Topic: Compilation error with LIFA_Base.ino for LabVIEW control (Read 25904 times) previous topic - next topic
John_R
A strange error when downloading the program that enables control by LabVIEW:
C:\programfiles (x86)\Arduino\Libraries\RobotIRremote\IRremoteTools.cpp:5 error 'IKD2' was not declared in this scope
On the PC is this file not present. However, when I look at a PC on my work where Arduino works flawless under LabVIEW this file is also not available; the RobotIRremote directory is absent as well.
I am stuck here, suggestions on how to solve this installation issue are welcome.
If any additional information is needed please let it know.
BR,
John
PaulS
Quote
If C:\program files (x86)\Arduino\Libraries\RobotIRremote\IRremoteTools.cpp didn't exist, the compiler would not be able to (try to) compile the file. Therefore, your assertion that the file doesn't exist is wrong.
John_R
Paul, thanks for the feedback. You were right, after a second look I did find the IRremoteTools.cpp file.
Here the complete listing:
#include "IRremote.h"
#include "IRremoteTools.h"
#include <Arduino.h>
int RECV_PIN = TKD2; // the pin the IR receiver is connected to
IRrecv irrecv(RECV_PIN); // an instance of the IR receiver object
decode_results results; // container for received IR codes
void beginIRremote(){
   irrecv.enableIRIn(); // Start the receiver
bool IRrecived(){
   return irrecv.decode(&results);
void resumeIRremote(){
    irrecv.resume(); // resume receiver
unsigned long getIRresult(){
   return results.value;
The error in compiling is with TDK2 (not with IDK2 as mentioned in the start post). So, a few steps have been taken in finding the location in the code that is central to the error message.
Not clear for me now why this error message is occurring? May-be it not declared in a .h file?
Assistence remains welcome.
Greetz,
John from The Netherlands with a Arduino UNO SMD, IDE 1.5.4
John_R
Issue has been solved.
A mix-up with the work-PC. On that PC there was no C:\programfiles (x86)\Arduino\Libraries\RobotIRremote\IRremoteTools.cpp file, it was present on my home PC. For my home PC the LIFA base program was copied from another PC.
I had re-installed Arduino and found an original LIFA_base.ino file on my own PC. This file can be compiled without any issue.
Rumbarolo
Hello
i'm getting this error after compile the LIFA_Base.ino
i have downloaded and putted in the same directory the various classes but the one that gives the error is the IRRemoteInt...
does anyone have the same problem?
the error give from the compiler is:
IRremoteInt.h:202: error: 'RAWBUF' was not declared in this scope
ideas ??!?
PaulS
My copy of the IRremoteInt.h file only has 112 lines. You appear to have an old(er) version. Get the latest version.
Julio_Romero_Vargas
Hi.
I need help to solve this problem whit my arduino board.
  enabled in File > Preferences.
Arduino: 1.0.6 (Windows NT (unknown)), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino\libraries\RobotIRremote\IRremoteTools.cpp:5: error: 'TKD2' was not declared in this scope
Goat_T
Hi All,
I had the same problem and copied the code from John_R, but I still get a message error: 'TKD2' was not declared in this scope. Can anyone advise ? Thanks G
PaulS
Quote
Can anyone advise ?
I advise you to post the code you can't compile. I advise you to define which Arduino you have selected, and which version of the IDE you are using.
Goat_T
Hi Paul, thanks a bunch for the reply, here is the code. Using 1.0.6
bool IRrecived(){
PaulS
Two answers/three questions is the wrong ratio. Until the ratio is greater than or equal to one, I'm not able to help you.
Goat_T
PaulS
Code: [Select]
So, where do you expect TKD2 to be magically defined?
buildOrBeRebuilt
I am still getting this error code, I properly imported/added github.com/shirriff/arduino-irremote library, but I am still getting error message below. Im using the latest version of Arduino, board is OSEPP Uno. I have tried uninstalling / installing again, checked wiring on my bot. Cant seem to get the IR remote to upload.
Arduino: 1.0.6 (Windows 7), Board: "Arduino Uno"
Any help will be appreciated.
PaulS
Quote
But you are STILL not defining why you think that TKD2 should be known. That you found some code somewhere that contained a possible error is NOT a reason to keep whining that it doesn't work. You MUST explain why you think it should work.
