Topic: Project 9 - problems with motor (Read 2491 times) previous topic - next topic
mateuyabar
I'm trying to make project 9.
When I press the switch the motor starts.
When I unpress it, the motors continues running decreasing its speed really slowly. Even if I stop the motor (with a finger), it will start again.
If I unplug the battery the motor stops directly.
So, it seas that the mosfet, when I send LOW to gate, the connectivity between the drain and the soruce, instead of stopping, is decreasing gradually.
Any thoughts on what may be happening?
Thanks.
Hackscribble
Hi mateuyabar
What type of MOSFET are you using?  What is its part number?
Regards
Ray
Hackscribble.  Writing about making things
hackscribble@outlook.com
mateuyabar
I bought the Arduino Kit,
The mosfet is: IRF520 http://arduino.cc/documents/datasheets/MOS-irf520npbf.pdf
spikula
Hi, I am having the exact same problem, mateuyabar.  Did you ever get this to work right, or at least figure out why it is doing what it is doing?
