Topic: Sometimes after reboot, Yun bridge will not connect between Linux and Microcon (Read 397 times) previous topic - next topic
born2net
Sometimes after reboot, Yun bridge will not connect between Linux and Microcontroller.
I was thinking maybe it's related to the USB Adapter not having enough amp ... while it seems to make a difference which USB to 120V power adapter I am using (some seem to make this behavior worse), I still can't make the problem go 100% away (tried 4 diff USB > 120V adapters)...
Is anyone experiencing this kind of behavior where the Serial1 between the Linux and Micro Controller doesn't come up and you need to reboot again?
I am using Arduino Yun Rev 4 with latest software build
regards,
Sean.
born2net
I hope this helps someone.
you need to use this code.
  Serial1.begin(9600); // Set the baud.
  while (!Serial1) {}
  // Wait for U-boot to finish startup.  Consume all bytes until we are done.
  do {
     while (Serial1.available() > 0) {
        Serial1.read();
  } while (Serial1.available() > 0);
  Firmata.setFirmwareVersion(FIRMATA_MAJOR_VERSION, FIRMATA_MINOR_VERSION);
  Firmata.attach(ANALOG_MESSAGE, analogWriteCallback);
  Firmata.attach(DIGITAL_MESSAGE, digitalWriteCallback);
  Firmata.attach(REPORT_ANALOG, reportAnalogCallback);
  Firmata.attach(REPORT_DIGITAL, reportDigitalCallback);
  Firmata.attach(SET_PIN_MODE, setPinModeCallback);
  Firmata.attach(START_SYSEX, sysexCallback);
  Firmata.attach(SYSTEM_RESET, systemResetCallback);
  Firmata.begin(Serial1);
  systemResetCallback();  // reset to default config
