Topic: ASSEMBLER HELP : Fast clear of an array (Read 11244 times) previous topic - next topic
mcnobby
Hello all
I have dabbled with assembler on arduino (uno etc) but actually its more luck than judgement, trial and error of adjusting other assembly code I have seen others do
What I need is a very simple piece of code that will clear an array that has 1536 elements in it
for instance
my array is
Code: [Select]
screen[..]
in C it would just be
Code: [Select]
for (uint16_t x; x<1536; x++) {
   screen[x]=0;
But this just isnt fast enough
Can anyone help PLEASE ??
econjack
I don't have access to my system, but does:
Code: [Select]
  memset(screen, 0, sizeof(screen));
work any faster? Often the mem*() functions are hand-tweaked assembler, but I don't know if that's true for the C++ compiler. They could be macros that won't help, but it's worth a try.
robtillaart
#2
Oct 27, 2014, 06:19 pm Last Edit: Oct 27, 2014, 06:54 pm by robtillaart
the proof is in the pudding test
Code: [Select]
uint32_t start;
uint32_t stop;
byte screen[1536];
  Serial.println("Start ");
  start = micros();
  for (uint16_t x = 0; x<1536; x++)   // updated, see post el_supremo (Thanks)
    screen[x]=0;
  stop = micros();
  Serial.println(stop-start);
  start = micros();
  stop = micros();
Start
704
596
so memset is 15.6% faster (tested on UNO)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
el_supremo
Does this
Code: [Select]
implicitly set x to zero? If not, you aren't necessarily measuring the right thing.
Pete
Don't send me technical questions via Private Message.
robtillaart
@el_supremo (you are right - I'll fix that code - although the timing is right)
extended test with pointer math + including check if all is really set to zero.
Code: [Select]
uint32_t start;
uint32_t stop;
byte screen[1536];
  start = micros();
  for (uint16_t x=0; x<1536; x++)
    screen[x] = 0;
  stop = micros();
  Serial.print("reference:\t");
    if (screen[x] != 0) Serial.print(x);
    screen[x] = 1;
  start = micros();
  stop = micros();
  Serial.print("memset:\t\t");
    screen[x] = 1;
  start = micros();
  byte *r =  &screen[0] ;
  while(r < screen+1536) {
    *r = 0;
    r++;
  stop = micros();
  Serial.print("08 bit ptr:\t");
    screen[x] == 1;
  start = micros();
  uint16_t *p = (uint16_t *) &screen[0] ;
  while(p < (uint16_t *)(screen+1536)) {
    *p = (uint16_t)0;
    p++;
  stop = micros();
  Serial.print("16 bit ptr:\t");
    screen[x] == 1;
  start = micros();
  uint32_t *q = (uint32_t *) &screen[0] ;
  while(q < (uint32_t *)(screen+1536)) {
    *q = (uint32_t)0;
    q++;
  stop = micros();
  Serial.print("32 bit ptr:\t");
    screen[x] = 1;
Start
reference:   708
memset:   588
08 bit ptr:   684
16 bit ptr:   448
32 bit ptr:   316
So optimized 32 bits pointer version is more than twice as fast the reference.
This is partly because the addresses of screen and screen+1536 are multiples of 4.
Rob Tillaart
robtillaart
32 bit ptr code wrapped into a function.
Code: [Select]
void memclr(byte * addr, uint16_t size)
  uint32_t *p = (uint32_t *)addr;
  while( p < (uint32_t *)(addr + size) ) *p++ = (uint32_t)0;
result:  392  (slower than the hard coded 32bit ptr code but at least reusable)
Note it does only handle multiples of 4!
Rob Tillaart
jboyton
The fastest version:
Code: [Select]
    *q = (uint32_t)0;
    q++;
generated this code:
Code: [Select]
ldi r30, 0x5C ; get pointer to screen[]
ldi r31, 0x01 ;
rjmp test      ; test to see if we're already done
loop: st Z+, r1 ; set 4 sequential bytes to R1 (=0)
st Z+, r1
st Z+, r1
st Z+, r1
test: ldi r24, 0x07 ; get high byte of last location in screen[]
cpi r30, 0x5C ; compare low byte to index Z low byte
cpc r31, r24 ; compare high byte to index Z
brcs loop ;
I think you could squeeze more if you were willing to hand code in assembly.
Coding Badly
Typically, counting down to zero is faster than counting up.
robtillaart
Code: [Select]
  uint32_t *q = (uint32_t *)(addr + size);
  while( --q >= p ) *q = 0UL;
result ==> 364  (same order)
Rob Tillaart
robtillaart
#10
Oct 27, 2014, 09:14 pm Last Edit: Oct 27, 2014, 09:25 pm by robtillaart
Code: [Select]
 start = micros();
  uint64_t *t = (uint64_t *)screen;
  while(t < (uint64_t *)(screen+1536)) {
    *t++ = 0ULL;
  stop = micros();
  Serial.print(F("64 bit+ptr:\t"));
64 bit+ptr: 284
// works because 1536 is a multiple of 64 (24x64)...
// in fact this is loop unrolling...
284/708 = 40% of the reference time
Rob Tillaart
nickgammon
Why?
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
jboyton
#12
Oct 27, 2014, 09:21 pm Last Edit: Oct 27, 2014, 09:22 pm by jboyton
This produced a time of 212 ± 4 us:
I couldn't line up more than 48 stores in a row while still being a multiple of 1536, maybe because of the relative jump at the end.
Code: [Select]
  start = micros();
  asm(
    "eor r1, r1 \n\t"
    "ldi r30, lo8(screen) \n\t"
    "ldi r31, hi8(screen) \n\t"
    "ldi r24, hi8(screen+1536) \n\t"
 "1:                           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "st Z+, r1           \n\t"
    "cpi r30, lo8(screen+1536) \n\t"
    "cpc r31, r24 \n\t"
    "brcs 1b      \n\t"
     ::: "r1", "r24", "r30", "r31"
  stop = micros();
nickgammon
Loop unrolling, eh?
Code: [Select]
uint32_t *foo = (uint32_t *) &screen[0] ;
memset ((void *) screen, 1, sizeof (screen));
start = micros();
foo [0] = 0;
foo [1] = 0;
foo [2] = 0;
foo [3] = 0;
foo [4] = 0;
foo [5] = 0;
foo [6] = 0;
foo [7] = 0;
foo [8] = 0;
foo [9] = 0;
foo [10] = 0;
foo [11] = 0;
foo [12] = 0;
foo [13] = 0;
foo [14] = 0;
foo [15] = 0;
foo [16] = 0;
foo [17] = 0;
foo [18] = 0;
foo [19] = 0;
foo [20] = 0;
foo [21] = 0;
foo [22] = 0;
foo [23] = 0;
foo [24] = 0;
foo [25] = 0;
foo [26] = 0;
foo [27] = 0;
foo [28] = 0;
foo [29] = 0;
foo [30] = 0;
foo [31] = 0;
foo [32] = 0;
foo [33] = 0;
foo [34] = 0;
foo [35] = 0;
foo [36] = 0;
foo [37] = 0;
foo [38] = 0;
foo [39] = 0;
foo [40] = 0;
foo [41] = 0;
foo [42] = 0;
foo [43] = 0;
foo [44] = 0;
foo [45] = 0;
foo [46] = 0;
foo [47] = 0;
foo [48] = 0;
foo [49] = 0;
foo [50] = 0;
foo [51] = 0;
foo [52] = 0;
foo [53] = 0;
foo [54] = 0;
foo [55] = 0;
foo [56] = 0;
foo [57] = 0;
foo [58] = 0;
foo [59] = 0;
foo [60] = 0;
foo [61] = 0;
foo [62] = 0;
foo [63] = 0;
foo [64] = 0;
foo [65] = 0;
foo [66] = 0;
foo [67] = 0;
foo [68] = 0;
foo [69] = 0;
foo [70] = 0;
foo [71] = 0;
foo [72] = 0;
foo [73] = 0;
foo [74] = 0;
foo [75] = 0;
foo [76] = 0;
foo [77] = 0;
foo [78] = 0;
foo [79] = 0;
foo [80] = 0;
foo [81] = 0;
foo [82] = 0;
foo [83] = 0;
foo [84] = 0;
foo [85] = 0;
foo [86] = 0;
foo [87] = 0;
foo [88] = 0;
foo [89] = 0;
foo [90] = 0;
foo [91] = 0;
foo [92] = 0;
foo [93] = 0;
foo [94] = 0;
foo [95] = 0;
foo [96] = 0;
foo [97] = 0;
foo [98] = 0;
foo [99] = 0;
foo [100] = 0;
foo [101] = 0;
foo [102] = 0;
foo [103] = 0;
foo [104] = 0;
foo [105] = 0;
foo [106] = 0;
foo [107] = 0;
foo [108] = 0;
foo [109] = 0;
foo [110] = 0;
foo [111] = 0;
foo [112] = 0;
foo [113] = 0;
foo [114] = 0;
foo [115] = 0;
foo [116] = 0;
foo [117] = 0;
foo [118] = 0;
foo [119] = 0;
foo [120] = 0;
foo [121] = 0;
foo [122] = 0;
foo [123] = 0;
foo [124] = 0;
foo [125] = 0;
foo [126] = 0;
foo [127] = 0;
foo [128] = 0;
foo [129] = 0;
foo [130] = 0;
foo [131] = 0;
foo [132] = 0;
foo [133] = 0;
foo [134] = 0;
foo [135] = 0;
foo [136] = 0;
foo [137] = 0;
foo [138] = 0;
foo [139] = 0;
foo [140] = 0;
foo [141] = 0;
foo [142] = 0;
foo [143] = 0;
foo [144] = 0;
foo [145] = 0;
foo [146] = 0;
foo [147] = 0;
foo [148] = 0;
foo [149] = 0;
foo [150] = 0;
foo [151] = 0;
foo [152] = 0;
foo [153] = 0;
foo [154] = 0;
foo [155] = 0;
foo [156] = 0;
foo [157] = 0;
foo [158] = 0;
foo [159] = 0;
foo [160] = 0;
foo [161] = 0;
foo [162] = 0;
foo [163] = 0;
foo [164] = 0;
foo [165] = 0;
foo [166] = 0;
foo [167] = 0;
foo [168] = 0;
foo [169] = 0;
foo [170] = 0;
foo [171] = 0;
foo [172] = 0;
foo [173] = 0;
foo [174] = 0;
foo [175] = 0;
foo [176] = 0;
foo [177] = 0;
foo [178] = 0;
foo [179] = 0;
foo [180] = 0;
foo [181] = 0;
foo [182] = 0;
foo [183] = 0;
foo [184] = 0;
foo [185] = 0;
foo [186] = 0;
foo [187] = 0;
foo [188] = 0;
foo [189] = 0;
foo [190] = 0;
foo [191] = 0;
foo [192] = 0;
foo [193] = 0;
foo [194] = 0;
foo [195] = 0;
foo [196] = 0;
foo [197] = 0;
foo [198] = 0;
foo [199] = 0;
foo [200] = 0;
foo [201] = 0;
foo [202] = 0;
foo [203] = 0;
foo [204] = 0;
foo [205] = 0;
foo [206] = 0;
foo [207] = 0;
foo [208] = 0;
foo [209] = 0;
foo [210] = 0;
foo [211] = 0;
foo [212] = 0;
foo [213] = 0;
foo [214] = 0;
foo [215] = 0;
foo [216] = 0;
foo [217] = 0;
foo [218] = 0;
foo [219] = 0;
foo [220] = 0;
foo [221] = 0;
foo [222] = 0;
foo [223] = 0;
foo [224] = 0;
foo [225] = 0;
foo [226] = 0;
foo [227] = 0;
foo [228] = 0;
foo [229] = 0;
foo [230] = 0;
foo [231] = 0;
foo [232] = 0;
foo [233] = 0;
foo [234] = 0;
foo [235] = 0;
foo [236] = 0;
foo [237] = 0;
foo [238] = 0;
foo [239] = 0;
foo [240] = 0;
foo [241] = 0;
foo [242] = 0;
foo [243] = 0;
foo [244] = 0;
foo [245] = 0;
foo [246] = 0;
foo [247] = 0;
foo [248] = 0;
foo [249] = 0;
foo [250] = 0;
foo [251] = 0;
foo [252] = 0;
foo [253] = 0;
foo [254] = 0;
foo [255] = 0;
foo [256] = 0;
foo [257] = 0;
foo [258] = 0;
foo [259] = 0;
foo [260] = 0;
foo [261] = 0;
foo [262] = 0;
foo [263] = 0;
foo [264] = 0;
foo [265] = 0;
foo [266] = 0;
foo [267] = 0;
foo [268] = 0;
foo [269] = 0;
foo [270] = 0;
foo [271] = 0;
foo [272] = 0;
foo [273] = 0;
foo [274] = 0;
foo [275] = 0;
foo [276] = 0;
foo [277] = 0;
foo [278] = 0;
foo [279] = 0;
foo [280] = 0;
foo [281] = 0;
foo [282] = 0;
foo [283] = 0;
foo [284] = 0;
foo [285] = 0;
foo [286] = 0;
foo [287] = 0;
foo [288] = 0;
foo [289] = 0;
foo [290] = 0;
foo [291] = 0;
foo [292] = 0;
foo [293] = 0;
foo [294] = 0;
foo [295] = 0;
foo [296] = 0;
foo [297] = 0;
foo [298] = 0;
foo [299] = 0;
foo [300] = 0;
foo [301] = 0;
foo [302] = 0;
foo [303] = 0;
foo [304] = 0;
foo [305] = 0;
foo [306] = 0;
foo [307] = 0;
foo [308] = 0;
foo [309] = 0;
foo [310] = 0;
foo [311] = 0;
foo [312] = 0;
foo [313] = 0;
foo [314] = 0;
foo [315] = 0;
foo [316] = 0;
foo [317] = 0;
foo [318] = 0;
foo [319] = 0;
foo [320] = 0;
foo [321] = 0;
foo [322] = 0;
foo [323] = 0;
foo [324] = 0;
foo [325] = 0;
foo [326] = 0;
foo [327] = 0;
foo [328] = 0;
foo [329] = 0;
foo [330] = 0;
foo [331] = 0;
foo [332] = 0;
foo [333] = 0;
foo [334] = 0;
foo [335] = 0;
foo [336] = 0;
foo [337] = 0;
foo [338] = 0;
foo [339] = 0;
foo [340] = 0;
foo [341] = 0;
foo [342] = 0;
foo [343] = 0;
foo [344] = 0;
foo [345] = 0;
foo [346] = 0;
foo [347] = 0;
foo [348] = 0;
foo [349] = 0;
foo [350] = 0;
foo [351] = 0;
foo [352] = 0;
foo [353] = 0;
foo [354] = 0;
foo [355] = 0;
foo [356] = 0;
foo [357] = 0;
foo [358] = 0;
foo [359] = 0;
foo [360] = 0;
foo [361] = 0;
foo [362] = 0;
foo [363] = 0;
foo [364] = 0;
foo [365] = 0;
foo [366] = 0;
foo [367] = 0;
foo [368] = 0;
foo [369] = 0;
foo [370] = 0;
foo [371] = 0;
foo [372] = 0;
foo [373] = 0;
foo [374] = 0;
foo [375] = 0;
foo [376] = 0;
foo [377] = 0;
foo [378] = 0;
foo [379] = 0;
foo [380] = 0;
foo [381] = 0;
foo [382] = 0;
foo [383] = 0;
  stop = micros();
  Serial.print("unrolled loop:\t");
Gives:
Code: [Select]
unrolled loop: 200
jboyton
Diminishing returns to keep unrolling as the cost of the compare and jump isn't that high, relatively, as the number increases.
With 48 ST Z+, r1 instructions the time was 212 us.
With 24 it was 220.
With 8 it was 260
With 4 it was 308.
