Topic: speed control of two servos (Read 385 times) previous topic - next topic
Barfly9823
I am trying to control the speed of two servos operating at the same time.  Right now they operate at max speed, one counter clockwise, the other clockwise.  Code so far is a follows.
const int sensorPin = A0;
int lightLevel = 0;
#include <Servo.h>  // servo library
Servo servoFLCW, servoFLCCW;  // servo control object
    Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
    servoFLCW.attach(2);
    servoFLCCW.attach(3);
void loop(){
  lightLevel = analogRead(sensorPin);
   Serial.print("Light level Bay 1: ");
   Serial.println(lightLevel);
  if ((lightLevel) > 2);
      delay(2000);
      doorFLCW();
void doorFLCW() {
  if ((lightLevel) < 300) {
    servoFLCW.write(135);
    servoFLCCW.write(5);
  servoFLCW.write(5);
  servoFLCCW.write(135);
Any constructive help would be appreciated.
groundFungus
You will save everyone's time if you read and follow the forum guidelines.  :)
https://forum.arduino.cc/index.php/topic,148850.0.html
and
https://forum.arduino.cc/index.php?topic=97455.0
Barfly9823
Robin2
Look at how the servo is controlled in the demo several things at a time. It would be very simple to add another servo.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
Barfly9823
It does what I need it to .  It is operating the two doors for a roundhouse bay.  Took the true statement at the end out so that they operate at the same time.
AWOL
Code: [Select]
Did you fix that one?
