Topic: Code for analog-to-digital initialisation (Read 1 time) previous topic - next topic
wizzkid
Hello!
I have a few questions!
I would like to know how you write a function that initializes a A/D-converter.
And how do you use ArduinoDue pin A0 that reads the value for the buttons on the LCD-shield.
This is the code that we are supposed to use:
Code: [Select]
void ADCSetup(int DuePinNr)
/* Insert table that maps the DuePinNr to ADC_CHANNEL_XX
/* Shamelessly copied from the ASF Quick Start Guide */
adc_init(ADC, sysclk_get_main_hz(), 1000000, 8);
adc_configure_timing(ADC, 0, ADC_SETTLING_TIME_3, 1);
adc_set_resolution(ADC, ADC_MR_LOWRES_BITS_12);
adc_enable_channel(ADC, ADC_CHANNEL_XX);
adc_configure_trigger(ADC, ADC_TRIG_SW, 0);
Thanks in advance!
robtillaart
Quote
I understand the words individually but not what you are asking for?
Sounds like a school project?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
KenF
Reading between the lines I suspect you have one of those displays with 5 buttons built in on A0.  This works for me
btw, if no key is being pressed, it returns straight away it doesn't wait.
Code: [Select]
//returns 1 to 5 for button down
//returns 0 if no button down
int getButton()
static int adcValues[5] ={30, 150, 360, 535, 760};
int n, input;
input=analogRead(0);
  for (n = 0; n < 5; n++)
    if (input < adcValues[n])
      return n+1;
 return 0;
wizzkid
My question was: How do you read a value on the AD-input and write it on the LCD-display, by using pin A0 on the Due. We want to use C-programming for this.
KenF
So it's not the buttons on the LCD shield that interests you?
wizzkid
No I am interested, but first I need to initialize the A/D-converter and I dont know how to do that i C-programming
KenF
Whoever told you that, should also tell you how.
Robin2
To the best of my knowledge reading from the ADC involves
Code: [Select]
myData = analogRead(analogPin);
and nothing else
If you need to read from different pins you should discard the first reading after changing to a different pin.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
