Topic: Unos 0.0.1 - A Simple OS for the Arduino (Read 22273 times) previous topic - next topic
rockwallaby
I stayed in 'lurk' mode where I was waiting for Unos release 0.0.3 (in a new thread of course) which would hopefully have 'ls' and 'df' command.  :P
Paul - VK7KPA
goodinventor
rockwallaby, I am sure you have been waiting for such commands. I'll probably try to cut down on memory in the next release, then after that I'll start using interrupt handlers and memory-related commands. This program is not a library. It is designed to make simple tasks possible to execute without direct programming.
AWOL
Quote
Have you looked at Firmata?
No real sense in reinventing the wheel.
goodinventor
Yes, I have. It is rather limited, though.
AWOL
SimpleDigitalFirmata sketch 4830 bytes (which allows the user to set their own pinModes correctly) vs. Unos 0.0.2  5230 bytes.
goodinventor
Firmata was designed to interface with programs on the computer. My program is not designed to do that at all. As a matter of fact, in a future release I plan to interface with a touchscreen shield instead of serial.
Robin2
I find dmesg very useful.
PLEASE don't encourage extra Threads
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
goodinventor
I improved on use of RAM. Attached is the code. The commands are the same as in Unos 0.0.2.
AWOL
Code: [Select]
char *command[NUMBER_OF_COMMANDS] = {"shutdown", "restart", "print", "pinwrite"}; // << enter your commands here<< These are # 0,1,2,3 & 4
int Pin[12] = {2,3,4,5,6,7,8,9,10,11,12,13};
Quote
Hmmm.
Quote
I'm looking forward to "lsusb".
vffgaston
Quote
As we say in spanish: "este niƱo no tiene abuela" (The boy hasn't any grandmother -he has to give applauses to himself)
rockwallaby
Robin2 wrote:
Quote
I hope my sense of dryness did not elude thee.  :-[
Paul - VK7KPA
goodinventor
The Arduino Uno doesn't have a host USB port, so there is little point in having such a command.
Robin2
Robin2 wrote: I hope my sense of dryness did not elude thee.  :-[
It did not elude me, but I was concerned that others might take you literally - e.g. ...
...R
goodinventor
Don't worry. I know better than that.
goodinventor
rockwallaby, the 'ls' command requires a storage device. What kind of storage device should I support?
