Topic: Can we get Arduino style syntax coloring in the code box? (Read 4023 times) previous topic - next topic
dlloyd
The following is a section of code from the BlinkWithoutDelay example:
void loop()
// here is where you would put code that needs to be running all the time.
  // check to see if it is time to blink the LED; that is, if the
  // difference between the current time and last time you blinked
  // the LED is bigger than the interval at which you want to
  // blink the LED.
unsigned long currentMillis millis();
  if(
currentMillis previousMillis >= interval) {
// save the last time you blinked the LED
previousMillis currentMillis;
// if the LED is off turn it on and vice-versa:
if (ledState == LOW)
ledState HIGH;
ledState LOW;
// set the LED with the ledState of the variable:
digitalWrite(ledPinledState);
This was posted using php syntax coloring by using:
Code: [Select]
[table][td][php]your code[/php][/td][/table]
Without the white background:
Code: [Select]
Certain characters (in comments) get converted to the HTML char code (i.e. '), however I think the overall result is much more readable.
Is this an acceptable method to post code?
PCWorxLA
Nice one!
That should be acceptable! :smiley-cool:
Ralf
graynomad
Looks OK to me, but that's not a monospaced font though is it? That is an issue for code.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
dlloyd
______
Rob
Ahh, right ... could I borrow your glasses?
new bbCode for syntax coloring:  [table][td][tt][php]your code[/php][/tt][/td][/table]
without white background:  [tt][php]your code[/php][/tt]
void loop()
  // blink the LED.
  if(
ledState HIGH;
ledState LOW;
graynomad
#4
Oct 25, 2014, 12:08 am Last Edit: Oct 25, 2014, 12:21 am by Graynomad
 Just thought I'd give it a try without the white box
void loop()
  // blink the LED.
  if(
ledState HIGH;
ledState LOW;
looks pretty good either way I think. For large code snippets the normal tag might be better because that will (when it's fixed) give scroll bars.
So are [ tt ] and [ php ] standard BB codes?
______
Rob
MAS3
[tt] is new to me, [php] has been around for a while.
[php] also works on vBulletin boards, [tt] doesn't seem to exist there.
Have a look at "blink without delay".
Did you connect the grounds ?
Je kunt hier ook in het Nederlands terecht: http://arduino.cc/forum/index.php/board,77.0.html
dlloyd
Yes, it's standard. [tt] is the BB Code that gets entered when you press the "Teletype" button in the text editor.
http://wiki.simplemachines.org/smf/Alphabetical_list_of_all_bulletin_board_codes
dlloyd
It seems that SMF Syntax Highlighter or something similar is already implemented in this forum. The code tag can take a parameter without complaining, so if we use:
[code=Arduino]//your code[/code]
we get the parameter displayed in the code box title:
Code: (Arduino) [Select]
//your code
I would like to propose to the forum administrators that syntax coloring for Arduino be added to the necessary translation file(s) on the server. I think it would be an awesome feature to have this as default. Then after using code tags as normal, a code box would be created having code colored like this:
SurferTim
As I recall, if you use the "Edit - Copy for forum" selection in the IDE, you get the colors.
Quote
#include <SPI.h>
// test
...but you must use it between quote tags, not code tags.
dlloyd
Yes, that's the desired effect. (nice - I couldn't replicate it here, at least in Preview).
Robin2
This is a very good example of why we should be able to edit our posts when we like - see other discussion here.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
graynomad
#11
Oct 26, 2014, 11:52 pm Last Edit: Oct 27, 2014, 01:50 pm by Graynomad
If it's in quote tags it's a proportional font and some combinations are treated as bb codes, for example
Code: [Select]
for (int b = 0; b < 5; b++)
            array[b] = b;
func(8);
Quote
            array = b;
func(8);
Yes Robin I think it's essential that the edit timeout feature is removed.
EDIT (severel hours later): Looks like it has.
______
Rob
dlloyd
Changed title on first post.
This is as close as it gets (php style)...
Code: [Select]
//<?php>
ledState HIGH;
ledState LOW;
pYro_65
Rob
You can escape special text with 'nobbc' tags, like some have already used in posts here.
Quote
            array[b] = b;
func(8);
Quote
The feature 'copy for forum' now simply wraps the syntax in a code box (1.5.6 and up), no more quote styling.
Forum Mod anyone?
https://arduino.land/Moduino/
dlloyd
Thank you ffissore for submitting this as a feature request.
I would like to suggest that this feature be implemented in a way that requires no special action(s) by the user.
Since parameters are accepted by some BB codes (i.e. [size=36pt], [img width=200]), then it should be possible to add some style parameters to [code], where the Arduino style is default.
Examples:
[code]           Arduino syle syntax coloring
[code=plain]     No syntax coloring
[code=c++]       C++ syle syntax coloring
[code=php]       PHP syle syntax coloring
This way, pressing in the editor will use Arduino style coloring by default.
