Topic: Neopixel RTC clock (Read 872 times) previous topic - next topic
thmmax
Hey,
I would like to use a Neopixel 24 ring to display seconds from a RTC. I have the Teensy 2++ and the DS1307 Real Time Clock board. I was trying to use this code https://learn.adafruit.com/neopixel-ring-clock/code-and-clock-faces from a GPS clock and adapt it for the RTC.
Anyway I'm kind of stuck - I don't know exactly where and how to read the time from the RTC...after days of trying, that's my attempt:
Code: [Select]
//NeoPixel clock with FLORA based on Kevin Alford's NeoPixel ring clock face
//https://github.com/zeroeth/time_loop
//http://www.youtube.com/watch?v=b-mROp-ZKuk
//modified by Becky Stern for Adafruit Industries
#include <Time.h>
#include "RTClib.h"
#include <SoftwareSerial.h>
#include <Wire.h>
RTC_DS1307 RTC;
#define PIN 17
Adafruit_NeoPixel strip = Adafruit_NeoPixel(24, PIN, NEO_GRB + NEO_KHZ800);
#define outerTOP_LED                1
int outertopLED = outerTOP_LED;
float fLat = 0.0;
float fLon = 0.0;
uint32_t milli_color  = strip.Color ( 44,  21,  0);
uint32_t second_color = strip.Color ( 255, 0,  0);
uint32_t second1_color = strip.Color ( 44, 42,  0);
uint32_t off_color    = strip.Color (  0,  0,  0);
/* CLOCK */
class ClockPositions
public:
  uint8_t milli;
  uint8_t currentsecond;
  ClockPositions ();
  void update    ();
ClockPositions::ClockPositions()
  milli = 0;
   second = 0;
   minute = 30;
   hour = 6;
  //DateTime(__DATE__, __TIME__);
void ClockPositions::update()
  if (! RTC.isrunning())
    RTC.adjust(DateTime(__DATE__, __TIME__));
  currentsecond = outertopLED + map ((second() % 60), 0, 60, 0, 23);
  if (currentsecond > 24) {
    currentsecond = currentsecond-24;
  milli  = map ((millis() %  1000), 0,  1000, 0, 24);
int getDecimalTime()
  DateTime now = RTC.now();
  int decimalTime = now.hour() * 100 + now.minute() + now.second();
  return decimalTime;
/* CLOCK VIEW */
class ClockSegments
public:
  ClockPositions    &positions;
  Adafruit_NeoPixel &strip;
  ClockSegments (Adafruit_NeoPixel&, ClockPositions&);
  void draw  ();
  void clear ();
  void add_color (uint8_t position, uint32_t color);
  uint32_t blend (uint32_t color1, uint32_t color2);
ClockSegments::ClockSegments (Adafruit_NeoPixel& n_strip, ClockPositions& n_positions):
strip (n_strip), positions (n_positions)
void ClockSegments::draw()
  clear();
  add_color (positions.currentsecond     % 24, second_color);
  add_color ((positions.currentsecond+1) % 24, second_color);
  add_color ((positions.currentsecond+2) % 24, second_color);
  add_color (positions.milli     % 24,  milli_color);
  add_color ((positions.milli+1) % 24,  milli_color);
  add_color ((positions.milli+2) % 24,  milli_color);
  strip.show ();
void ClockSegments::add_color (uint8_t position, uint32_t color)
  uint32_t blended_color = blend (strip.getPixelColor (position), color);
  /* Gamma mapping */
  uint8_t r,b,g;
  r = (uint8_t)(blended_color >> 16),
  g = (uint8_t)(blended_color >>  8),
  b = (uint8_t)(blended_color >>  0);
  strip.setPixelColor (position, blended_color);
uint32_t ClockSegments::blend (uint32_t color1, uint32_t color2)
  uint8_t r1,g1,b1;
  uint8_t r2,g2,b2;
  uint8_t r3,g3,b3;
  r1 = (uint8_t)(color1 >> 16),
  g1 = (uint8_t)(color1 >>  8),
  b1 = (uint8_t)(color1 >>  0);
  r2 = (uint8_t)(color2 >> 16),
  g2 = (uint8_t)(color2 >>  8),
  b2 = (uint8_t)(color2 >>  0);
  return strip.Color (constrain (r1+r2, 0, 255), constrain (g1+g2, 0, 255), constrain (b1+b2, 0, 255));
void ClockSegments::clear ()
  for(uint16_t i=0; i<strip.numPixels (); i++) {
    strip.setPixelColor (i, off_color);
/* SIMPLE MIXER */
// add rgb and clamp
/* APP */
ClockPositions positions;
ClockSegments  segments(strip, positions);
void setup ()
  Wire.begin();
  RTC.begin();
  strip.begin ();
  strip.show (); // Initialize all pixels to 'off'
void loop ()
  positions.update ();
  segments.draw ();
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint32_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
    strip.setPixelColor(i, c);
    strip.show();
    delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
    delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  if(WheelPos < 85) {
    return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  else if(WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  else {
    WheelPos -= 170;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
Hopefully there's a solution 8)
Max
