Topic: 21 DOF Humanoid - IS THIS POSSIBLE? (Read 2984 times) previous topic - next topic
simone_pri
I'm planning to create a 21 DOF Humanoid
This is what i have already bought:
Code: [Select]
21 x  MG90S 9G (servo)
2 x  74HC4017 (5-STAGE รท 10 Johnson counter)
1x OV7670 (Camera) + AL422B (FIFO)
1x HC-05 (Bluetooth)
1x IIC I2C Logic leve converter 4 channels
1x MPU-6050 (Gyroscope + Acce??lerometer)
1x ARDUINO NANO ATMEGA328
All for about 115$
My plans  were initially only to create an humanoid that could walk controlled remotely by bluetooth.
Now, my professor asked me to add also a remote camera in the project (i know is hard also to have 1-2fps sended with the bluetooth but for me is enought)
So i want to manage the 20 servos with 2 x 74HC4017 as described here:
http://rcarduino.blogspot.it/2012/08/arduino-serial-servos.html
For controlling the stability i want to use a cheap MPU-6050 simply to get the actual center of gravity of the robot.
I know also this is a heavy work for the Microcontroller.
Next, my plans provide to send the robot's command through the Bluetooth . Like ("Move UP", "Move LEFT", etc..) so simple serial command.
The hardest thing is that i also want to add a remote camera view
with a seperate PWM servo for move the camera (the head of the robot)
So if you have read all this you and you think i'm crazy...is ook ahah
I think that for a 17MHz microcontroller is toooooo work to do.
So my questions are these:
CONCEPTUAL:
1) Whit REALLY WELL OPTIMIZED CODED CODE the arduino may can handle this?
2) If NOT a second AT328 only for the camera may be help? (the first control gyroscope + accelerometer + bluetooth and the second in slave control the camera)
HARDWARE:
1) How much ampere drains 21 servos controlled serially? One servo may drain about 300-400 mA . I really need of 10A ??
2)So established what is the average drain, what type of power suorce i'll have to use? Li-Po battery?
3)I really need of a board with something like 500+MHz of CPU for all this this?
This is how the robot should look like:
And this is the sketch of the connections:
Note:
I've never done anything like this, i've never dealed with this type of system programming, but my programming skills are relatively hight.
I really appreciate any type of suggestion/changes.
Best regards,
Simone.
raschemmel
Would you like us to write the program for your humanoid robot ?
Arduino UNOs, Pro-Minis, ATMega328, ATtiny85, LCDs, MCP4162, keypads,<br />DS18B20s,74c922,nRF24L01, RS232, SD card, RC fixed wing, quadcopter
simone_pri
There isn't any code yet ahah
i'm trying to undestand if it's possible with teh arduino before start.
raschemmel
Quote
I presume you mean:
Quote
ha ha.  There isn't any code yet
zoomkat
Quote
9G servos probably won't be strong enough to support your robot. You should research similar robots and see what size servos they use.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
