Topic: Project 8-LED get all to HIGH  (Read 944 times) previous topic - next topic
meteoros
Hi,i'm at project 8 and when i run the arduino all the leds go to HIGH at the same time,instead of one by one.any ideias on what could be the mistake?Thanks
My code:
const int switchPin=8;
unsigned long previousTime=0;
int switchState=0;
int prevSwitchState=0;
int led=2;
long interval=150000;
void setup(){
  for(int x=2;x<8;x++){
    pinMode(x,OUTPUT);
  pinMode(switchPin, INPUT);
void loop(){
  unsigned long currentTime=millis();
  if(currentTime-previousTime>interval){
  digitalWrite(led,HIGH);
  led++;
  if(led==7){
  switchState=digitalRead(switchPin);
  if(switchState!=prevSwitchState){
      digitalWrite(x,LOW);
    led=2;
    previousTime=currentTime;
  prevSwitchState=switchState;
BadMrFresli
Hi Meteoros
The problem with your code is that you need to reset the previousTime variable after you compare it:
Code: [Select]
 previousTime = currentTime;
 led++;
Hope that helped
