Topic: Arduino 50 Hz sine wave Analog read problem (Read 6670 times) previous topic - next topic
Achira
HI,
I use arduino to read a sensor (Antenna) value. we measure from a oscilloscope that antenna values. we got that the maximum value or peak value is some what 200 mV. But the analog read value gives 1023 read as peak. when i give 5 v to the that pin then it gives 1023 also. what is the problem. Can you help me?
Here i attached the arduino readings and the screen shot of the oscilloscope.
Achira
#1
Sep 25, 2014, 06:02 am Last Edit: Sep 25, 2014, 08:46 pm by robtillaart Reason: 1
hi,
can you help me with this?
this signal is 50 Hz.
Grumpy_Mike
Quote
The problem is how you have wired it up. You need to post a schematic.
robtillaart
moderator:
please do not crosspost  (asking the same question more than once)
please do not use other persons thread for your questions.
thank you.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
mrburnette
#4
Sep 27, 2014, 02:01 am Last Edit: Sep 29, 2014, 02:18 pm by mrburnette Reason: 1
http://www.eetimes.com/author.asp?section_id=36&doc_id=1319495
You are misunderstanding what you are measuring w/ the o'scope.
You are simply measuring the power-line 50Hz inducement into the open wire connected to a probe with a 1 megaOhm typical AC/DC impedance.
W/Arduino, the AC hum inducement will be based upon the ADC characteristic DC impedance of approx 100 megaOhm.  But, Atmel indicates that a DC impedance of 10 kiloOhm is desired for accurate ADC measurements:
Quote
(23.6.1) Page 257 states: "The ADC is optimized for analog signals with an output impedance of approximately 10 k? or less. If such a source is used, the sampling time will be negligible. "
Then there is the whole issue that on the Arduino, you can only measure positive voltage, so the input signal must " ride" a bias voltage to allow the +/- nature of the AC to be DC offset.
So, in American lingo, you are comparing Apples to Oranges.
Ray
KenF
Your problem would be more obvious if you attached a speaker instead of an oscilloscope.  Mains hum is very distinctive :)
