Topic: Flash Page is Locked (Read 12635 times) previous topic - next topic
ard_newbie
@ IntraStellar
Could you upload the .bin of the skectch I provided in reply #14 with Sam-BA and see if something has changed.
I only clear all lock bits, not GPNVM bit 0 though, I can add this too...
IntraStellar
Yes. Now on, every time you need to program your 'pesky' Due, you have to use SAM-BA.
I still don't understand why Due with lock issue is bricked for Arduino IDE, even after a chip erase.
That does suck. How will I know if the sketch was successfully uploaded? Will SAM-BA function as a serial monitor as well?
@ IntraStellar
Yep, that's the file I have been uploading together with hello world.
Palliser
Once you have downloaded your sketch using SAM-BA, you can connect your Due to the USB programming port and use the serial monitor of the Arduino IDE as usual.
IntraStellar
That works! Thanks a bunch. I have tried both the 'hello world' sketch and the 'unlocking' sketch and they both run. Unfortunately the error still remains even after running the 'unlocking sketch' trough SAM-BA.
At least I can use the Due now even though it's a hazzle. If anyone have another solution that enables me to upload sketchs trough the Arduino IDE, I'm all ears!
ard_newbie
We know that the error message is incorrect since all lock bits are cleared.
We don't know if the security bit is set and if there is an issue with the ERASE process. I suspect the conjonction of several bugs.
I suggest that you upload, via SAM BA and the native USB port, this sketch to read GPNVM bits :
Code: [Select]
#define Serial SerialUSB
#define EEFC_FKEY 0x5A
__attribute__ (( __section__ (".ramfunc")))
uint32_t ReadGPNVM_bits(void)
  uint32_t status;
  uint32_t priMask = __get_PRIMASK ();
  __disable_irq();
  static uint32_t (* IAP_function) (boolean, uint32_t);
  IAP_function = (uint32_t(*)(boolean, uint32_t)) * ((uint32_t *) CHIP_FLASH_IAP_ADDRESS);
  // select flash Bank
  while (!(EFC0->EEFC_FSR & EEFC_FSR_FRDY));
  IAP_function(0, EEFC_FCR_FKEY(EEFC_FKEY) | EEFC_FCR_FCMD(EFC_FCMD_GGPB ));
  status = EFC0->EEFC_FRR;            // Read GPNVM Bits
  __set_PRIMASK (priMask);
  return status;
  Serial.begin(250000);
  while(!Serial);
  uint32_t __GPNVM = ReadGPNVM_bits();
  Serial.print(" GPNVM = 0b"); Serial.println(__GPNVM, BIN);
Note that the result wil be printed via the native USB port !! Select the COM port accordingly.
IntraStellar
The serial response from that code is "GPNVM = 0b1" which would indicate that the lock bit is set if I understand this correctly.
This is from the Due processor (AT91SAM3X8E) datasheet:
Quote from: AT91SAM3X8E datasheet
7.2.3.5 Security Bit Feature
The SAM3X/A series features a security bit, based on a specific General Purpose NVM bit (GPNVM bit 0). When
the security is enabled, any access to the Flash, either through the ICE interface or through the Fast Flash
Programming Interface (FFPI), is forbidden. This ensures the confidentiality of the code programmed in the Flash.
This security bit can only be enabled through the "Set General Purpose NVM Bit 0" command of the EEFC0 User
Interface. Disabling the security bit can only be achieved by asserting the ERASE pin at 1, and after a full Flash
erase is performed. When the security bit is deactivated, all accesses to the Flash are permitted.
It is important to note that the assertion of the ERASE pin should always be longer than 200 ms.
As the ERASE pin integrates a permanent pull-down, it can be left unconnected during normal operation.
However, it is safer to connect it directly to GND for the final application.
I don't really see what they mean by;
"Disabling the security bit can only be achieved by asserting the ERASE pin at 1, and after a full Flash
erase is performed."
Perhaps pressing the ERASE pin after doing a full flash erase trough SAM-BA?
ard_newbie
Now we are sure that the security bit has been set (however we still don't know why ...)
Here is a code to clear GPNVM bit 0, then read again GPNVM bits to know if the security bit has been properly cleard  (Note that the result wil be printed via the native USB port !! Select the COM port accordingly.):
Code: [Select]
  uint32_t status;
  __disable_irq();
  return status;
uint32_t ClearGPNVM_bits( uint32_t gpnvm )
  __disable_irq();
  // select flash Bank 0
  IAP_function(0, EEFC_FCR_FKEY(EEFC_FKEY) | EEFC_FCR_FARG(gpnvm) | EEFC_FCR_FCMD(EFC_FCMD_CGPB ));
  ClearGPNVM_bits( 0 );  // Clear security bit  GPNVM bit 0
  while (!Serial);
IntraStellar
Still the same output; "GPNVM = 0b1". So the bit fails to be reset somehow.
ard_newbie
As per datasheet:
.... Disabling the security bit can only be achieved by asserting the ERASE pin at 1, and after a full Flash
erase is performed. When the security bit is deactivated, all accesses to the Flash are permitted...
The only guess I can make is that the ERASE procedure is not performed properly or long enough.
Let see if the ERASE pin (PC0) is not driven anymore by the peripheral as it should be. Try to upload this code to print SYSIO12 bit level:
Code: [Select]
while(!Serial);
boolean  SYSIO12 = MATRIX->CCFG_SYSIO >> 12;
Serial.print( "SYSIO12 = "); Serial.println(SYSIO12);
IntraStellar
This gives the response: "SYSIO12 = 1"
doritnap
I am facing the same issue with my Arduino Due - Flash Page is locked. The flow described above with the SAM-BA does give a workaround. However, i wanted to solve it so i can upload scatches from the IDE only.
For this i've connected a SAM ICE ATMEL studio trying to reset the lockbit as described above (by God Member).
What i found is that bit 16 (0x00010000) stays on even after erase Chip. When i verify it's reset, i get an error: "one or more registers differs"
Any idea?
Thanks,
D
mamoto
I also have the same problem with 2 arduino due boards. I used SAM_BA to load the .bin file, but this is awkward. I solved it by doing the following:
- Find the platform.txt file in the Hardware / Sam / 1.6.xx /
- Find the second line from the bottom up: tools.bossac.upload.pattern = "{path.svg} {{cmd}" {upload.verbose} --port = {serial.port.file} -U {upload.native_usb} -e -w {upload.verify} -b "{build.path} / {build.project_name} .bin" -R
- Add "-u" before "-b": tools.bossac.upload.pattern = "{path.svg / {cmd}" {upload.verbose} --port = {serial.port.file} -U {upload. native_usb} -e -w {upload.verify} -u -b "{build.path} / {build.project_name} .bin" -R
- This means bossac will unlock all the bits. restar Arduino IDE
So everything works as well as it used to.
alokbkc
I have tried all the above.
But there is still same problem i.e. flash page is locked.
Please help.
TheSeventhCG
#43
May 17, 2019, 12:48 pm Last Edit: May 21, 2019, 12:31 pm by TheSeventhCG
Hi everyone  ;)
Just today i started to have the exact same problem, as many already have mention before.
Quote
Flash page is locked (47 pages in my case)
I first used the "fix" provided by @ard_newbie, but the problem still persisted:
In the IDE window, go to File / Preferences, then click in the url at the bottom of preferences:
c:\Users\....\AppData\Local\Arduino15\preferences.txt
Then go to: packages>arduino>hardware>sam>1.6.x>platform.txt
Copy and past platform.txt into a new blank IDE window (without setup() and loop()
At the end of the file, you will find:
-e -w -v -b  change this by:
-e -u -w -v -b
For the meaning of -u (unlock all Flash pages), see:
http://www.shumatech.com/web/products/bossa
Then copy the entire new file in platform.txt, save and close all IDE windows.
Open a new IDE window with the minimal sketch (setup() and loop()), all Flash pages should be unlocked now.
(I undid this changes, after i found out that mamoto's approach is working for me)
Right after, I followed the instructions from @mamoto and was able to get my Arduino Due working again. (As far as i can tell by now, done some uploads of different sketches):
The platform.txt file is located here:
Quote
In the IDE window, go to File -> Preferences, then click in the url at the bottom of preferences:
Then go to: packages -> arduino -> hardware -> sam -> 1.6.x -> platform.txt
Complete path: C:\Users\username\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.x
EDIT (20.05.2019): The bug fix of adding a "bossac flash unlock" in form of an "-u" to the platform.txt file, worked for around 3 days!!!
In order to continue working with the Flash on my Due, i tried several changes to the platform.txt file.
Until i found one that was working for me: (Changes are marked RED)
Quote
tools.bossac.upload.pattern="{path}/{cmd}" {upload.verbose} --port={serial.port.file} -U {upload.native_usb} -e -u -w {upload.verify} -u -b "{build.path}/{build.project_name}.bin" -R
tools.bossac_remote.upload.pattern=/usr/bin/run-bossac {upload.verbose} --port=ttyATH0 -U {upload.native_usb} -e -u -w -v -b /tmp/sketch.bin -R
EDIT (21.05.2019): But strangely after around 1 day of working properly, my Flash pages were once again locked!
At this point in time i decided to stop, putting forth more effort in trying to make i run just for a few days and switched to a SPI EEPROM.
Perhabs those work arounds may work for you , but sadly... not for me.
