Topic: LED Bar graph and Button (Read 19030 times) previous topic - next topic
BulldogLowell
can you post your current code?  the program you are using with the beep sounds?
thanks.
jameskirk
Just got home here is the code I used with the tone...
Oh it still does it with the tone not in...
Code: [Select]
#define PHASER 0
#define DIAGNOSTIC 1
int ledPin[10] = {12,11,10,9,8,6,5,4,3,2};
int scanArray[5] = {0b1000000001, 0b0100000010, 0b0010000100, 0b0001001000, 0b0000110000};
const int pushButton  = 7;
const int pushButton2 = 13;
const int pushButton3 = A1;
int spkr = A0;
int lastVal;
int lastVal2;
int lastVal3;
int index = 0;
byte state = PHASER;// initialises in phaser state
unsigned long timeStamp;
  for (int i = 0; i < 11; i++)
    pinMode(ledPin[i],OUTPUT);
  pinMode(pushButton,INPUT);
  pinMode(pushButton2,INPUT);
  pinMode(pushButton3,INPUT);
  int val=digitalRead(pushButton);
  delay(50); // Software debouncing
  if(val==HIGH && lastVal == LOW && state == PHASER)
    timeStamp = millis();
    index <<= 1;
    index |= 1;
    if (index > 0b1111111111) index = 0b1111111111;
    Serial.print("index = "); Serial.println(index, BIN);
    for (int i = 0; i < 10; i++)
      digitalWrite(ledPin[i], bitRead(index, i));
tone(spkr, 2000, 50);
  else if (val==LOW && lastVal == HIGH)
    if (millis() - timeStamp >= 2000UL)
      digitalWrite (ledPin[i], LOW);
    if (state == DIAGNOSTIC) state = PHASER;
    else state = DIAGNOSTIC;
  else if (val==HIGH && lastVal == LOW && state == DIAGNOSTIC)
    state = PHASER;
  lastVal = val;
  int val2 = digitalRead(pushButton2);
  if(val2 == HIGH && lastVal2 == LOW && state == PHASER)
    index >>= 1;
  lastVal2 = val2;
  // Keep this here for now................
  int val3 = digitalRead(pushButton3);
  delay(50);
  if (val3 == HIGH && lastVal3 == LOW)
    diagnogsticScan();
    // other diagnostic stuff here...
void diagnogsticScan()
  static unsigned long scanStart;
  static byte scanIndex = 0;
  static byte increment = 1;
  if (millis() - scanStart >= 60UL)
    Serial.println(scanIndex);
      digitalWrite(ledPin[i], bitRead(scanArray[scanIndex], i));
      Serial.println(i);
    scanIndex += increment;
    if (scanIndex == 0 || scanIndex == 4)
      increment = -increment;
    scanStart = millis();
Thank You
Michael
BulldogLowell
I think the problem is that the LedPin lites on reset, that may be affecting it
I changed this:
Code: [Select]
to this:
Code: [Select]
const int pushButton2 = 1;
and commented out Serial:
Code: [Select]
//Serial.begin(115200);
jameskirk
#33
Oct 15, 2014, 01:21 am Last Edit: Oct 15, 2014, 01:23 am by jameskirk Reason: 1
It made things worse when it comes on it beeps once and then starts the scroll blinking and when
you push the up button it is fine but the down button don't work...
If I put things in the right place that you wanted here is the code...
Code: [Select]
#define PHASER 0
int spkr = A0;
int lastVal;
int lastVal2;
int lastVal3;
int index = 0;
    index <<= 1;
    index |= 1;
    state = PHASER;
  lastVal = val;
    index >>= 1;
  lastVal2 = val2;
  delay(50);
    diagnogsticScan();
      Serial.println(i);
Thanks
Michael
BulldogLowell
Hmmm
It works fine for me, though I am using internal pull-up resistors and inverted the logic.
I'll post my code later.
BulldogLowell
this works well for me... notice the use of the internal pull-ups.
how are your pushbuttons wired?
Code: [Select]
#define PHASER 0
int ledPin[10] = {
int spkr = A0;
int lastVal;
int lastVal2;
int lastVal3;
int index = 0;
  pinMode(pushButton,INPUT_PULLUP);
  pinMode(pushButton2,INPUT_PULLUP);
  if(val==LOW && lastVal == HIGH && state == PHASER)
    index <<= 1;
    index |= 1;
  else if (val==HIGH && lastVal == LOW)
   state = PHASER;
  lastVal = val;
  if(val2 == LOW && lastVal2 == HIGH && state == PHASER)
    index >>= 1;
  lastVal2 = val2;
  delay(50);
    diagnogsticScan();
      Serial.println(i);
jameskirk
It is still messed up like before I can't use the down button and I can't switch to the diagnostic mode...
Here is my button Pic's...
Thanks
Michael
BulldogLowell
hmmm
did you try using the pull-ups and my code?
jameskirk
I copied the sketch you posted just a reminder when you say pullup resistor you mean in the sketch
not on the breadboard correct???
I found the problem...
I removed the 3rd switch from the breadboard and that's when all the problems started I reinstalled it now
there is no random blinking...
I tried removing it from the sketch but that messes everything up too...
I used the last good sketch before anything went wrong and it works...
But I still have that 3rd switch now...
Thanks
Michael
BulldogLowell
jameskirk
I need to get rid of the 3rd switch and remove it from the sketch...
BulldogLowell
well, don't you know I think I found the problem... but you are getting rid of the third switch already...
I forgot to put into the code:
Code: [Select]
  delay(50);
  lastVal3 = val3;//<<<<<<<<<<<<<<<<<<<<<<<<<<<< this line, right?
but you should be able to ditch that whole block of code, no problem since you are not using that hardware.
jameskirk
Well I removed what you said and I took out the...
Code: [Select]
Code: [Select]
int lastVal3;
Code: [Select]
  delay(50);
Now nothing works again...
BulldogLowell
don't take this out:
Code: [Select]
jameskirk
OK that worked (so far) lol...
Thanks
Michael
