Topic: Another Arduino clone with 1284P (Read 19031 times) previous topic - next topic
Budvar10
Nov 06, 2014, 10:37 am Last Edit: Oct 02, 2015, 06:02 pm by Budvar10
Dear forum community,
I've built an Arduino like board with ATmega1284P chip. Here is the first functional prototype (poor mobile phone photo, I know) I'd like to show off.
Main features:
- ATmega1284P: more of FLASH, RAM, ports, etc.
- Arduino shape look (it is function less but I like it)
- additional ports - all of 1284P's ports are available; I'd tried at max. compatibility with UNO
- FT232RL instead ATMega16U2 as USB/RS232 convertor - due to the problems with a large amount of data transfer under some speeds so I decided for FTDI
- LEDs are on better visible place (especially if shield is plugged into the board)
- similar power circuit as UNO with automatic choice of source USB/barrel_jack
- full-swing crystal, tested with 16MHz, 18MHz, 18.432MHz, 20MHz)
and.. that's it.
I appreciate your comments but don't be a cruel, please. :)
Here is pin configuration (for PDIP)
       *[D22]    (PCINT8/XCK0/T0) PB0  1|        |40 PA0 (ADC0/PCINT0)   [D24/A0]
       *[D23]    (PCINT9/CLKO/T1) PB1  2|        |39 PA1 (ADC1/PCINT1)   [D25/A1]
        [D8]  (PCINT10/INT2/AIN0) PB2  3|        |38 PA2 (ADC2/PCINT2)   [D26/A2]
    PWM~[D9]  (PCINT11/OC0A/AIN1) PB3  4|        |37 PA3 (ADC3/PCINT3)   [D27/A3]
    PWM~[D10]  (PCINT12/OC0B/!SS) PB4  5|        |36 PA4 (ADC4/PCINT4)   [D28/A4]
        [D11] (PCINT13/ICP3/MOSI) PB5  6|        |35 PA5 (ADC5/PCINT5)   [D29/A5]
    PWM~[D12] (PCINT14/OC3A/MISO) PB6  7|        |34 PA6 (ADC6/PCINT6)   [D30/A6]*
    PWM~[D13]  (PCINT15/OC3B/SCK) PB7  8|        |33 PA7 (ADC7/PCINT7)   [D31/A5]*
                               !RESET  9|        |32 AREF
                                  VCC 10|        |31 GND
                                  GND 11|        |30 AVCC
                                XTAL2 12|        |29 PC7 (TOSC2/PCINT23)    [D21]*
                                XTAL1 13|        |28 PC6 (TOSC1/PCINT22)    [D20]*
   Rx0<-[D0]    (PCINT24/RXDO/T3) PD0 14|        |27 PC5 (TDI/PCINT21)      [D19]*
   Tx0->[D1]       (PCINT25/TXD0) PD1 15|        |26 PC4 (TDO/PCINT20)      [D18]*
   Rx1<-[D2]  (PCINT26/RXD1/INT0) PD2 16|        |25 PC3 (TMS/PCINT19)      [D17]*
   Tx1->[D3]  (PCINT27/TXD1/INT1) PD3 17|        |24 PC2 (TCK/PCINT18)      [D16]*
    PWM~[D4]  (PCINT28/XCK1/OC1B) PD4 18|        |23 PC1 (SDA/PCINT17)  [D15/SDA]
    PWM~[D5]       (PCINT29/OC1A) PD5 19|        |22 PC0 (SCL/PCINT16)  [D14/SCL]
    PWM~[D6]   (PCINT30/OC2B/ICP) PD6 20|        |21 PD7 (OC2A/PCINT31)      [D7]~PWM
Arduino clone with ATmega1284P   http://forum.arduino.cc/index.php?topic=277260.0
mcnobby
Very nice Budvar10, looks just like one of the Arduino range !!
I have seen a few of these boards similar, but you have done a good job there
Is the header pins/sockets configured for arduino shields, or custom ?
http://www.youtube.com/user/Recovered
http://www.smartshow.lighting
mrburnette
Budvar10
Many thanks.
@mcnobby
Thank you for positive reaction. The blue colour it caused probably.  :)  Header are configured for arduino shields, except of 5th one which is custom and contains rest of I/O from MCU. The goal was to make it as close as possible to UNO. Board is little bit longer than UNO in result just for that header.
@mrburnette
I'm interesting in everything concerned to 1284P. To be honest, older discussion around Mighty 1284 inspired me a lot.
mrburnette
Many thanks.
@mrburnette
Yes, it is a great 8-bit DIP workhorse.  A friend of mine ported the 6502 AVR emulator from a few years back and has Commodore 64 running on a ILI9341 TFT GLCD!  So cool.
If you are moving from 2560 Mega or from the 328/32U4 because of SRAM/Flash headroom, our discussions around the STM32 may really get you going!  Around $5 U.S., 32-bit, 20K SRAM, 72 MHz, 128KB Flash... still a very long way to go, but many sketches will run at this time when compiled under 1.5.7.
STM32 Maple
Ray
Budvar10
I know that there is a lot of other devices. Sometimes it hard to orientate. My interest is about 8-bit ATmega for now - free time activity (and I especially like 1284P. :) )  I think that they offer enough of power and are usable in many directions. It is only about know how to write effective code. E.g. I've been working on some sort of home automation system. During the app growth I've been rewriting it again and again and it always fits into 32kb so UNO is enough only it has not enough of pins. On the other side Mega has a lot of  pins but many of them are not on headers so I decided to make own with 1284.
I like your comparison to workhorse, that is exactly it. :)
ChilliTronix
Where is your 1284 board available?
Budvar10
#7
Nov 08, 2014, 03:08 am Last Edit: Nov 08, 2014, 03:11 am by Budvar10
It is a prototype now. I have just the first one piece but in next few weeks I will have the first series and also I have to prepare some presentation on web. I can contact you then if you want one or two but I didn't plan to run big trade.
larryd
From what I can see (very blurry) in you image you have done a great job.
I, however, like versions where the 1284 is the DIP package.
I guess I am just too old to go with surface mount controllers.
Good job!
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
westfw
I had cause to notice recently that a 1284 in this configuration (portC on an extra header) provides a pretty convenient mechanism for attaching to a JTAG debugging connection.  (The JTAG signals are on PC2..5, which are unnecessary to provide basic "Uno-like" service on the other connections.)
mcnobby
I thought that Larry, but then I decided to give it a go.. im 48 and have 12 inches of eyesight that is in focus.. I got myself some cheap x2.5 reading glasses, a very fine soldering iron, and some incredibly thin solder
after a bit of practise I am now soldering LQFP32's and now LQFP44's & 48's
My next big project has 2 x TQFP100's !! (god help me !!)
Bob
ChilliTronix
I'd be interested in seeing one at least. I don't mind it as a kit.
larryd
@mcnobby
Very nice work!
I do like to have the controller in a socket though.
No technical PMs.
mcnobby
Thanks Larry, I have already done several prototypes socketed, now this is moving nearer to a finished product I decided to go fully SM, fingers crossed I dont blow the micro !! ;)
larryd
If it blows, just unplug it and plug a new one in.   :smiley-zipper:
No technical PMs.
