Topic: RTC DS1307 --- Wir leben im Jahr 2165 (Read 8658 times) previous topic - next topic
PanTau78
Tja...
Kenne deine Lib nicht...
Und selbst nach aufmerksamen Lesen des Threads konnte ich nicht herausfinden, welche das ist.
Auch ist mir dein "RTC Monitor" noch nicht unter gekommen....
Ich benutze die RTClib.h und was genau meinst Du mit Monitor ?
Ich habe eben einen Code gefunden wo mit man die Uhr stellen kann, allerdings wird beim Jahr automatisch eine 0 gesetzt. Schade :(
Code: [Select]
// RTC data and time setter              //
// This sample program allows the user   //
// to set the date and time of an RTC    //
// using I2C.                            //
// Codes by:                             //
// eGizmo Mechatronix Central            //
// Taft, Manila, Philippines             //
// http://www.egizmo.com                 //
// April 15, 2013                        //
#include <Wire.h>
const int DS1307 = 0x68; // Address of DS1307 see data sheets
const char* days[] =
{"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
const char* months[] =
{"January", "February", "March", "April", "May", "June", "July", "August","September", "October", "November", "December"};
// Initializes all values:
byte second = 0;
byte minute = 0;
byte hour = 0;
byte weekday = 0;
byte monthday = 0;
byte month = 0;
byte year = 0;
  Wire.begin();
  delay(2000); // This delay allows the MCU to read the current date and time.
  Serial.print("The current date and time is: ");
  printTime();
  Serial.println("Please change to newline ending the settings on the lower right of the Serial Monitor");
  Serial.println("Would you like to set the date and time now? Y/N");
  while (!Serial.available()) delay(10);
  if (Serial.read() == 'y' || Serial.read() == 'Y')
  // This set of functions allows the user to change the date and time
    Serial.read();
    setTime();
    Serial.print("The current date and time is now: ");
    printTime();
  Serial.println("Thank you.");
// Continuous function for converting bytes to decimals and vice versa
byte decToBcd(byte val) {
  return ((val/10*16) + (val%10));
byte bcdToDec(byte val) {
  return ((val/16*10) + (val%16));
// This set of codes is allows input of data
void setTime() {
  Serial.print("Please enter the current year, 00-99. - ");
  year = readByte();
  Serial.println(year);
  Serial.print("Please enter the current month, 1-12. - ");
  month = readByte();
  Serial.println(months[month-1]);
  Serial.print("Please enter the current day of the month, 1-31. - ");
  monthday = readByte();
  Serial.println(monthday);
  Serial.println("Please enter the current day of the week, 1-7.");
  Serial.print("1 Sun | 2 Mon | 3 Tues | 4 Weds | 5 Thu | 6 Fri | 7 Sat - ");
  weekday = readByte();
  Serial.println(days[weekday-1]);
  Serial.print("Please enter the current hour in 24hr format, 0-23. - ");
  hour = readByte();
  Serial.println(hour);
  Serial.print("Please enter the current minute, 0-59. - ");
  minute = readByte();
  Serial.println(minute);
  second = 0;
  Serial.println("The data has been entered.");
  // The following codes transmits the data to the RTC
  Wire.beginTransmission(DS1307);
  Wire.write(byte(0));
  Wire.write(decToBcd(second));
  Wire.write(decToBcd(minute));
  Wire.write(decToBcd(hour));
  Wire.write(decToBcd(weekday));
  Wire.write(decToBcd(monthday));
  Wire.write(decToBcd(month));
  Wire.write(decToBcd(year));
  Wire.endTransmission();
  // Ends transmission of data
byte readByte() {
  byte reading = 0;
  byte incomingByte = Serial.read();
  while (incomingByte != '\n') {
    if (incomingByte >= '0' && incomingByte <= '9')
      reading = reading * 10 + (incomingByte - '0');
    else;
  Serial.flush();
  return reading;
void printTime() {
  char buffer[3];
  const char* AMPM = 0;
  readTime();
  Serial.print(days[weekday-1]);
  Serial.print(" ");
  Serial.print(months[month-1]);
  Serial.print(" ");
  Serial.print(monthday);
  Serial.print(", 20");
  Serial.print(year);
  Serial.print(" ");
  if (hour > 12) {
    hour -= 12;
    AMPM = " PM";
  else AMPM = " AM";
  Serial.print(hour);
  Serial.print(":");
  sprintf(buffer, "%02d", minute);
  Serial.print(buffer);
  Serial.println(AMPM);
void readTime() {
  Wire.requestFrom(DS1307, 7);
  second = bcdToDec(Wire.read());
  minute = bcdToDec(Wire.read());
  hour = bcdToDec(Wire.read());
  weekday = bcdToDec(Wire.read());
  monthday = bcdToDec(Wire.read());
  month = bcdToDec(Wire.read());
  year = bcdToDec(Wire.read());
PanTau78
Ok, habe die Werte einfach manuell eingetragen und funktioniert!
Code: [Select]
  year = 14;
  month = 10;
  monthday = 26;
  weekday = 1;
  hour = 12;
  minute = 7;
  second = 0;
