Topic: TTL camera with AltSoftSerial giving no response (Read 4881 times) previous topic - next topic
KenF
KenF Wow I'm grateful for your time and effort! Absolutely I'd like to try the updated files and sample sketch.
At the end of the day, this is for a middle school science project using Infragram.org 'infrablue' images on one camera and standard color images on a second camera.
OK.  I've also made copies of the examples that came with the original libraries.  modified to work with the mega.  (using serial only)
Bear with me, I'll Just rename the library files zip them up and find somewhere to upload.  But like I say, I haven't got any hardware to test this on.
KenF
Both HardwareSerial and SoftwareSerial derive from Stream, and provide the same functionality (though in very different ways). If the Adafruit_VC0706 class to a pointer to the instance of HardwareSerial or SoftwareSerial to write to, it would not be necessary to know which derived class the pointer pointed to.
This is my thoughts exactly.  Unfortunately, as it stands, there are three different constructors.  They all include pointers to different types.  A bit of cross casting, with perhaps an extra parameter to denote the actual type being passed, could overcome the issue.
Maybe later.
Bucky99
No Problem - I'll test - I have the hardware to test on.
KenF
OK Here are the modded library files.  I've renamed them MegaVC0706 so that you can keep your existing libraries without any conflict.
If you install them properly, you should be able to find the examples from the IDE MEGAMotionDetect and MEGASnapshot.
KenF
By the way, you realise you'll have to use the pins that are used for the Serial1 (instead of your software serial ones)  Serial 1 uses pin 18 for tx  pin 19 for rx
Here's the example code you posted earlier with the modifications to suit.
Code: [Select]
#include <MegaVC0706.h>
#include <SD.h>
Adafruit_VC0706 cam_01 = Adafruit_VC0706(&Serial1);  //Pin 18 TX  Pin 19= RX
Adafruit_VC0706 cam_02 = Adafruit_VC0706(&Serial2);  //Pin 16 TX  Pin 17= RX
#define chipSelect 53
pinMode(chipSelect, OUTPUT); // SS
   // Try to locate the camera
  if (cam_01.begin()) {
    Serial.println("01 Camera Found:");
    Serial.println("No 01 camera found?");
  if (cam_02.begin()) {
    Serial.println("02 Camera Found:");
    Serial.println("No 02 camera found?");
  // Print out the camera version information
  char *reply = cam_01.getVersion();
  if (reply == 0) {
    Serial.println("Failed to get 01 version");
    Serial.println("-------01 Cam----------");
    Serial.print(reply);
    Serial.println("-----------------");
  reply = cam_02.getVersion();
  if (reply == 0) {
    Serial.println("Failed to get 02 version");
    Serial.println("--------02 Cam---------");
Bucky99
SUCCESS Wow Wow Wow  :D
Here's my Hacked version of your MEGASnapShot sample with two Camera connections using the hardware Serial. Tested and Saving pictures to the SD! I know the Picture taking code (copy/paste) is not optimal but it works.
Thank you KenF! Let the Algae growth begin! LOL
Code: [Select]
#include <SD.h>
#define chipSelect 10
  // When using hardware SPI, the SS pin MUST be set to an
  // output (even if not connected or used).  If left as a
  // floating input w/SPI on, this can cause lockuppage.
pinMode(53, OUTPUT); // SS on Mega
Serial.println("VC0706 Camera snapshot test");
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    return;
    Serial.println("Camera 1 Found:");
    Serial.println("No camera 1 found?");
    return;
    Serial.println("Camera 2 Found:");
    Serial.println("No camera 2 found?");
    return;
  // Print out the camera version information (optional)
  if (reply == 0) {
    Serial.print("Failed to get 1 version");
    Serial.println("--------1---------");
  if (reply == 0) {
    Serial.print("Failed to get 2 version");
    Serial.println("-------2 ----------");
  // Set the picture size - you can choose one of 640x480, 320x240 or 160x120
  // Remember that bigger pictures take longer to transmit!
  cam_01.setImageSize(VC0706_640x480);        // biggest
  cam_02.setImageSize(VC0706_640x480);        // biggest
    Serial.println("Snap Cam_01 in 3 secs...");
  delay(3000);
  if (! cam_01.takePicture())
    Serial.println("Failed to snap!");
    Serial.println("Picture taken!");
  // Create an image with the name IMAGExx.JPG
  char filename[13];
  strcpy(filename, "IMAGE00.JPG");
  for (int i = 0; i < 100; i++) {
    filename[5] = '0' + i/10;
    filename[6] = '0' + i%10;
    // create if does not exist, do not open existing, write, sync after write
    if (! SD.exists(filename)) {
  // Open the file for writing
  File imgFile = SD.open(filename, FILE_WRITE);
  // Get the size of the image (frame) taken
  uint16_t jpglen = cam_01.frameLength();
  Serial.print("Storing ");
  Serial.print(jpglen, DEC);
  Serial.print(" byte image.");
  int32_t time = millis();
  pinMode(8, OUTPUT);
  // Read all the data up to # bytes!
  byte wCount = 0; // For counting # of writes
  while (jpglen > 0) {
    // read 32 bytes at a time;
    uint8_t *buffer;
    uint8_t bytesToRead = min(32, jpglen); // change 32 to 64 for a speedup but may not work with all setups!
    buffer = cam_01.readPicture(bytesToRead);
    imgFile.write(buffer, bytesToRead);
    if(++wCount >= 64) { // Every 2K, give a little feedback so it doesn't appear locked up
      Serial.print('.');
      wCount = 0;
    //Serial.print("Read ");  Serial.print(bytesToRead, DEC); Serial.println(" bytes");
    jpglen -= bytesToRead;
  imgFile.close();
  time = millis() - time;
  Serial.println("done!");
  Serial.print(time); Serial.println(" ms elapsed");
  Serial.println("Snap Cam_02 in 3 secs...");
  delay(3000);
  if (! cam_02.takePicture())
//  char filename[13];
//  File imgFile = SD.open(filename, FILE_WRITE);
//  uint16_t jpglen = cam_02.frameLength();
  jpglen = cam_02.frameLength();  Serial.print("Storing ");
//  int32_t time = millis();
  time = millis();
  pinMode(8, OUTPUT);
//  byte wCount = 0; // For counting # of writes
    uint8_t *buffer;
    buffer = cam_02.readPicture(bytesToRead);
      Serial.print('.');
      wCount = 0;
  imgFile.close();
  delay(60000);
Bucky99
Yes, Thank your for checking!
KenF
Brilliant.  The hardware serial should be more reliable than the software varieties anyhow.  How many cameras are you likely to be using at any one time?  Obviously you realise there's still Serial3 and even plain Serial can be used.
As it stands, on a mega2560, this library won't work with software serial any more.  With a bit of effort, I could probably rectify that, but would it be worth it?
Bucky99
Opps The above code will not take additional pictures without .resumeVideo(); at the end of each picture.
This project only requires two cameras, one with a blue filter and one standard. Yes I realize I still have two more Serial that can be used.
So far I do not see any reason to fix software serial for this MegaVC0706 library. It will work with up to 4 hardware serial connections. Which is two more than I need with this project.
Many Many Thanks KenF!
j3kk
Hi all,
I've followed this thread and have attempted to implement changes to the code such that the Arduino Due is supported.
Is it possible? Everytime I run the compiler, it hangs up and doesn't finish. I don't know what to do.
Changes I made:
replaced defined(__AVR_ATmega2560__) with defined(__SAM3X8E__)
Using Serial1 on the Due, which corresponds to pins 18 and 19.
Here is the verbose white text that spits back at me before it hangs there:
Code: [Select]
Using library SD in folder: C:\Program Files (x86)\Arduino\libraries\SD
C:\Users\Mahdie\AppData\Roaming\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -Wall -Wextra -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -Dprintf=iprintf -MMD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO=10604 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER="Unknown" -DUSB_PRODUCT="Arduino Due" -IC:\Users\Mahdie\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\system/libsam -IC:\Users\Mahdie\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\system/CMSIS/CMSIS/Include/ -IC:\Users\Mahdie\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\system/CMSIS/Device/ATMEL/ -IC:\Users\Mahdie\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\cores\arduino -IC:\Users\Mahdie\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\variants\arduino_due_x -IC:\Program Files (x86)\Arduino\libraries\SD\src C:\Users\Mahdie\AppData\Local\Temp\build6636715804119919100.tmp\DUE_Proj3.cpp -o C:\Users\Mahdie\AppData\Local\Temp\build6636715804119919100.tmp\DUE_Proj3.cpp.o
C:\Users\Mahdie\AppData\Roaming\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -Wall -Wextra -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -Dprintf=iprintf -MMD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO=10604 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER="Unknown" -DUSB_PRODUCT="Arduino Due" -IC:\Users\Mahdie\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\system/libsam -IC:\Users\Mahdie\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\system/CMSIS/CMSIS/Include/ -IC:\Users\Mahdie\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\system/CMSIS/Device/ATMEL/ -IC:\Users\Mahdie\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\cores\arduino -IC:\Users\Mahdie\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\variants\arduino_due_x -IC:\Program Files (x86)\Arduino\libraries\SD\src C:\Users\Mahdie\AppData\Local\Temp\build6636715804119919100.tmp\Due_VC0706.cpp -o C:\Users\Mahdie\AppData\Local\Temp\build6636715804119919100.tmp\Due_VC0706.cpp.o
