Topic: Unire sketch (Read 581 times) previous topic - next topic
-d0b-
Nov 20, 2014, 08:56 pm Last Edit: Nov 20, 2014, 09:08 pm by -d0b-
 Vorrei imparare ad unire gli scketch... spero che qualcuno mi possa instradare.
Nel particolare devo unire
. scketch  DHT11
Code: [Select]
int pin=4;
DHT11 dht11(pin);
 while (!Serial) {
     ; // wait for serial port to connect. Needed for Leonardo only
 int err;
 float temp, humi;
 if((err=dht11.read(humi, temp))==0)
   Serial.print("temperature:");
   Serial.print(temp);
   Serial.print(" humidity:");
   Serial.print(humi);
   Serial.print("Error No :");
   Serial.print(err);
 delay(DHT11_RETRY_DELAY); //delay for reread
. sketch  DS18B20
Code: [Select]
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices
// (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
void setup(void)
  // start serial port
  Serial.println("Dallas Temperature IC Control Library Demo");
  // Start up the library
  sensors.begin();
void loop(void)
  // call sensors.requestTemperatures() to issue a global temperature
  // request to all devices on the bus
  Serial.print(" Requesting temperatures...");
  sensors.requestTemperatures(); // Send the command to get temperatures
  Serial.println("DONE");
  Serial.print("Temperature for Device 1 is: ");
  Serial.print(sensors.getTempCByIndex(0)); // Why "byIndex"?
    // You can have more than one IC on the same bus.
    // 0 refers to the first IC on the wire
in rete si trovano discussioni... ad esempio http://forum.arduino.cc/index.php?topic=271977.0
ma non spiega come fare ... datemi una mano a capire anche con link vari
grazie... forse era meglio postarlo nella sezione software....
uwefed
Non puoi "unire"
Devi scrivere un sketch che fa sia una cosa che l' altra e devi decidere in che maniera fa una cosa e l' altra. uno dopo l' altra, una 10 volte e poi l' altra 1 volta, uno ogni minuto e l' altra ogni 10 secondi ecc.
Ciao Uwe
