Topic: How to send the state of an LED via SMS (Read 21119 times) previous topic - next topic
dannable
Stick them in a char array (Not a String!) and then do a string compare?
Just in case: http://www.cplusplus.com/reference/cstring/strcmp/
Beginners guide to using the Seeedstudio SIM900 GPRS/GSM Shield
thandana
Hi Dan,
I have built some security into my code. I have not used the char array as mentioned previuosly, but I will. When i run this code even if i send the correct code to the arduino i.e ?20!4#a1 it keeps executing the sendSMSFAULT function repeatedly. Also why is it runnign that part of the code because the correct code was sent to the arduino to turn on light. Please have a look at the attached code for please:
The sendSMSFAULT should only run if the incoming character does not begin with ? mark
Code: [Select]
#include <SoftwareSerial.h>
SoftwareSerial SIM900(2, 3); // RX, TX
char incoming_char=0; //Will hold the incoming character from the Serial Port.If the command becomes bigger than 8 bits, try use char16_t
// Pin 8 has an LED connected on most Arduino boards.
int led = 8;
int led13 = 13;
int led_status = 0;     // variable to store the led status
/*-----( Declare Constants )-----*/
#define RELAY_ON 0
#define RELAY_OFF 1
/*-----( Declare variables )-----*/
#define Relay_1  8  // Arduino Digital I/O pin number
#define Relay_2  7
#define Relay_3  6
#define Relay_4  5
  // the setup routine runs once when you press reset:
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
  pinMode(led13, OUTPUT);
  pinMode(Relay_1, OUTPUT);
  pinMode(Relay_2, OUTPUT);
  pinMode(Relay_3, OUTPUT);
  pinMode(Relay_4, OUTPUT);
  digitalWrite(led, LOW);  // Set led to LOW
  digitalWrite(led13, LOW);  // Set led to LOW
  //-------( Initialize Pins so relays are inactive at reset)----
  digitalWrite(Relay_1, RELAY_OFF);
  digitalWrite(Relay_2, RELAY_OFF);
  digitalWrite(Relay_3, RELAY_OFF);
  digitalWrite(Relay_4, RELAY_OFF);
  Serial.begin(19200); // set the baud rate
  SIM900.begin(19200); // for GSM shield
  delay(20000);  // give time to log on to network.
  Serial.println("setup Section");
  SIM900.print("AT+CMGF=1\r");  // set SMS mode to text
  delay(100);
  SIM900.println("AT+CNMI=2,2,0,0,0\r");
  SIM900.print("AT+CLIP=1\r"); // turn on caller ID notification
  // blurt out contents of new SMS upon receipt to the GSM shield's serial out
  delay(100);
  //digitalWrite(led, LOW);  // Set led to LOW
  //digitalWrite(led13, LOW);  // Set led to LOW
// Serial.println("AT+CMGD=1,4");  //Delete all SMS in box
void sendSMS(byte led_status){               //SEND SMS
  SIM900.print("AT+CMGF=1\r");                     // AT command to send SMS message
  SIM900.println("AT + CMGS = \"+277XXXXXXXX\"");  // recipient's mobile number, in international format
if (led_status==0)
      SIM900.println( " LIGHT STATUS: OFF");
      SIM900.println( " LIGHT STATUS: ON");
  SIM900.println((char)26);                        // End AT command with a ^Z, ASCII code 26
  SIM900.println();
  delay(5000);     // give module time to send SMS
void sendSMSFAULT(){               //SEND SMS
  SIM900.println("AT + CMGS = \"+277XXXXXXX\"");  // recipient's mobile number, in international format
  SIM900.println( " SORRY! YOU ARE NOT ALLOWED TO USE THE SYSTEM");
  SIM900.println();
// the loop routine runs over and over again forever:
if(SIM900.available() >0)
incoming_char=SIM900.read();
if (incoming_char!='?')
   delay(10);
   Serial.println("Discarded SMS");
   sendSMSFAULT();
  if (incoming_char=='?')
   delay(10);
if (incoming_char=='2')
   delay(10);
if (incoming_char=='0')
   delay(10);
if (incoming_char=='!')
   delay(10);
if (incoming_char=='4')
   delay(10);
if (incoming_char=='#')
   delay(10);
if (incoming_char=='a')
   delay(10);
   digitalWrite(Relay_1, LOW);// set the Relay OFF
   delay(1000);              // wait for a second
else if (incoming_char=='1')
   digitalWrite(led, HIGH);
   digitalWrite(Relay_1, HIGH);// set the Relay ON
else if (incoming_char=='S')
   digitalRead(led);
   led_status=digitalRead(led);
   Serial.print(led_status);  // prints status on serial terminal
   sendSMS(led_status);
delay(10);
I also included this in the code as you previously advised in the void Setup, however even after the changes, when i upload the code onto the arduino, my LED turns ON and stays ON....:-(
Code: [Select]
thandana
Hi Dan,
May you please give me an example how I can used the char array to analyze the incoming char and to do a compare as mentioned earlier.
"Stick them in a char array (Not a String!) and then do a string compare?"
dannable
In reply #3 I said:
Quote
Auto-format feature is your friend. Use it - a lot.
If you try it on the code you posted on 4th October you should be able to see where the problem arises. You have all your conditional testing in the section beginning:
Code: [Select]
thandana
Hi Dan,
I have modified my void loop, however now my code keeps executing the sendSMSFAULT() function ALWAYS, even without sending commands to my modem. Please have a look at where I'm going wrong:
Code: [Select]
int led = 8;
int led13 = 13;
#define RELAY_ON 0
#define RELAY_OFF 1
#define Relay_2  7
#define Relay_3  6
#define Relay_4  5
  delay(100);
  delay(100);
  SIM900.println("AT + CMGS = \"+27725XXXX\"");  // recipient's mobile number, in international format
  if (led_status==0)
  SIM900.println();
  SIM900.println("AT + CMGS = \"+27XXXXX\"");  // recipient's mobile number, in international format
  SIM900.println();
      delay(10);
      Serial.println("Discard SMS");
      sendSMSFAULT();
        delay(10);
          delay(10);
            delay(10);
              delay(10);
                delay(10);
                  delay(10);
                    delay(10);
                      delay(10);
                        digitalRead(led);
                      delay(10);
dannable
Rather than checking each incoming character individually why not just load them into a character array?
In the following example the sketch waits until 5 characters have been received from Serial Terminal and then compares them to 'secret_code'.
Code: [Select]
char buffer[6]; // Five char plus null terminator
char secret_code[] = "12345";
char incoming_char;
byte buffer_pos=0;
  if (Serial.available()>0)
    incoming_char=Serial.read();
    buffer[buffer_pos]=incoming_char;
    buffer_pos++;
    if (buffer_pos==5) // Already incremented
      //Print it out
      buffer[buffer_pos]='\0';
      Serial.write(buffer);
      if (strcmp(buffer,secret_code)==0)
        Serial.println("It's a match!");
      buffer_pos=0;
thandana
Hi Dan,
I have modified my code to include storing incomming data from serial into a char_array as below. I will test it a bit later as I'm still at work. Please have a look at the below code and comment:
Code: [Select]
int led = 8;
int led13 = 13;
char buffer[9]; // eight char plus null terminator
char secret_code[] = "?20!4#a0";
char secret_code1[] = "?20!4#a1";
char secret_code2[] = "?20!4#aS";
byte buffer_pos=0;
#define RELAY_ON 0
#define RELAY_OFF 1
#define Relay_2  7
#define Relay_3  6
#define Relay_4  5
  delay(100);
  delay(100);
  SIM900.println("AT + CMGS = \"+XXXXXXXXX\"");  // recipient's mobile number, in international format
  if (led_status==0)
  SIM900.println();
  SIM900.println("AT + CMGS = \"+2XXXXXXXXXXXXXX\"");  // recipient's mobile number, in international format
  SIM900.println();
    buffer_pos++;
    if (buffer_pos==8) // Already incremented
      //Print it out
      buffer_pos=0;
      if (strcmp(buffer,secret_code1)==0)
      buffer_pos=0;
      if (strcmp(buffer,secret_code2)==0)
        digitalRead(led);
        sendSMS(led_status);           // wait for a second
      buffer_pos=0;
thandana
Hi Dan,
I used the above code and the code is not turning ON/OFF the LED. I have sent the correct codes but with no effect. Any ideas what I'm doing wrong?
Also, in arduino is there a way of seeing where the code is failing, i.e. DEBUG mode or something?
Code: [Select]
int led = 8;
int led13 = 13;
byte buffer_pos=0;
#define RELAY_ON 0
#define RELAY_OFF 1
#define Relay_2  7
#define Relay_3  6
#define Relay_4  5
  delay(100);
  delay(100);
  SIM900.println("AT + CMGS = \"+XXXXXXXXXXXXXXX\"");  // recipient's mobile number, in international format
  if (led_status==0)
  SIM900.println();
  SIM900.println("AT + CMGS = \"XXXXXXXXXXXX\"");  // recipient's mobile number, in international format
  SIM900.println();
  if (SIM900.available()>0)
    buffer_pos++;
      //Print it out
      SIM900.write(buffer);
      SIM900.println();
      buffer_pos=0;
      buffer_pos=0;
        digitalRead(led);
        SIM900.print(led_status);  // prints status on serial terminal
      buffer_pos=0;
dannable
The usual way to debug a program is to use Serial.println() to print out the value of variables of interest, and to indicate that program execution has reached to a particular point.
Code: [Select]
Serial.println("Got to stage 7");
If you are going to put them in a piece of code that executes rapidly then temporarily add a delay(1000); just to slow it down so you can see what is happening. Don't forget to take it out afterwards!
dannable
Critique? Of you most recent code:
Code: [Select]
Being a little ambitious aren't we? We haven't even got the code working. Don't add stuff that you don't need. Just for curiosity, what are you expecting this command to do?
Code: [Select]
      SIM900.println();
Why are you sending it to the SIM900? It would be of more use sending it to the serial monitor to tell us what is going on.
Code: [Select]
        digitalRead(led);
Read the pin, but don't do anything with it? And then read it again but save the result, which is what you should be doing to start with.
Code: [Select]
Again, perhaps it would be better to send the led_status to Serial, not the SIM900. It doesn't care. And with both these lines, the comments don't match what is really happening. It may not matter right now, but you'll wonder what you were trying to do when you read them in three months time. Personally I comment a block of code rather than individual lines unless it really warrants it.
However, I've done a hatchet job on your code, partially because the modem I have to hand uses pins 7 & 8. I've put some debug comments in so you can see what is happening. It does work, but it only works once! I'll leave it to you to figure it out why.
Code: [Select]
SoftwareSerial SIM900(7,8); // RX, TX
int led13 = 13;
char secret_code[] = "20!4#a0";
byte buffer_pos=0;
  SIM900.print("ATE0\r");
  delay(100);
  delay(100);
  Serial.println("Finished Setup Section");
void sendSMS(byte led_status)               //SEND SMS (Isn't the clue in the function name?)
  SIM900.println("AT + CMGS = \"+447751xxxxxx\"");  // recipient's mobile number, in international format
  if (led_status==0)
  SIM900.println();
  Serial.println("Message sent");
    Serial.println("Reading incoming data");
      Serial.println("Got a ?");
      delay(100);
      while (SIM900.available())
        delay(100);
        buffer_pos++;
        if (buffer_pos==7) // Already incremented
          //Print it out
            digitalWrite(led13, HIGH);
            int led_status=digitalRead(led13);
            Serial.print ("LED status = ");
            Serial.println(led_status);  // prints status on serial terminal
          buffer_pos=0;
And it's not intended to be an example of good programming style!
thandana
Hi Dan,
Thanks for your comments - I will keep in mind going forward. Thank you also for the code you've sent, i have also tested on my modem and Led13 turns ON and STATUS sent upon receiving the code ?20!4#a0.
When u say it only works once, you mean the that the Led13 is turned ON once and the STATUS is sent once, correct?
This would be because the led13 is already ON if you try and resend the code again, so there will be no need to turn it ON again and the sendsms function will not run...Am i correct?
I will modify the code to include other secret_codes to be able to turn OFF and query the STATUS of the led
dannable
There is nothing in the code that would reject a second instance of 'Turn it on'. Send the SMS a second time, and watch the results in Serial Monitor.
thandana
Hi Dan,
I have modified the code to use a relay to turn ON/OFF and get the STATUS of the LED connect via breadboard. The code seems to intermittently work. May you kindly have a look at the below code:
Unfortunately, I cannot see why the 2nd the code will not run  :(
Code: [Select]
SoftwareSerial SIM900(2,3); // RX, TX
int pin8 = 8;
int led13 = 13;
char secret_code[] = "20!4#a1";
char secret_code1[] = "20!4#a0";
char secret_code2[] = "20!4#aS";
byte buffer_pos=0;
#define RELAY_ON 1
#define RELAY_OFF 0
#define Relay_2  7
#define Relay_3  6
#define Relay_4  5
  pinMode(pin8, OUTPUT);
  digitalWrite(pin8, LOW);  // Set led to LOW
  delay(100);
  delay(100);
  SIM900.println("AT + CMGS = \"+2XXXXXXX\"");  // recipient's mobile number, in international format
  if (led_status==0)
  SIM900.println();
      delay(100);
        delay(100);
        buffer_pos++;
          //Print it out
            digitalWrite(pin8, HIGH);
            int led_status=digitalRead(pin8);
          buffer_pos=0;
          buffer_pos=0;
          buffer_pos=0;
dannable
I know why it's not working. I left that for you to figure out. I've taken the sketch I posted earlier and added even more debug output to assist you.
Code: [Select]
int led13 = 13;
byte buffer_pos=0;
  delay(5000);  // give time to log on to network.
  SIM900.print("ATE1\r");
  delay(100);
  delay(100);
  //SIM900.print("AT+CMGF=1\r");                     // AT command to send SMS message
  //delay(1000);
  if (led_status==0)
  SIM900.println();
    Serial.print("Reading incoming data: ");
    Serial.print(int(incoming_char));
    Serial.print(" ");
    Serial.println(incoming_char);
      delay(100);
        delay(100);
        Serial.print("Reading incoming data in loop: Buffer_pos = ");
        Serial.print(buffer_pos);
        Serial.print(" ");
        Serial.print(" ");
        buffer_pos++;
          //Print it out
          buffer_pos=0;
thandana
