Hello all,
I'm using two flex resistors to control two servo motors. Somewhere in the code (pasted below) I have an error. The code compiles correctly, but when I flash it to an Uno R3, the servo attached to pin 10 flies fully counterclockwise and gets stuck in that position. I'm using Parallax standard servos. If I alter the code and swap pin 9 for pin 10, the erroneous servo behavior is copied to the other motor and the previously problematic motor behaves correctly. I have not doubt it is something really obvious that I am just missing after an all night work session. The code is as follows:
Code
#include <Servo.h>
Servo servoLeft, servoRight;
int flexpin = A0;
int flexpin1 = A1;
servoLeft.attach(9);
servoRight.attach(10);
int flexposition;
int servoposition;
int flexposition1;
int servoposition1;
flexposition = analogRead(flexpin);
flexposition1 = analogRead(flexpin1);
servoposition = map(flexposition, 760, 905, 0, 180);
servoposition = constrain(servoposition, 0, 180);
servoposition1 = map(flexposition1, 760, 905, 0, 180);
servoposition1 = constrain(flexposition1, 0, 180);
servoLeft.write(servoposition);
servoRight.write(servoposition1);
Serial.print("sensor1: ");
Serial.print(flexposition);
Serial.print(" servo1: ");
Serial.println(servoposition);
Serial.print("sensor2: ");
Serial.print(flexposition1);
Serial.print(" servo2: ");
Serial.println(servoposition1);
delay(100);
/code
Thanks very much.
