Topic: DUE interrupt called only once (Read 509 times) previous topic - next topic
peguerosdc
Dec 04, 2014, 10:56 am Last Edit: Dec 04, 2014, 10:59 am by peguerosdc
Hi!! I am new to the Arduino world and I have been trying to run the Interrupt's example on my Arduino DUE, but I just can't get it to work because my LED is always in the HIGH state.
This is my code:
Code: [Select]
int out = 9;
volatile int state = LOW;
volatile int count = 0;
  pinMode(out, OUTPUT);
  // Init serial port
  // Attach interrupt on led change
  attachInterrupt(out, toggle, CHANGE);
  // write state to LED
  digitalWriteDirect(out, state);
  // print state and count
  delay(2000);
  Serial.println(state);
  Serial.println(count);
void toggle() {
  count++;
  state = !state;
inline void digitalWriteDirect(int pin, boolean val){
  if(val) g_APinDescription[pin].pPort -> PIO_SODR = g_APinDescription[pin].ulPin;
  else    g_APinDescription[pin].pPort -> PIO_CODR = g_APinDescription[pin].ulPin;
I added a "count" variable to see whats happening and it is always printed as 1 so it seemed obvious that my interrupt was being triggered only once, so after some Googling I found this one year old bug that suggests to change "digitalWrite" to "digitalWriteDirect" to avoid this exact behaviour, but it's still not working.
Any ideas?  :smiley-cry: I am using an Arduino DUE and 1.5.8 IDE running on OSX Mavericks.
dlloyd
The main problem is this:
Code: [Select]
delay(2000);
Check out the "blink without delay" sketch for a method of avoiding delays (uses timing intervals instead).
