Topic: Simple Terminal Program Has a Problem (Read 16040 times) previous topic - next topic
goodinventor
Yes, I did. Thank you for reminding me.
goodinventor
Are there any more improvements I can make?
AWOL
goodinventor
Well, I didn't think that the code block could hold code that long. I thought it should be used for snippets.
AWOL
No, snippets are what we don't want to see.
goodinventor
OK. Thank you for the information. I will try out your suggestion in the future.
goodinventor
OK. I implemented millis() in the LED command. I think I'll implement millis() instead of delay() for everything. And I might add a timer function.
goodinventor
Fellow hackers, I made the changes to the program. The compiler generated errors when I tried to compile the program.
Here is the program so far.
Code: [Select]
// Unos_0_0_1
// programmed by George Andrews
// (c. 2014)
int LED_PIN = 13; // LED pin
int LED_PIN_STATE = LOW; // initial state of LED pin
long LAST_LED_UPDATE = 0; // time of last LED update
long LED_BLINK_INTERVAL = 500; // time interval for LED to blink
unsigned long TIME_NEEDED
int Time(TIME_NEEDED)
  long INTERVAL = TIME_NEEDED;
  long LAST_UPDATE = 0;
  unsigned long CURRENT_TIME = millis();
  if (CURRENT_TIME - LAST_UPDATE > INTERVAL)
    LAST_UPDATE = CURRENT_TIME;
    return 1; // signify that the time is up
  pinMode(LED_PIN, OUTPUT); // LED pin
  Serial.println("Welcome...");
  TIME_NEEDED = 3000;
  Time(TIME_NEEDED);
  if (Time(TIME_NEEDED) == 1)
    Serial.println("root@unos:~#");
  TIME_NEEDED = 3000;
  Time(TIME_NEEDED);
    Serial.print("root@unos:");
  interrupts();
  // input character
  char inputChar = Serial.read();
  char input[8];
  unsigned long time = millis();
  switch (inputChar)
    case 's':
      input[0] = inputChar;
      Serial.println(inputChar);
      Serial.println("Shutting down...");
      delay(3000);
      noInterrupts();
    case 'r':
      Serial.println("Restarting...");
      delay(3000);
      noInterrupts();
      interrupts();
      delay(3000);
      delay(3000);
    case 'p':
      delay(3000);
    case 'b':
      if (time - LAST_LED_UPDATE > LED_BLINK_INTERVAL)
        LAST_LED_UPDATE = time;
        if (LED_PIN_STATE == LOW)
          LED_PIN_STATE = HIGH;
        digitalWrite(LED_PIN, LED_PIN_STATE);
      delay(3000);
Here are the errors that the compiler generated.
Unos_0_0_1:12: error: expected initializer before 'int'
Unos_0_0_1:15: error: expected initializer before 'int'
What does this mean? And how can I fix it?
AWOL
#23
Jan 01, 2015, 01:11 am Last Edit: Jan 01, 2015, 01:12 am by AWOL
Needs more semicolon.
And type specifier.
KenF
TIME_NEEDED is a global variable.  So there's no need to pass it to your function Time.
BTW You've missed a semi-colon on line 14;
goodinventor
OK, now I have the following errors.
Unos_0_0_1:10: error: 'TIME_NEEDED' was not declared in this scope
Unos_0_0_1:15: error: redefinition of 'int Time'
Unos_0_0_1:10: error: 'int Time' previously defined here
Here is my code.
Code: [Select]
// Unos_0_0_1
// (c. 2014)
unsigned long LED_BLINK_INTERVAL = 500; // time interval for LED to blink
unsigned long TIME_NEEDED;
  TIME_NEEDED = 3000;
  Wait(TIME_NEEDED);
  TIME_NEEDED = 3000;
  Time(TIME_NEEDED);
  if (Wait(TIME_NEEDED) == 1)
  interrupts();
  // input character
  char input[8];
  switch (inputChar)
    case 's':
      delay(3000);
      noInterrupts();
    case 'r':
      delay(3000);
      noInterrupts();
      interrupts();
      delay(3000);
      delay(3000);
    case 'p':
      delay(3000);
    case 'b':
      delay(3000);
How can I solve these errors?
KenF
So why do I still find a global variable with the name TIME_NEEDED and a function still having it passed.
Code: [Select]
unsigned long TIME_NEEDED;  //<<<<  This is a global variable, it doesn't need to be passed to any function
int Time(TIME_NEEDED)  //<< This is declaring a function that is going to have TIME_NEEDED passed to it
                                 //(You've also forgotten to declare what type of variable TIME_NEEDED is here)
goodinventor
OK. Here is my improved version. I have fixed all the errors and tested it.
Code: [Select]
[/c//
// Unos_0_0_1
// (c. 2014)
int Time(unsigned long TIME_NEEDED)
  unsigned long INTERVAL = TIME_NEEDED;
  TIME_NEEDED = 3000;
  Time(TIME_NEEDED);
  TIME_NEEDED = 3000;
  Time(TIME_NEEDED);
  interrupts();
  // input character
  char input[8];
  switch (inputChar)
    case 's':
      delay(3000);
      noInterrupts();
    case 'r':
      TIME_NEEDED = 3000;
      Time(TIME_NEEDED);
        noInterrupts();
      interrupts();
      TIME_NEEDED = 3000;
      Time(TIME_NEEDED);
      TIME_NEEDED = 3000;
      Time(TIME_NEEDED);
    case 'p':
      TIME_NEEDED = 3000;
      Time(TIME_NEEDED);
    case 'b':
      TIME_NEEDED = 3000;
      Time(TIME_NEEDED);
What should I add to the terminal?
KenF
Just for the sake of getting my point across, does it still work like this?
Code: [Select]
// Unos_0_0_1
// (c. 2014)
int Time()
  TIME_NEEDED = 3000;
  Time();
  if (Time() == 1)
  TIME_NEEDED = 3000;
  Time();
  if (Time() == 1)
  interrupts();
  // input character
  char input[8];
  switch (inputChar)
    case 's':
      delay(3000);
      noInterrupts();
    case 'r':
      TIME_NEEDED = 3000;
      Time();
      if (Time() == 1)
        noInterrupts();
      interrupts();
      TIME_NEEDED = 3000;
      Time();
      if (Time() == 1)
      TIME_NEEDED = 3000;
      Time();
      if (Time() == 1)
    case 'p':
      TIME_NEEDED = 3000;
      Time();
      if (Time() == 1)
    case 'b':
      TIME_NEEDED = 3000;
      Time();
      if (Time() == 1)
goodinventor
