Topic: Simple Terminal Program Has a Problem (Read 16041 times) previous topic - next topic
goodinventor
Hello,
Attached is the program so far.
The problem is that when I type 'r' or 's', the Arduino does not respond via serial. Can you all show me how to fix it?
KenF
Your Serial.read belongs INSIDE your loop function.  Not at the top of your sketch.
Does this get you any closer to your aspirations.
Code: [Select]
// Unos_0_0_1
// programmed by George Andrews
// (c. 2014)
// input
  Serial.println("Welcome...");
  delay(3000);
  Serial.println("root@unos:~#");
  delay(3000);
  Serial.print("root@unos:");
char input = Serial.read();
  switch (input)
    case 's':
      Serial.println(" ");
      Serial.println("Shutting down...");
      delay(3000);
    case 'r':
      Serial.println("Restarting...");
      delay(3000);
goodinventor
Yes, it now does everything I want it to. Thank you, KenF. Now how do I implement strings for Serial.read() in the switch control structure? When I tried it, it generated errors.
Robin2
#3
Dec 29, 2014, 02:40 pm Last Edit: Dec 29, 2014, 02:42 pm by Robin2
You need to post your revised code so we know what you are now dealing with.
Also have a look at serial input basics   [Edit to add]  -  which uses strings (small s) [/edit]
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
goodinventor
When I replace 'r' with "reboot" and 's' with "shutdown", the compiler generates an error. When I replace 'r' with 'r' && 'e' && 'b' && 'o' && 'o' && 't', the compiler generates an error for duplicated characters. What should I do?
UKHeliBob
Quote
switch/case uses the value of a variable as the switch parameter so it cannot use strings.  You might consider using strcmp() to test strings against literal strings or string variables.
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
goodinventor
OK. Attached is the program so far.
Any commands I should add that would be useful?
AWOL
Quote
It's small enough for you to have posted it for everyone's convenience.
Robin2
Did you look at the link I posted in Reply #4 which probably covers everything you need.
...R
goodinventor
goodinventor
Now what could I add to the program?
Delta_G
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
KenF
goodinventor
OK. I added a blink LED command. Attached is the new and improved program.
