Topic: " Error loading hardware file" for attiny85 (Read 4889 times) previous topic - next topic
Yariv3G
I tried according to http://highlowtech.org/?p=1695 to mplement the attiny85 on the Arduino IDE, but it does not show the boards ATTINYs.
When loading the arduino_debug.exe, it says
"Could not find boards.txt in C:users\<my name>\Documents\Arduino\hardware\attiny\variants.
WARNING: Error loading hardware folder attiny
No valid hardware definitions found in folder attiny
attached is the file from the highlowtech site
On another PC this step worked.
Any idea what could be wrong?
BR
Yariv?
hiduino
The highlowtech attiny core is not setup to work with IDE 1.5.x.  You need to use IDE 1.0.x.
Yariv3G
Thanks,
Is there any other Attiny core that is supported by Arduino IDE 1.5.x?
Meanwhile I will check IDE 1.0.x
Thanks for the support
Y3G
Yariv3G
I installed IDE 1.0.6 and it seemed to be perfect until I tried to load the example ArduinoISP,
By trying to upload it I received an error I haven't seen long time: in the message window appeared:
" Binary sketch size: 5,590 bytes (of a 32,256 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00"
Funny is that even the Blink SIgnal does drop the same error (nothing to do with the Attiny).
Is it because I use an ATMEL ATMEGA 328P-PU in my UNO?
Any idea where this is comeing from now?
Thanks
Y3G
hiduino
Check your port setting, make sure you have the right serial COM port selected.
akkorber
There is a simple solution for this (at least it works for me):
You wrote:
Quote
The 1.0.x versions expects the file "boards.txt" and the folder "variants" at the place you put it.
For the 1.5.x version you just have to make a new folder within "C:users\<my name>\Documents\Arduino\hardware\attiny" named "avr" and move both the "boards.txt" and the "variants" folder into "avr".
Then, after restarting the IDE, you should have the boars listed.
Hope that helps.
AK
Yariv3G
Guys,
Thanks for your support! the upload worked when I used IDE 1.0.4 and went according to the guideline of the http://highlowtech.org/?p=1695. (See the upload report window below).
But when I connected an LED ,accordingly to the guideline,  between Pin0 and Ground there was no blinking.
This should work by only supplying VCC and GND to the ATTINY.
Am I  right?
UPLOAD REPORT from IDE 1.0.4
Binary sketch size: 836 bytes (of a 8,192 byte maximum)
C:\Program Files (x86)\Arduino\arduino-1.0.4\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Arduino\arduino-1.0.4\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -pattiny85 -cstk500v1 -P\\.\COM3 -b19200 -Uflash:w:C:\Users\YARIV~1.SHA\AppData\Local\Temp\build1073212491978223966.tmp\Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\arduino-1.0.4\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM3
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude done.  Thank you.
Yariv3G
You can Close this issue.
This Video on youtube did the change:
http://youtu.be/5-UsmGDPdak
I had to run the Example file ArduinoISP and then choosing in the Programmer Arduino as ISP. then it worked.
Thanks
Y3G
