Topic: Uno Cannot Connect to Network with Ethernet Shield (Read 875 times) previous topic - next topic
HonicTheSedghog
I bought an Ethernet Shield for my Arduino from Radio Shack and I haven't been able to get any of the ethernet tutorials to work and I haven't found anyone on the web with the exact same symptoms that I have.
Below is some data of what I have and what I've tried:
  • I am using the Arduno Uno R3 SMD Edition
  • I am using the W5200 Ethernet Shield v2.2
  • I am on Mac OS 10.6.8 with Arduino IDE 1.0.6
  • The chat server tutorial returns: Chat server address:0.0.0.0
  • The DHCP address printer tutorial doesn't print anything and gets stuck on the line if (Ethernet.begin(mac) == 0) {
  • I have tried the following network configurations:
    • I have tried with different MAC addresses on the WebServer tutorial
    • I have tried with different IP addresses on the WebServer tutorial
    • Plugged the Arduino into two different routers
    • Tried with DHCP both on and off on the routers
    • Plugged the Arduino directly to my computers ethernet jack
    • Put a network switch between my computer and the Arduino
    • Tried with three different ethernet cords
  • I did not have an SD card plugged in when I tried the ethernet tutorials
  • I tried plugging the Arduino into an external power supply
  • I HAVE gotten the Arduino CardInfo tutorial to work with the ethernet shield
HonicTheSedghog
I have discovered more information that may be useful.
Without inserting the SD card, I added these two lines to the setup section for the Web Server tutorial:
pinMode(4, OUTPUT);
digitalWrite(4, HIGH);
The serial output that resulted from this change is:
server is at 175.45.199.175
When I tried to ping the address the serial console gave me this very strange, interesting response:
ping 175.45.199.175
PING 175.45.199.175 (175.45.199.175): 56 data bytes
36 bytes from 192.168.2.1: Destination Net Unreachable
Vr HL TOS   Len    ID Flg    off  TTL Pro   cks              Src                    Dst
 4   5   00 5400 de92   0 0000    3f  01 638f 192.168.2.2  175.45.199.175
This response is unlike any other response I usually get from ping, which usually says something like Request timeout for icmp_seq 0
Here are some conditions for the response:
  • This only works when the router has DHCP mode turned on.
  • The DHCP IP pool range is 192.168.2.2 to 192.168.2.100
  • The IP address I gave to the arduino is 192.168.2.101.
  • When I tell the Arduino to use 175.45.199.175 as its address I do not get that response.
I'm wondering if I need to place a jumper between two pins. Help would be appreciated.
