Topic: Seek N’ Sneak: your robust robotic pet. (Read 2867 times) previous topic - next topic
EL-Costello
Seek N' Sneak is an Arduino powered self-controlled robot which is able to run around, find objects, grab them, relocate them and do many other useful and funny things.
We will start the IndieGoGo campaign on Monday, Sept 22 at 1200 GMT.
http://www.youtube.com/watch?v=DAx6WKgas_I
Visit
www.seeknsneak.com
and
www.facebook.com/SeekNSneak
for more information.
EL-Costello
-Motivation.
Why did we develop this robot? There is a very short answer: kids! They need 10 to 30 minutes (depending on their temper) to scatter literally all the toys they have over their rooms, so initially we were looking for some way to automate a tedious process of daily toys collection. We solved this problem, but we realized that there are many other cool applications for this robot. We found that our robot can be smart, fast, strong, fearless and funny, just like a badger, and we named it Seek N' Sneak.
http://www.youtube.com/watch?v=gh2T_w8otec
EL-Costello
Seek N' Sneak robot at a glance.
The two driving wheels of this robot are powered by independently controlled motors and equipped with 128-steps-per-revolution encoders allowing for precise control of the angular position of the wheel, as well as its velocity and acceleration.
http://www.youtube.com/watch?v=XEY1RXZ6FGU
An independent 2D orientation of the rover is provided by two side mounted IR proximity meters. Objects are detected by the third centered IR proximity meter. The three IR sensors can be replaced by one PING)))™ Ultrasonic Distance Sensor.
http://www.youtube.com/watch?v=6MuAQy3KAyk
The arm is run by 3 super-strong servo-motors, so it is fast and powerful enough to push up about 3 pounds, or even lift the robot itself, or throw objects.
http://www.youtube.com/watch?v=sh7i1j7Uxlg
Seek N' Sneak is an Arduino Mega 2560 powered robot. The robot software is completely open sourced, so you can either use the original software which has already been developed for you, or you can modify it as you please to meet your demands. You can then use commands like LOOK FOR AN OBJECT, GRAB or THROW instead of writing low-level code to control the sensors, motors and servos directly or develop your own way of thinking for the robot from scratch using the Arduino integrated development environment.
Though Seek N' Sneak was designed as a fully autonomous, upgradable robot. There is plenty of space inside the body of the robot to extend Arduino board with extra sensors or with Wi-Fi or Bluetooth shields to establish communication with a computer or remote control.
Seek N' Sneak's body and arm parts, depending on the kit you choose, are made of either 5mm laser cut black acrylic glass, 3mm laser cut galvanized aluminum or 2mm milled carbon-fiber composite.
8.4 - 9.6V accumulator (not included*) is used as the only power supply.
-What can Seek N' Sneak robot do?
The most impressive thing is that the robot runs as a fully independent  unit:
• it can find and collect objects on the ground,
• chase and attack other robots
• you can make it organize your living space, placing things back in place whenever they are found where they should not be.
You are only limited by your imagination.
Can you use it?
YES, if you have a very basic knowledge in electronics and programming OR if you are able to accurately follow simple instructions. Seek N' Sneak robot is provided as a kit, so you will need some basic tools including wrenches, screwdrivers, diagonal cutter and soldering set. For young technicians supervision is recommended.
The Seek N' Sneak robot can also be a great gift to get your child interested in robotics. Since the databank of free software will be continuously replenished, people with no programming background can also enjoy the fun of robotics.
No matter if you are an experienced programmer, a robotics fan, or a school teacher trying to interest kids in robotics, the Seek N' Sneak is a great way to learn about mechanics, electronics and programming… All in one!
What does SN'S kit include?
The standard Seek N' Sneak kit contains everything* you need to complete the assembly of the robot including
• laser cut body parts along with
• DC motors with encoders,
• dual motor shieldand wheels,
• arm powering servos,
• IR proximity meters,
• an Arduino Mega 2560** or analog control board,
• screws, nuts and spacers, flanged bearing wheels, wires, connectors, breadboard and other minor parts.[/li][/list]
You will be provided with a full step-by-step tutorial explaining how to assemble your Seek N' Sneak robot. Moreover, you will get the intermediate programming sketches that will help you to properly connect and test all the electronic parts one by one.
http://www.youtube.com/watch?v=e7IfpUSiBdI
* Accumulator is not included; see recommended type of accumulator
http://www.amazon.com/Tenergy-2000mAh-Capacity-Battery-Security/dp/B001BA292A/ref=sr_1_1?ie=UTF8&qid=1410170727&sr=8-1&keywords=9.6+battery+pack
or
http://www.pololu.com/product/2226.
** You can replace it with Arduino UNO as it has exactly as many pins as needed. However we strongly recommend Mega 2560 board because it gives you a lot of room for experiments with additional drives, sensors, screens, pushbuttons or LEDs.
EL-Costello
Seek N' Sneak evolution.
We made a lot of modifications, but most of them were made on paper. In the end there was only one predecessor which successfully solved the problems of self-orientation and finding objects. It looked like this:
http://www.youtube.com/watch?v=bapBclACKaY
EL-Costello
Why does the project need your support?
We want to share the design and our experience building the Seek N' Sneak robot with developers all around the world. So after the INDIEGOGO campaign, the Seek N' Sneak robot in its entirety will be released to the public!
Our aim is a community of robotic fans - we count on your participation as a developer. With your help we will be able to establish a network of all Seek N' Sneak robot developers. You will be able to share and borrow ready-to-use code and find support from other robot builders. At the same time we will be continuously working on new features for existing robot and develop new robots to meet your expectations. Just imagine how much we can do, working together on this project.
The next version of the robot will be equipped with accelerometers for precise positioning of the robot. We will also add a CMOS-camera and BlueTooth or WiFi shields for interactive outboard optical object recognition. We are also considering using the Raspberry Pi portable computer in the next generation of the Seek N' Sneak robot.
However, all of this can only be done with your support…
With your funding we can make the Seek N' Sneak robot even better, more affordable and easily accessible to everyone.
EL-Costello
We created an amazing robot and we want to share the design and our experience building the Seek N' Sneak robot with developers all around the world.
However, it can only be done with your support…
Help us! http://igg.me/at/SeekNSneak
How else can You help?
- Share the news about our campaign on social media (Instagram, Facebook, Google+, Twitter, etc.)
- Share about our campaign via email
- Write the link to our campaign and hand it out. The shortened link is http://igg.me/at/SeekNSneak
- Our website is http://seeknsneak.com/ We have an easy-to-share photos and videos there. Feel free to copy and share them.
zoomkat
This really should go back in the exhibition area. As an arduino user I found nothing of value (plans, code, construction info, etc.) on your site (just info on sending $$$). It appears that this posting is nothing more than just a sales hustle for your venture.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
EL-Costello
