Topic: Non-executing code block freezes, but works if block is in { } braces (Read 8838 times) previous topic - next topic
PaulS
Code: [Select]
Yes, it's the Teensy++ 2.0 from PJRC (thanks PaulS)
Paul Stoffregen, the maker of the teensy, posts under his complete name. I do not. You've got the wrong Paul S. there.
Jeff Rowberg
Ah. Oops. Sorry about that.
nickgammon
I originally took that approach because I ran into issues trying to get the Arduino IDE to compile multiple .cpp/.h files in the same sketch, way back when I started.
See: How to avoid the quirks of the IDE sketch file pre-preprocessing
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
Jeff Rowberg
I will definitely read through that prior to refactoring this project into a more normal format. Thanks!
^^^ EDIT: Good grief, this is fantastically simple. Amazing.
Follow-up on SRAM usage: according to Adafruit's quick RAM check function, I still have over 6kB of ram free out of the 8kB on the chip immediately prior to the offending lines of code, so it doesn't look like I'm running out of memory. That's what I thought, but all the same...good.
darkroomsource
I am nowhere near the guru that many on here are, and what this reminds me of is something that I encountered about 30 years ago working on assembler on an IBM mainframe, but when a line of code stops or starts mis-behaving when another line of code is inserted (even a single blank assembly instruction), it would seem to me that there is some kind of memory bounds issue involved.
Not necessarily that there is not enough memory, but that one variable ends up writing over another variable.
Without comparing the decompiled code of the two versions (with and without braces), it would be impossible to figure out why. And even having the decompiled code would be extremely difficult.
Can you possibly re-order the sequence of functions within a portion of the code, so that this function is earlier by one or two functions, or later by one or two functions. If it continues to fail, you probably have something, somewhere, that is setting the pointer to that function (in the if statement), but setting it to something that does not act as a function, and thus it "hangs" or terminates in such a way as to mess things up. (If it doesn't continue to fail, then the code will probably fail elsewhere after having moved the function).
My guess, is that when you put the braces in, you have moved the problem to elsewhere within your code, because somewhere you are overwriting a bit of memory outside of where you think you are writing.
Jeff Rowberg
Quick update on this issue: I finished rearranging the code into standard C project form, rather than one .ino and a million .h files. This has greatly simplified the code organization, especially regarding order-of-include challenges that I previously had a hard time solving.
I also noticed that at some point, my Arduino IDE had been set to run the Teensy++ at 16MHz (IDE default), rather than 8MHz. It's been modified with the 3.3v LDO, and per Paul Stoffregen's recommendation, that's a bad idea. An AT90USB1286 @ 3.3v is technically overclocked at 16MHz. Maybe the setting got reset when I updated to v1.0.6 of the IDE instead of the v1.0.5-r2 that I had been using...I really don't know how long it has been that way, but I put it back to 8MHz in the middle of the code rearrangement process.
The API event no longer freezes like it did before, despite not having some of the extra-safe adjustments to the code (braces around the conditional block, explicit NULL tests in "if" conditions, etc.). So far, things appear to be 100% reliable again.
I cannot say for sure what change fixed this behavior since there were many of them simultaneously, and I'm also not sure whether the problem is actually gone or only moved. It could still be an invalid memory dereference operation or buffer overflow that is once again invisible. In case it shows up again. I now have an AVR One debugger to attack the problem with. For the moment though, this case is closed. Thanks for all of your help and insight!
nickgammon
Glad to help, and good to hear your code is better organized. :)
