AFAIK, both the SD and SdFat libs in the "patched-libs" that are in the Mighty-1284p 1.0.5 github distro work for all the 1284p variants in the distro, including boards with Bobuino pin definitions. That's why they are in there.
For example, in the file Sd2PinMap.h for the SD (official) lib, there are these macro defns:
#elif defined(__AVR_ATmega1284__) || defined(__AVR_ATmega1284P__) \
|| defined(__AVR_ATmega644__) || defined(__AVR_ATmega644A__) \
|| defined(__AVR_ATmega644P__) || defined(__AVR_ATmega644PA__)
#if defined(MIGHTY_1284P_VARIANT)
// from pins_arduino.h in mighty-1284p core
// Two Wire (aka I2C) ports
uint8_t const SDA_PIN = SDA;
uint8_t const SCL_PIN = SCL;
// SPI port
uint8_t const SS_PIN = SS;
uint8_t const MOSI_PIN = MOSI;
uint8_t const MISO_PIN = MISO;
uint8_t const SCK_PIN = SCK;
#define DPM(x) { PORT_TO_MODE(PORT_D##x), PORT_TO_INPUT(PORT_D##x), PORT_TO_OUTPUT(PORT_D##x), BIT_D##x }
static const pin_map_t digitalPinMap[NUM_DIGITAL_PINS] = {
DPM(0),
DPM(1),
DPM(2),
DPM(3),
DPM(4),
DPM(5),
DPM(6),
DPM(7),
DPM(8),
DPM(9),
DPM(10),
DPM(11),
DPM(12),
DPM(13),
DPM(14),
DPM(15),
DPM(16),
DPM(17),
DPM(18),
DPM(19),
DPM(20),
DPM(21),
DPM(22),
DPM(23),
DPM(24),
DPM(25),
DPM(26),
DPM(27),
DPM(28),
DPM(29),
DPM(30),
DPM(31)
#else
// else, assume Sanguino pin assignments
#warning "SANGUINO PIN ASSIGMENT ASSUMED"
uint8_t const SDA_PIN = 17;
uint8_t const SCL_PIN = 18;
// SPI port
uint8_t const SS_PIN = 4;
uint8_t const MOSI_PIN = 5;
uint8_t const MISO_PIN = 6;
uint8_t const SCK_PIN = 7;
static const pin_map_t digitalPinMap[] = {
{&DDRB, &PINB, &PORTB, 0}, // B0 0
{&DDRB, &PINB, &PORTB, 1}, // B1 1
{&DDRB, &PINB, &PORTB, 2}, // B2 2
{&DDRB, &PINB, &PORTB, 3}, // B3 3
{&DDRB, &PINB, &PORTB, 4}, // B4 4
{&DDRB, &PINB, &PORTB, 5}, // B5 5
{&DDRB, &PINB, &PORTB, 6}, // B6 6
{&DDRB, &PINB, &PORTB, 7}, // B7 7
{&DDRD, &PIND, &PORTD, 0}, // D0 8
{&DDRD, &PIND, &PORTD, 1}, // D1 9
{&DDRD, &PIND, &PORTD, 2}, // D2 10
{&DDRD, &PIND, &PORTD, 3}, // D3 11
{&DDRD, &PIND, &PORTD, 4}, // D4 12
{&DDRD, &PIND, &PORTD, 5}, // D5 13
{&DDRD, &PIND, &PORTD, 6}, // D6 14
{&DDRD, &PIND, &PORTD, 7}, // D7 15
{&DDRC, &PINC, &PORTC, 0}, // C0 16
{&DDRC, &PINC, &PORTC, 1}, // C1 17
{&DDRC, &PINC, &PORTC, 2}, // C2 18
{&DDRC, &PINC, &PORTC, 3}, // C3 19
{&DDRC, &PINC, &PORTC, 4}, // C4 20
{&DDRC, &PINC, &PORTC, 5}, // C5 21
{&DDRC, &PINC, &PORTC, 6}, // C6 22
{&DDRC, &PINC, &PORTC, 7}, // C7 23
{&DDRA, &PINA, &PORTA, 7}, // A7 24
{&DDRA, &PINA, &PORTA, 6}, // A6 25
{&DDRA, &PINA, &PORTA, 5}, // A5 26
{&DDRA, &PINA, &PORTA, 4}, // A4 27
{&DDRA, &PINA, &PORTA, 3}, // A3 28
{&DDRA, &PINA, &PORTA, 2}, // A2 29
{&DDRA, &PINA, &PORTA, 1}, // A1 30
{&DDRA, &PINA, &PORTA, 0} // A0 31
#endif
BTW, in case it is the cause of any confusion, there are no #ifdef BOBUINO (or similar) directives needed in the library files because the pin defns are already defined in the pins_arduino.h file for the Bobuino variant file. The code was generalized to work with all 1284p variants, not just the Bobuino variant.
Similarly for the patched Sdfat16 lib, this is from DigitalPin.h:
#elif defined(__AVR_ATmega1284P__)\
|| defined(__AVR_ATmega1284__)\
|| defined(__AVR_ATmega644P__)\
|| defined(__AVR_ATmega644__)\
|| defined(__AVR_ATmega64__)\
|| defined(__AVR_ATmega32__)\
|| defined(__AVR_ATmega324__)\
|| defined(__AVR_ATmega16__)
static const pin_map_t pinMap[NUM_DIGITAL_PINS] = {
DPM(0),
DPM(1),
DPM(2),
DPM(3),
DPM(4),
DPM(5),
DPM(6),
DPM(7),
DPM(8),
DPM(9),
DPM(10),
DPM(11),
DPM(12),
DPM(13),
DPM(14),
DPM(15),
DPM(16),
DPM(17),
DPM(18),
DPM(19),
DPM(20),
DPM(21),
DPM(22),
DPM(23),
DPM(24),
DPM(25),
DPM(26),
DPM(27),
DPM(28),
DPM(29),
DPM(30),
DPM(31)
#undef DPM
#else
// original Mighty Layout
static const pin_map_t pinMap[] = {
{&DDRA, &PINA, &PORTA, 0}, // A0 24
{&DDRA, &PINA, &PORTA, 1}, // A1 25
{&DDRA, &PINA, &PORTA, 2}, // A2 26
{&DDRA, &PINA, &PORTA, 3}, // A3 27
{&DDRA, &PINA, &PORTA, 4}, // A4 28
{&DDRA, &PINA, &PORTA, 5}, // A5 29
{&DDRA, &PINA, &PORTA, 6}, // A6 30
{&DDRA, &PINA, &PORTA, 7} // A7 31
#endif
If anyone is having problems with any of the patched libs with any of the 1284p variants, let me know and we can get to bottom of it. I was going to have a look to see if there were any changes needed to be compatible with 1.0.6 (I suspect not, but I'll be testing over the next few days.)
