Topic: 32mHz ARDUINO PROJECTS.. ATMega328P etc... (Read 21305 times) previous topic - next topic
mcnobby
UPDATE : I have tried & tested 32MHz crystal oscillators on many ATMega328, ATTiny85, and ATTiny13A (all 20MHz variants) I have decided to push things to the limit...
I have ordered one 40mhz oscillator for testing.. these things run at a juicy 40ma plus more current drawn from the microprocessor because of the extra speed.
I shall revisit with my results soon :)
ChilliTronix
mrburnette
Do you feel the need for speed?
IMO..
Not just speed, but the thrill of the chase.
Ray
westfw
For a while, I was thinking that one of the new XMega chips running at 32MHz would be a useful addition to the Arduino line.   Now, I just think that anyone who needs the speed should jump to one of the ARM boards.
CrossRoads
Yes, make those LEDs blink really fast ... even faster delay() for button pushes ...
mcnobby
Ha ha, thanks all !!
westFw, I have been thinking about the arm stuff, even to the point of getting several stm32f1 boards after the (now very long) topic was started on here.
for me its not a simple jump, I write in C AND assembler, the task of learning the 32bit assembly and all the register manupulation didnt suit me too well as I am just about coping with 8 bit !!
Crossroads, it is mainly for multicolour VGA purposes, I really need the speed !!
westfw
#21
Jan 22, 2015, 10:31 am Last Edit: Jan 23, 2015, 03:08 am by westfw Reason: Change link to one not requiring login.
Quote
for me its not a simple jump [to ARM]
This online class has just started, and I highly recommend it.  If you already have experience programming AVRs in C and assembly, you'll be well ahead of "median" background, but it's STILL a good introduction to ARM programming...
https://www.edx.org/course/embedded-systems-shape-world-utaustinx-ut-6-02x
mcnobby
Cheers WestFw, I think I would need to sign up as I cant see much on that page/link
westfw
nickgammon
Interesting, I had found I could run at around 24 MHz (note the M) with a crystal but not faster. Now I am motivated to try faster clock inputs, excluding crystals.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
I very much doubt that ;)
Annoyingly, the proper capitalization of 1,000 is k but 1,000,000 is M.
mcnobby
Yes Nick, I got that far too, but then realised I had to switch to a TTL clock gen for higher speeds as the micro wasnt able to drive the crystal or something, I cant remember the full reason but thats in the past now
cyclegadget
@mcnobby,
I have looked for the crystal that you are using but, have not found a cheap way to buy a crystal just for playing around. However, I ordered a breakout board last night that may prove interesting!
Adafruit Si5351A Clock Generator Breakout Board - 8KHz to 160MHz
http://www.adafruit.com/product/2045
The breakout board is not practical for a finished product but, it will allow me to find out how fast an Arduino can go. :)
mcnobby
I have been using THESE. they are about £0.19p each in qty of 10, but they are surface mount which can be a problem if you just use standard mount
I did find some surplus stock standard mount ones on ebay, bought a load for testing/playing very cheap, I have had a look but cant find them anymore
DrAzzy
Neat stuff. Sounds like a good omen for trying to make the ATTiny's that are normally spec'ed only to 12mhz run at 16mhz like a normal Arduino.
ATTinyCore and megaTinyCore for all ATtiny, DxCore for DA/DB-series! github.com/SpenceKonde
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
