Topic: Mega2560 power consumption (Read 15144 times) previous topic - next topic
qwertysimo
I could not find this information. What is the consumption of Mega2560? I measure about 200 mA flowing between 12 V supply and Mega's power connector (nothing connected to pins, "blink" example uploaded). Is this expected?
Thank you.
MarkT
Look up the Atmel datasheet for the ATmega2560, they have graphs for current consumption v. clock frequency somewhere.
Also are the inputs floating?  There's a lot of pins and if they are all floating that could contribute quite a lot of current.
qwertysimo
Thanks. I checked http://www.atmel.com/dyn/resources/prod_documents/doc2549.PDF section 30. Electrical Characteristics and found this maximum rating:
DC Current VCC and GND Pins................................ 200.0 mA
Below this table follow another one with Power Supply Current but the stated values are 14 mA max.
Strange.
retrolefty
Quote
This maximum current spec combines internal consumption for the chip AND any and all current being drawn from the output pins powering external loads like LEDs, etc.
Lefty
pokinwilly
Quote
200mA sounds a lot to me too. Wondering if you are not measuring the board power consumption, including the power régulator. Especially if the onboard power is 5V and the external power source is 12V, as converter efficiency can be as low as 55%.
Suggestion: measure using a 5V external power supply, bypassing the regulator (for instance powering through USB port).
