Topic: Yun External Antenna (Read 9338 times) previous topic - next topic
acastronovo
Hello all- I have found much discussion but no clear answer about the issue of connecting an external antenna to the Yun.
It seems the correct consensus is that the connector on the Yun board is a female SWF connector, like these:http://www.digikey.com/product-search/en/connectors-interconnects/coaxial-connectors-rf/1443098?k=swf%20connector
but there doesn't seem to be a male adapter that will mate with this???
someone mentioned this: http://www.digikey.com/product-search/en?site=us;lang=en;vendor=490;Keywords=MXHS83QE3000
but I'm not sure ( even at $50) if this will fit the connection on the Yun...
Has anyone successfully connected an external antenna? and saw signal gain?
Thanks Much!
lucad79
#1
Nov 08, 2014, 02:51 pm Last Edit: Nov 08, 2014, 02:52 pm by lucadentella
Hi! I gave up using the embedded wifi interface with an external antenna... the cheapest (and working!) solution I found was to use an usb->wifi adapter with an RP-SMA dipole antenna (8 euros on ebay):
http://www.lucadentella.it/en/2014/11/08/yun-adattatore-wifi-usb/
I was able to put my Yun in a metal box and still have it connected to my wireless network... hope this solution is suitable for you too!
mamu
That is a pretty cool solution! Thanks for sharing.
Bournetoride
How about swapping the connector on board to a male one so that you can use the lead  from any canibalised wifi router
http://www.ebay.co.uk/itm/390611645159
TickTock
From what I read about the Hornet AR9331 Wifi chip used on Yun, the two antenna inputs are set up for diversity (automatically selects which has the better signal strength).  So unless you put an antenna with more gain than the onboard antenna, you will never see any change in the link quality (will continue to select the internal antenna).  I have doubts that any of the monopole antennas you typically see will offer any improvement.
sonnyyu
#5
Nov 24, 2014, 05:10 am Last Edit: Nov 24, 2014, 05:18 am by sonnyyu
Give me a stick long enough and a pivot and I shall move the world.
Archimedes
http://forum.arduino.cc/index.php?topic=188976.msg1580756#msg1580756
http://forum.arduino.cc/index.php?topic=221945.msg1612044#msg1612044
People make 2 Openwrt base AR9331 with high gain antenna nodes on 1 mile distance  wells communications.
Just Give Me Antenna and I'll Show You the World!
pete_dl
FYI. I have managed to successfully attach an external antenna to the yun.
http://forum.arduino.cc/index.php?topic=188976.15
acastronovo
#7
Jun 04, 2015, 05:53 pm Last Edit: Jun 04, 2015, 05:54 pm by acastronovo Reason: attach pics
Thanks all for your help- I did get the external antenna connected, and it definitely, reliably, has boosted signal strength. I am getting good WiFi signal 150' from source. I used this cable to connect the antenna:
The connector is very tall an if you use a shield you will have to add male-female header pins between Yun and shield. Also there is an adapter between the cable and antenna:
http://www.digikey.com/product-detail/en/132171RP/ACX1247-ND/1011924
and the antenna from adafruit:
http://www.adafruit.com/products/945
sonnyyu
#8
Jun 04, 2015, 06:07 pm Last Edit: Jun 04, 2015, 06:09 pm by sonnyyu
Great job!
Adafruit 2.4GHz Dipole Swivel Antenna with RP-SMA - 5dBi
in line of sight environments;-
Every 6 dBi antenna gain will be double the distance.
Archimedes
Give me an antenna and I shall give you the world.
ShapeShifter
Good work on finding all of the parts, but if I'm reading it properly, it totals out to about $60 for the parts? That's an expensive antenna!
How well does the connector stay attached to the Yun? My understanding is that it doesn't latch in place?
acastronovo
Yes, about $60...expensive :o BUT for my application, it was the only way I could figure to get the range I needed- but like I said, it gets a strong signal 150' away from a standard wireless router.
As for the connection, it is solid. you press it down and it latches in place. the only drawback is that the connector here is tall, and if you are putting a shield on the Yun you need to have an addition set of male-female header pins to give the shield clearance.
sonnyyu
#11
Jun 06, 2015, 02:30 pm Last Edit: Jun 06, 2015, 02:32 pm by sonnyyu
FYI:
Dragino yun shield support external antenna natively
http://www.dragino.com/products/yunshield/item/86-yun-shield.html
Simply swap antenna.
sonnyyu
Plan C:
Use The Yun shield by remove 0R resistor which connects to internal antenna.
The Yun shield is out
http://forum.arduino.cc/index.php?topic=325188.0
GrantA
are you saying that the connector on the aerial on the dragino yun shield is the male one?
I wonder if they can be bought separately as I can't find a reasonably priced pigtail or male connector anywhere.
I've tried to stuff a wire into the female connector on the pigtail I have, but can't find a small enough wire that  fits reliably.
sonnyyu
#14
Jun 10, 2015, 02:25 pm Last Edit: Jun 10, 2015, 02:49 pm by sonnyyu
You could easily get those type connectors from Ebay, or shopping at Ebay's sourcing - Shenzhen.
more than one floors of shopping malls sell nothing but cable connectors.
http://forum.arduino.cc/index.php?topic=155946.msg1169500#msg1169500
While you are shopping cable connector in Shenzhen do not forget enjoy nice food.
http://forum.arduino.cc/index.php?topic=165543.msg1236954#msg1236954
