Topic: Capacitor on DTR pin? (Read 8088 times) previous topic - next topic
artswan
I am using the FTDI Basic Breakout (5.0V) from Sparkfun to program my standalone 168 Arduino. When I run a hookup wire from the FTDI Basic Breakout board DTR pin to the Reset pin on the Arduino and then try to program the chip, it doesn't work. HOWEVER, when I put a disc capacitor (0.1uf, 0.001 uf, 0.47 uf, or anything similar) from the DTR pin to the Reset pin on the chip instead of the wire, everything programs wonderfully and the auto-reset works, etc. All the photos I have ever seen on the hookup show a wire. Why does it take the capacitor to make it work instead?
Grumpy_Mike
Quote
Because the level on this signal line changes when the serial bridge is connected (enabled in software). However on the reset you only want a pulse. The capacitor acts as a differentiator.
artswan
Thanks! That helps. But, why do all the examples, ads, etc. show a wire? Is this common or something with my hookup? Am I doing something wrong?
retrolefty
Quote
All the Arduino (and clones) board schmatics I have seen used a cap to connect the DTR from the FTDI to the arduino reset. Can you post a link to the examples you are speaking of?
Lefty
artswan
Yes. While waiting for a reply, I went off and searched some schematics and some other posts on standalone arduino specifically and found several that showed the inline cap.
So, I am wondering,... thinking about getting the Ardweeny kit sold by Solarbotics, etc. The photos show the programming pins on top where you plug in the FTDI adapter for programming. Haven't seen the schematics yet... so I am wondering if the cap is already built into the circuit, or I will have to add it in somehow?
retrolefty
Quote
Can't say for sure without the schematic but I would think that they would include to series cap if they expect the Arduino IDE and the on-board Arduino bootloader software to work correctly for downloading new sketches.
Lefty
