Topic: Keypad Issues (Read 1 time) previous topic - next topic
Markham
Hello,
I've finally got it worked out! First of all I was writing code_read[a]=0 to put the whole string to zero instead of applying
Code: [Select]
memset (code_read,0,10); but that wasn't what was causing the program to not work properly . I had written a++ in a function 2 lines lower than it should have been and it was causing  the string to increment before it was intended. After using the serial monitor tool I was able to find out what was going on.
In any case thanks alot for your help in this matter!!
PaulS
Quote
First of all I was writing code_read[a]=0 to put the whole string to zero instead of applying ... but that wasn't what was causing the program to not work properly
Of course not. Functions that expect a NULL terminated string stop at the first NULL (the first stop sign). They do not need a bunch of stop signs to know to stop.
Quote
That would do it.
Quote
Been suggesting that for a while. Glad it finally sunk in.
Feels good to find and fix a problem yourself, doesn't it?
