Topic: Rubik's cube Robot solver (Read 157864 times) previous topic - next topic
kas
#540
May 21, 2018, 04:49 pm Last Edit: May 21, 2018, 04:59 pm by kas
Let me have more info re this 'exit status 1 error'
Post the entire error message.
There is more information in the message that points to the type and location of the error
I sent you the App by email
kas
Quote
My message was returned with error code 550 (no such user)
Please confirm your email address via PM
Souli
Hello Kass!
I want to use a power based shield for my project to power the four servos... Which one do you advice
me?
Can I use this one?
https://www.amazon.com/gp/product/B01HNK6TQS/ref=ox_sc_act_title_1?smid=A2TOL213PF2CAG&psc=1
looking forward to hearing from you
kas
Hello Kas!
I want to use a power based shield for my project to power the four servos... Which one do you advice me?
I made my own shield
Quote
Can I use this one?
You can use this one although there are cheaper alternatives
ahappykid
Arduino: 1.8.4 (Windows 7), Placa:"Arduino BT, ATmega328P"
F:\PAP\software\CubeMover13_posted\CubeMover13_posted.ino:3:28: fatal error: VarSpeedServo.h: No such file or directory
 #include <VarSpeedServo.h>
compilation terminated.
exit status 1
Erro ao compilar para a placa Arduino BT.
Biblioteca inválida encontrada em C:\Program Files\Arduino\libraries\LiquidCrystal_I2C: C:\Program Files\Arduino\libraries\LiquidCrystal_I2C
here is the error message, i am sorry but some things are in portuguese.
kas
You need to install the VarSpeedServo library in your /Arduino/library folder
ahappykid
hi kas, with your help and with the help of everyone here i was able to build the structure and upload the code to the iteaduino board.
but i still have questions about how to power the servo motors so if you could show me how to connect the servos to the board it would be great.
thanks.
kas
#547
Jun 05, 2018, 07:40 am Last Edit: Jun 05, 2018, 09:51 am by kas
Quote
thanks.
Adapt for four servo's only
I use two LiFePO4 batteries  (6.8V)  for powering both Arduino and servo's
The safe way is to use separate power supplies (9V + 5/6V) to avoid browning out
Don't forget common grounds
EDIT: this drawing is for connection description only
Please don't use a solderless breadboard, wires should be soldered
Johan_Ha
How many amps can go through the positive rail in a solderless breadboard? Should the power current carrying wires of the servos be soldered directly to the power source instead of through the breadboard?
____________________
If you ask for help and write 'u' instead of 'you' because you think it's convenient, I will write 'no' instead of 'yes'. For same reasons.
kas
#549
Jun 05, 2018, 09:54 am Last Edit: Jun 05, 2018, 09:54 am by kas
Sure, solderless breadboard shouldn't be used
I edited my post accordingly
ahappykid
hi kas, i am having some problems with the code, when i power the servos they start moving on their own.
maybe i am connecting the servos to the wrong pins, can you please explain me a little of the code ?
kas
Quote
Please be more specific
Post connection diagram and a video showing those moves
ahappykid
i follow exactily the image you sent me, but the moment i power the iteaduino and the servos they move and lock in place, i bet i am connecting the servos to the wrong pin on the iteaduino.
and i also am having a problem with the app, if i connect the app with the iteaduino when i try to scan the app crashes.
i hope you can help me because i am almost out of time for my school project.
kas
Quote
According to CubeMover13_posted
"down" gripper:
#define    downPinchPin         9
#define    downRotPin          10
"back" gripper
#define    backPinchPin         5
#define    backRotPin            6
Quote
//boolean    DEBUG_SERIAL =       true;          // Python mode or Serial Monitor testing      //
boolean    DEBUG_SERIAL =         false;           // Android mode                                                   //
Please set DEBUG_SERIAL to false
ahappykid, I am not convinced you fully understand what you are trying to achieve  ::)
You should probably go for an easier project
mach1
Hi Kas
I have just recently found this project and I have decided to give it a go. I will retire soon and my plan is to start this in the autumn after the clocks turn at the end of October, so that I can get it ready for Christmas. It can be my Christmas present to myself. Meanwhile I will set about collecting the bits and pieces needed ready for the start date.
Being as you have been very helpful to people on this forum I was wondering if you would be kind enough to sell me a pair of grippers ready for my project.
If you are happy to do so I would prefer clear plexiglass, acrylic or perspex as a first choice, then as a second choice plywood.
I would be happy to pay the going rate for these items if you are prepared to produce them for me.
I have made a few projects with the Arduino in the past so I should be able to pick it up again with not too much difficulty, at least I hope so. The last think I did some time ago was a device to replace a timer switch to switch on a security/welcoming light which automatically changed the on time according to the time of year using an algorithm based on the equation of time, rather than an LDR. I have no experience of servos, but I have thought of learning to use them for some time and this seems like a good excuse to start with.
Many thanks mach1
