Topic: Arduino Uno Error- Code Won't Upload (Read 4631 times) previous topic - next topic
invaderzimm
Hi, I just got an Arduino Uno. I downloaded the latest IDE for Mac OS X, plugged in my arduino, green light turns on. I then attempt to upload the blink program (after selecting port and device) but I get this error
avrdude: arduino_read_sig_bytes(): (a) protocol error, expect=0x10, resp=0x1c
avrdude: error reading signature data for part "ATMEGA328P", rc=-3
avrdude: error reading signature data, rc=-1
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0xe0
ChilliTronix
Post a picture of your board or post a link to where it was from. This allows us to double check the nature of the board.
invaderzimm
http://www.amazon.com/Arduino-Starter-Official-170-page-Projects/dp/B009UKZV0A/ref=sr_1_2?ie=UTF8&qid=1419546922&sr=8-2&keywords=arduino
the picture of the board is exactly how mine looks. occasionally, when i reset the board, it says 'device not in sync' but almost all the time it reads the error above
AJITnayak
I think you using differnt signature.
Please check IC name atmega328p-pu or atmega328 pu
Quote
0x1e 0x95 0x0F" (this is the ATmega328P signature)
0x1e 0x95 0x14" (this is the ATmega328 signature)
Just open
Quote
In your Arduino folder, find the subfolder: ..\hardware\tools\avr\etc
Open the file avrdude.conf in a text editor
search for signature top replace with new one
depend on controller change signature.
AMPS
invaderzimm
That didn't work. Does it make any difference that I'm using OS X Yosemite, may the IDE not be compatle?
AJITnayak
Quote
What does it mean??? To whos answer pointing to. Always use @ tag to present your comments
AMPS
invaderzimm
@AMPS-N , I tried replacing the code with the one you said and I still get the error:
avrdude: error reading signature data for part "ATmega328P", rc=-3
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
AJITnayak
#7
Dec 26, 2014, 07:53 am Last Edit: Dec 26, 2014, 08:00 am by AMPS-N
Above error is definitely signature error.
Can you tell me what IC name on arduino you are using.Can you share me where you changed the signature . put snap shots
signature should be changed here
AMPS
ChilliTronix
As @roxanne1982cxk says, post a picture of your actual board. It sounds like it has the wrong chip in it. Or alternatively tell us what exactly is written on the large 28 pin IC.
invaderzimm
@roxanne1982cxk
Here is a pic of the board: https://www.flickr.com/photos/124149965@N02/15925822507/
@AMPS-N
Here is a pic of where I changed the code: https://www.flickr.com/photos/124149965@N02/15924282390/in/photostream/
The IC says "ATMEGA328P-PU"
AJITnayak
Can you replace the avrdude file.
I have shared here. store your old avrdude in other locataion paste current avrdude file in config file.
path will look like this
Quote
D:\arduino-1.0.1\arduino-1.0.1\hardware\tools\avr\etc
AMPS
invaderzimm
@AMPS-N I get this error now:
avrdude: parallel port access not available in this configuration
avrdude: error at /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf:727: programmer type not specified
However, instead of turning orange, it also now says "Done Uploading" but the LED does not blink.
ChilliTronix
So it now appears to be communicating to the Arduino but you can't get the blink sketch to work?
invaderzimm
@chillitronix, yea I guess but how do I fix this. Is this a code issue of a hardware issue. Should I take the board back?
AJITnayak
#14
Dec 29, 2014, 06:05 am Last Edit: Dec 29, 2014, 06:11 am by AMPS-N
Is you board is customised or newly one from geninue arduino website.
If customized just check the value of capacitor & crystal oscillator being used .
value of c3,c2 must 22pf, oscilator 16MHz,
can you share screen shot of error & board you using for this application
I have attached 2 modified file here.
unzip the avrdude in folder
Quote
unzip boards in below folder
Quote
D:\arduino-1.0.1\arduino-1.0.1\hardware\arduino
try to upload code. If error put screen shot
AMPS
