Topic: its possible a stepper go that fast? (Read 5429 times) previous topic - next topic
copachino
hi i got i video, i have tried a stepper nema 23 with 2Amp per fase and 12V and the fast it can go its 800Steps/second ibs about 4Rev/s and 240RPM, but that its assumed to go 1500RPM??, its about 8000 steps/s, could it be that possible with arduino??
runaway_pancake
Sure. Why not?
I'd use Port Manipulation to really snap things up.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
copachino
Sure. Why not?
how its that, can you show me please??, i dont need toeque as far as i can move a pastic pulley
runaway_pancake
To make it really fast, you have to knock out the step codes in parallel, [v]videlicet[/i]"Port Manipulation" -
http://playground.arduino.cc/Learning/PortManipulation
copachino
ummm im kind of lost on that, have never used something that way, im trying this simple code, but when speed its about 8oo steps per second, the motor just vibrates, and dont move at all.
Code: [Select]
#include <AccelStepper.h>
AccelStepper stepper; // Defaults to AccelStepper::FULL4WIRE (4 pins) on 2, 3, 4, 5
   stepper.setMaxSpeed(1000);
   stepper.setSpeed(50);
   stepper.runSpeed();
Grumpy_Mike
Quote
So that means the stall torque has been reached, therefore you need a higher voltage and a chopping regulator on the motor drive.
copachino
Quote
i have a current limiter at 2.0 amp per fase, and 12v i could try 36V(if i get a supply fot that. im using a computer supply), but the video show a real fast stepper, maybe it has many less steps than mine i have a regular 200step motor, myaybe at 36v i cold look go at maz 1500 step per second but i think that would be my ultimate speed
Grumpy_Mike
It depends entirely on what sort of motor you have as to the maximum speed you can obtain.
Quote
have tried a stepper nema 23 with 2Amp per phase and 12V
NEMA 23 just tells you about the physical size of the end plate of the motor, it has nothing to do with how much torque it can delver nor what speed it can go at. So we have no idea if you are under running or over running the motor by giving it 2A.
copachino
Quote
wel the motor have 2.0AMP per fase on the name plate, so i think current its ok, but i would to get more spedd, im trying to make the same aplication that the video
Grumpy_Mike
OK so given that you are running each phase at the rated value, and assuming that your power supply can provide 4A then increasing the voltage will increase the speed.
copachino
#10
Oct 19, 2014, 11:29 pm Last Edit: Oct 19, 2014, 11:34 pm by copachino Reason: 1
i need to get another supply the pc supply im using as all atx supplys only deliver 12V and 8A, so it ok but i need more voltage, i see that i can drive my motor up to 2000 steps per second, its running on that speed now, and have the power to move more than the pulley, but to achive the full speed, it have to be a low speed star to defeat the inertia, after that it goes nice up to 600RPM i think i could aim 1000RPM with 36V, thats the max voltage the driver its rated, and probably could sacrifice the motor by feeding up to 2.5A, now it have 20 minutes running and its not even heat
i took my amp meter, and snap it on one of the four leads, but most be something worng, its reading only .263A, maybe the snap it just to AC
Robin2
Have you a proper stepper motor driver board?
If so, please post a link to its datasheet
IF NOT - WHY NOT.
Not using a proper stepper driver board is like trying to make your car run on kerosene.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
copachino
IF NOT - WHY NOT.
...R
yes its a proper driver maded for somebody of the forum, it was maded for cnc, based on the DRv8025
http://www.electrofunltd.com/2012/11/elfdrv2-stepper-driver.html
Grumpy_Mike
The other technique to get a bit more speed is to ramp up to it. Look at the accell library for an example of how to do this..
copachino
yes im doing that with a pot, and i get around 2400 steps per second max, more than that the stepper start to stop itself
