );
  tm1637_stop_bit();
  // send the third command
  tm1637_start_bit();
  tm1637_send_byte( TM1637_CMD3 | (brightness & 0x07) | 0x08 );
  tm1637_stop_bit();
uint32_t ts;
  tm1637_init();
  ts = millis();
// show time (hour and minute)
void showTime( uint8_t hh, uint8_t mm, boolean colon=false ) {
  static uint8_t data[4];
  data[0] = hh/10;
  data[1] = hh%10;
  data[2] = mm/10;
  data[3] = mm%10;
  showDigits( data, colon );
void testDigitalWatch() {
  static boolean colon=false;
  // Start at 12:00:00(hours, minutes and seconds)
  static uint8_t hh=12, mm=0, ss=0;
  if ( millis() - ts >= 500 ) { // check every 500 msec
    showTime( hh, mm, colon );
    colon = !colon;
    if (colon) {
      ss = (ss+1)%60;
      if (ss == 0) {
        mm = (mm+1)%60;
        if (mm == 0) {
          hh = (hh+1)%24;
    ts += 500;
void testTimer() {
  static uint16_t count = 0, temp;
  if ( millis() - ts >= 100 ) { // check every 100 msec
    temp  = count;
    count = (count+1) % 10000;
    for (uint8_t i=0; i < 4; i++) {
      data[3-i] = temp%10;
      temp /= 10;
    showDigits( data );
    ts += 100;
  testTimer();
  //testDigitalWatch();
