Topic: How did I fry my transistor? (Read 7291 times) previous topic - next topic
jotapeh
I had a weird thing happen just now where I was experimenting with a transistor switch and after a little while it just stopped working entirely. Replacing the transistor fixed it, but I'm curious now what caused it.
I started with a very plain circuit like the first picture (attached to post.) I noticed that this was pretty susceptible to interference from say, touching the contact wires with my finger. Which I guess makes sense, as even a few hundred microamps ought to light up a 1ma LED, and I suppose the 22kΩ path to ground can only source so much current. I guess?
So then I thought maybe a small capacitor could help to prevent this interference, so I tried putting a 0.1uF capacitor in parellel with the 22kΩ resistor to ground, as shown in the second picture. This worked for a little while, but as stated above it suddenly stopped working and after testing each component in the chain the transistor was definitely what died.
So I guess I'm curious, what am I missing here? Did I somehow exceed the breakdown voltage momentarily, destroying the transistor? There was no smoke or sparks or heat that I could observe - just suddenly, nothing.
Help? What is wrong with the second circuit that might cause this?
Paul__B
Did you solder the components?  (Too much heat?)
We do like schematics as a minimum, and yours is excellent, but in this case a (perfectly focused, no more than 1024 pixels wide) picture is called for.
The circuit is perfect; clumsiness of some sort is suspected.
cjdelphi
Both are fine but the resistor to ground/cap's  not required...
weedpharma
Circuit looks good. What transistor are you using?
Weedpharma
jotapeh
Thanks for the feedback. Transistor I am using is a PN2222A. Datasheet here: ON Semiconductor PN2222A Datasheet
Got a whole bunch of them, because at 5¢ per I figured it would be a decent practice transistor. I guess that was a good idea, because I clearly don't understand what I did to kill the first one.  :smiley-eek:
No, this is on a breadboard. This is not my first circuit by a long shot but my first time really poking at discrete transistors rather than using ICs. Some details that might be pertinent but that I left out thinking they were not relevant:
- The supply is actually ~4.6V from a wall wart rated for 1.6A, should be overkill.
- There is a 2200µF cap across the +/- supply. Again, overkill, but there for later experiments with neopixels
- The 100nF cap is technically rated as 104Z, so I guess potentially anywhere from 80-180nF.
I will try to take a proper picture, the ones I'm taking now are blurry with my phone cam.
Not required but I found the switch leaving the base of the transistor "Floating" left it very susceptible to random noise, flickering the LED on and off just by waving my finger nearby. I also used a 1MΩ at one point, but this basically seemed to act like an antenna. I figured this was a bit like a pull-down resistor, just something to help bring it back to ground when the switch opens? Is this not a good practice?
jotapeh
OK, managed to get a decent shot. Nothing that interesting I think. Rails are ~4.6VDC as I said before.
Maybe it was just a bad transistor..? I guess you get what you pay for sometimes...
larryd
Could be you accidentally shorted a point in the cct.
I have never had a new, bad semi conductor in the 45 years.
Except some diodes that were marked with the cathode on the wrong end!
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
raschemmel
Quote
Ditto for 30 years. Invariably, it turns out to be operator error (accidentally connecting a wire to a wrong pin etc..).
The led current limiting resistor only needs to be 220 ohms.
How did you test the transistor ? (exactly)
Arduino UNOs, Pro-Minis, ATMega328, ATtiny85, LCDs, MCP4162, keypads,<br />DS18B20s,74c922,nRF24L01, RS232, SD card, RC fixed wing, quadcopter
KenF
Static discharge?  Highly unlikely but in the absence of any other explanation.
raschemmel
Quote
Static discharge?
2n2222's are not CMOS and therefore not static sensitive. In Southern California , in the summer , during Santa Anna wind conditions, the static is so extreme that you hear people yelling "ouch !" intermittedly all
day at work as they walk from one desk to another over a carpet and touch something at the other end.
It has been said that even TTL chips can be damaged under these conditions but I don't know if that is true.
KenF
It may take a strike of lightening to convince you but ALL electronic components are sensitive to Static discharge at some level.
jotapeh
#11
Dec 26, 2014, 11:29 pm Last Edit: Dec 26, 2014, 11:34 pm by jotapeh
As I stated above, at the time I was poking my finger about (gently) between the base of the transistor and the resistors/cap to see if I could cause interference which I was seeing before. In that general area, as you can see from the picture, there's really not a lot of risk of shorting, but I suppose that's the best explanation there is.
Quote
Aware of this, thanks, but I prefer my LEDs dimmer than most. I find fully lit LEDs a bit hard to look at (and I mean really, if we're being nitpicky, 220 ohms is a tiny bit short since it provides 20.9mA @ 4.6VDC and the LED is rated for 20mA.. ±5% for a carbon film resistor and... ok ok I'm done.. :) )
Quote
Two methods, the first being to replace the transistor in the circuit. The circuit started working again. That was a big hint.
Testing now with a multimeter, a working transistor shows:
BE Vf 0.664
BC Vf 0.659
The broken transistor shows:
BE Vf 1 (Can't get a reading)
BC Vf 0.654
So yeah, I guess I will have to settle for "briefly shorted it somehow" as the explanation. No idea how really, but I will just exercise more caution in the future.
Thanks everyone for your help!
ChilliTronix
I've got a few boxes of valves, and I am fairly certain it would take an actual lightning strike to fry one.
KenF
Some years ago I threw out about half a dozen tea chests full of valves believing I'd never use them again.  Literally just a few weeks later I realised I'd thrown away an absolute gold mine.  They were all in full working condition and over half of them were still in their original packing. :(
runaway_pancake
BC Vf 0.654
Open base-emitter junction.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
