Topic: Cheap and good way to feed 12v digital input (Read 16269 times) previous topic - next topic
Grumpy_Mike
Quote
Actually I am not using it to trigger any arduino pin..
So what are you using it for?
dlloyd
Cheap, good and small:
SOT-89 (7805): 1.6mm x 4.6mm, area 7.36mm2,
SOT-416 (DTC114W): 1.7mm x 0.9mm, area 1.53mm2, $0.20 each
I/O Connections: VIN 0-30V, OUT (inverted) connected to PIC input with Pull-up enabled.
nemo4all
Quote
I have mentioned it on my previous post. I am actually using it to trigger a SMD 8 Pin PIC Microcontoller..
The main target is to make the PCB as tiny as possible and making it cheap retaining the quality, as it will be mass produced..
nemo4all
I am unable to make out how will it work..
I went through the datasheet too, bu cant make out..It would be kind of you, if you can elaborate please..
dlloyd
Hint:
The 7805 has 3 terminals (INPUT, OUTPUT, GND).
The DTC114W has 3 terminals (IN, OUT, GND).
Grumpy_Mike
Quote
What does that mean?
By trigger do you mean turn on, like applying power controlled by something else?
That sounds like an even worse idea.
rmetzner49
It's actually quite novel.  He connects the GND to ground, obviously, the OUT to the input pin on his Arduino, and the IN of the regulator to his switch or whatever his 12V signal is.  The 7805's output will be 5V with anything from about 7V to 30V on its input.
Not how the manufacturer envisioned its use, but should work just fine.
dlloyd
Quote
Hmm...no capacitors.
Here's what the Society of Robots has to say about that.
JimboZA
Bit misleading: It's no more the Society of Robots saying anything than Messrs Arduino saying anything in this public forum, is it? (However correct the individual member's views may be....)
That said, not one of the many schematics in the 7805 datasheet lacks caps.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
cjdelphi
The caps would be very bad for serial communication... the 7805 will work up to a certain frequency but then it simply can't switch between 0 and 5v fast enough killing the serial data...
Change the 2 zener resistors for 10k to keep the current down.
CrossRoads
So what's the argument against using simple resistor divider with a zener just in case the input exceeds 16V?
dlloyd
Quote
Just 2 parts, smaller footprint, low cost 5.5ยข per PCB (qty 1000)
High performance: 0-30V Input, Max 250MHz transistor frequency, Inverted 0-5V output
DTC114W Digi-Key $0.04844 each (qty 1000)
ERJ-2RKF2201X Digi-Key $0.00699 each (qty 1000)
nemo4all
Quote
I actually meant that I am giving just and ON / OFF signal to the digital input of a PIC and the controls a condition..
I ON / OFF switching is not at all fast..
nemo4all
There is no argument at all..
The issue is the space in the PCB. I have to fit components in a very tiny place, so lesser components, easier for me..
CrossRoads
Two 0402 resistors and an 0603 zener, that's pretty small.
What quantities are you making these in?
