Topic: Wifi modules (Read 1 time) previous topic - next topic
Yaro
Hi all,
I want to ask if all wifi b/g/n are the same. Since the protocol is the same, the quality of all wifi module is too the same? or there is better quality and faster wifi module?
Yaro
I see now that there are full of UART modules like esp8266. But i also see that they can trasfer only 11kb/s and not 54Mbit/s like standard wifi modules. Someone know and IC or a wifi module that is able to trasfer big data?
Peter_n
Nothing is the same. Some are indeed faster. Some have a signal that is 5 times better with the same power. Some have really bad firmware and the connection gets broken every few minutes. That is why I decided to use only good brands... until I learned that some of those are easy to hack.
Do you want to transfer a lot of data with an Arduino ? Which Arduino board do you want to use ?
Yaro
I know an Arduino is not able to trasfer a lot of data, I'll use another MCU for that. I can't find usefull information about wifi modules. I need a small module, low cost and low power consumption but all i can find only UART modules that are not suitable for me. A 22 Mbps or 25 Mbps is the speed i want accomplish.
Peter_n
Small, low cost, low consumption and 22Mbps... I think that is not possible. You better look for something big, expensive and with high power consumption.
A wifi module for a MCU is often with Serial (UART) interface. A fast wifi connection is with consumer electronics and a computer with all the drivers and software.
I think instead of a module, look for a system with Ethernet/wifi. Perhaps the Raspberry Pi with a wifi client device can do that. I don't know what the transfer speed of the Arduino Yun is, it might be interesting.
MarkT
#5
Dec 09, 2014, 06:01 pm Last Edit: Dec 09, 2014, 06:02 pm by MarkT
Hi all,
Do you mean are the B, G and N WiFi standards the same or whether all b+g+n compliant
devices are the same?  Output power can vary between implementations of course...
Yaro
#6
Dec 10, 2014, 10:59 am Last Edit: Dec 10, 2014, 11:28 am by Yaro
Can you explain me better what determinate speed? Becouse all modules i find say me 54Mbits but when i asked to one productor if his module can fit my purpose thay said me "it's not possible becouse throughput limitation of SPI/URAT interface".
