dlloyd, yes, the fan is for general cooling and the led is for general lighting, not necessarily a power indicator, although it will certainly indicate that.
Pancake, so my two questions are still not quite clear - in "case A" when the zener is in its conducting state, will the board sensor "see" ground and hence be triggered?
Then, since the ground is floating on the sensor and since I'm getting this 24v unsensed, 14v sensed thing, neither config of 5v zener will do the job. I hadn't thought of a 24v > zener > 14v option... don't have one of those, really did think some divider would get the job done but still a mystery.
Simplest seems to make all in parallel and load them down with resistors to get the amount of air/light needed.
