Topic: Mega 2560 used to debug a 1978 S-100 Z80 system (Read 10913 times) previous topic - next topic
dnar
Oct 18, 2014, 08:53 am Last Edit: Oct 18, 2014, 08:55 am by dnar Reason: 1
I thought I would share this little project with you to show how useful the Arduino can be to quickly solve problems.
I picked up this S-100 computer system (Z80 CPU) earlier this year in a non-working state. it comprises the following S-100 cards:
1 x Z80 Master CPU card running at 2Mhz
1 x Video card with composite output (memory mapped)
4 x 16kB SRAM boards for a total of 64kB
1 x VersaFloppy controller card
1 x Cassette interface
The system did not run at all and I was going around in circles trying to find the issue(s). So I stood back and thought if I could test each card individually then that would be more logical, and right I was just about every card had at least one fault!
So my plan was to use a blank S-100 card that I had to build a test CPU to enable testing of the memory cards and video output card. The video output card is memory mapped, so writing to memory locations would create a "test image". Doing so I managed to repair the video card quickly and move onto the 4 SRAM cards, which each had faulty chips. A total of 128 memory chips are used across the four boards so a few dud chips are to be expected considering their age!
Once I had validated the VDU and SRAM cards I removed my test Arduino CPU card and refitted the original Z80 CPU card which was amazingly easy to get going now with all other cards working. Turns out the monitor ROM had been plugged in the wrong way around! Reversing the ROM left me with a working S-100 system and a flood of memories of my early computing  years.
I used the Mega 2560 to drive the data and address busses and the various S-100 control signals. The sketch provided a familiar looking monitor program that I knocked up over a couple of evenings. This monitor allows me to read and write memory locations and to test specific blocks of memory using various bit patterns. Simples. If anyone wants the code, I can post it up also.
dnar
A few more pics.
graynomad
Man that takes me back, I love that stuff, those were the days, when men were men (and had to be to lift a computer :)).
I've written a few monitors over the years, even did one for the AVR not that long ago.
______
Rob
dnar
______
Rob
Thanks Rob.
The irony is the power of the Arduino Mega compared with this Z80 system.... All in a single chip!
graynomad
I cut my teeth on Z80 assembler and for years I've though of building a retro board with all my old favourites, CPU, PIO, SIO, CTC, etc. It would be a lot of fun but really, why bother...still the idea appeals all the same.
______
Rob
dnar
______
Rob
Same here, Z80 assembler is how I started out. I designed an all in one embedded board that I used in a few projects. Love the Z80 instruction set. I have written multiply and divide libraries too.
Riva
Though I started on the Z80 my favourite CPU has to be the Motorola MC68000
graynomad
Man I used to drule over the 68k data sheet, and that "aircraft carrier" package, they don't make 'em like that any more :(
I had a product on the market using a Z8, that was a real nice controller. And then another with the 64180, now that was a Z80 on steroids.
Oh well, time passes. I'm currently working with the LPC1549, what a weapon and TBH I can't see myself going back to a Z80 even as a trip down memory lane. The only problem with the new chips is that by the time I get proficient with one it's out of date. :)
______
Rob
graynomad
dnar, your pics have disappeared (courtesy of the recent forum upgrade I guess), any chance you can repost them?
______
Rob
dnar
______
Rob
They are visible to me. Fixed?
graynomad
Thanks, I had a mate who was interested in seeing them.
______
Rob
robwlakes
Hi Guys,
I have a similar romantic (as I just love those 70-ish things) aspiration to rebuild a SYM-1 (sorry guys, but 6502 is a grandparent of ARM :) ). It is a slightly later system than the S-100 bus & 8080 processors (ie one self contained board, good built in software, and plenty of I/O, sort of like an Arduino grand parent really).  I have (re-)acquired a SYM-1 board courtesy the Internet and 2 of 32k by 8bit chips to fully populate the memory space.  I also intend to use the Arduino products to emulate the audio cassette interface to the original board, as I no longer have a working cassette player/recorder (what a surprise!!).  I am tempted to do the TTY interface as well through an Arduino Mega + touch screen etc.  Using a modern FTDI chip I will having it with a a USB interface as well.  However I am held up with a huge technological hurdle haha, that is 22pin two way connectors at 0.156" spacing to do my memory expansion etc(I have ordered them but they are on a "Slow Boat from China" somewhere). I love the challenge of then having my SYM-1 hand crafted assembler ending up on a 4Gig SD card courtesy Arduino technology.
Great post...dnar
Cheers, Rob
Learning Flute and C++, heading for a meltdown.
dnar
#12
Oct 24, 2014, 05:17 pm Last Edit: Oct 24, 2014, 05:21 pm by dnar
Nice. I have been pondering an emulated cass interface too, by modifying the monitor rom casette read and write handlers to use zmodem....
FYI that S-100 system is based on the DG640 Z80 card, 640 VDU card as designed and built by Applied Technology here in Australia. In fact this board set was the precursor to the first Microbee home computer that is now legendary.
Hi Guys,
Great post...dnar
Cheers, Rob
graynomad
I remember AT, and of course the Microbee. I did a commercial product based on the uBee, all in Z80 assembler. and also an extension board with SIO/MAX232 (so it has a real serial port) and PIO plus EPROMs for several programs.
Did you know the Microbee has been resurrected?
http://www.microbeetechnology.com.au/premiumpluskit.htm
Where in Oz are you dnar?
______
Rob
rockwallaby
#14
Oct 25, 2014, 01:56 am Last Edit: Oct 25, 2014, 02:01 am by rockwallaby
Thanks for the article and pics dnar, brings back many memories, of the 1Kx 1bit sort  :)
I couldn't pick what sort of system that was, but I did a bit on Cromenco S100 systems back in the 80's.
Cromemco - Wiki.
Like Rob said, in those days, men were men, and I mention to him the other day that I recall flying into Melbroune with my work colleage to pick up a S100 system built out in Box Hill area in east Melbourne. I mean, we physically needed both of us to carry the darn thing. It sat on the seat next to me on the flight back home, it was considered that precious.
Ah, Microbee's, again, many years these things were part of my staple diet.
I once repaired a Microbee for a chap (Head of Library Services at the Tas Uni, called TSIT in those days) and in return was offered a quality vintage port. That bottle of port has travelled around dusty Australia with me. Two weeks ago I decide to give this 30 year plus botle of vintage port to a family member. I best go round there to try it I guess  :-[
Those sure were the days when you could see the pins on chips and count them.
I did a bit of S100 wire-wrapping back then as well, and these things were works of art with dedicated colours for each of the buses, data, address and control. Also some custom Z80 boards during my work at the Australian Maritime College here in Launceston.
Ah, well, back to today's reality I guess.
You did an outstanding job at getting that beast to work dnar.
Yeah, where abouts in Aus are you?
____
Paul
Paul - VK7KPA
