Topic: Need help interfacing Arduino with Motor Controller (Read 3220 times) previous topic - next topic
redmug
I am relatively new to Arduino. I am currently in the process of building a robot, and I am using an Arduino Uno to control my sensors and also send commands to a motor controller.
At the moment I am having issues sending commands to the motor controller.
This is the motor controller I am using :
http://www.robotshop.com/en/sabertooth-dual-12a-regenerative-motor-driver.html
The issue is, the motor controller seems to operate the wheels without the Arduino. I.e. When the Arduino is off and the motor controller is on, the wheels are still moving, and no amount of code I load onto the Arduino seems to have an effect..
At the moment the Arduino and the Motor Controller are running off seperate power sources, and when the Arduino is disconnected 2 out of the 4 motors move in a forward direction, and once the Arduino is hooked up the same still occurs.
This is the code I am using:
Code: [Select]
#include <Servo.h>
Servo myservo;
void setup () {
  myservo.attach(9); // Use PWM pin 9 to control Sabertooth.
  // 0 means full power in one direction.
  // Actually the minimum value for me is around 30.
  // A smaller value won't drive the motor.
  myservo.write(30);
  delay(2000);
  // 90 means stopping the motor.
  myservo.write(90);
  delay(2000);
  // 180 means full power in the other direction.
  // Actually the maximum value for me is around 160.
  // A larger value won't drive the motor either.
  myservo.write(160);
  delay(2000);
I need to know why I am unable to control this motor controller, and why it is not responding to the code I load onto the Arduino.
Thanks
jremington
Please post a circuit diagram. Have you connected the grounds together?
redmug
I really don't know how to make a digital  circuit diagram, so I'll just explain.
There are 2 red, 2 orange and 2 brown wires on the motor controller.
I have the 2 orange wires connected to PWM pins 5 and 6
I have 1 brown wire connected to Ground
And None of the red wires are connected.
I was told to wire it this way by this website:
http://www.robotshop.com/forum/arduino-mega-adk-and-sabertooth-12a-r-c-t11651
Thanks
Cactusface
#3
Jan 09, 2015, 04:15 pm Last Edit: Jan 09, 2015, 04:26 pm by Cactusface Reason: connect it to the
Hi redmug,
                 Do you really need 12A? (if not you wasted a lot of money!!) they must be some motors. That link tells us nothing about the driver PCB and does'nt show us the full board contacts, etc. The two leads have 3 wires coded for servos?? (Red=5v, Brown=Gnd and Orange=control signal). Are you using DC motors or servos??
What are the lables printed near the 6 screw terminal block, are they the motor outputs and power in?
You code is for servos, not DC motors!!!
As JR says we need to see your schematic and perhaps a picture of your setup. Until then we can't help much, help us to help you.
From the second link:
Quote
As for the connection, you have to use PWM capable pins on your Arduino Mega for the signal (Orange Wire).
You need to hook one of the GND wire between the motor controller and the Arduino (Brown Wire) on the "GND" pins.
The Red wire is leave alone as it is use to power the receiver with the internal BEC of the Motor Controller.
Don't connect it to the Arduino. NO CONNECT IT TO THE MOTOR SUPPLY POS! SURELY?
Is this a RC project? if not again you purchased the wrong thing??
Are your Gnd's tied together??
Regards
Mel.
Open your mind! But not too far, your brains might fall out.
Also like Photography, model building and my 300+ Cacti and Succs.
redmug
Firstly, let me clarify, I didn't buy these parts, I am taking part in a special project and was only given these parts to work with unfortunately...
This isn't an R/C project, and I was told to program these like they were servos not DC motors. Also, I think I may have found the reason as to why the motor controller is not responding to my Arduino, however I am not exactly sure how to go about fixing it.
Basically this is an R/C motor controller and I am aiming to build an autonomous robot. If its an R/C controller, I think to control the motors I need to make my Arduino produce a pulse between 1 - 2 ms.
If someone could show me how to get the Arduino to produce these pulses that would be much appreciated.
Thanks
zoomkat
Quote
In the link for the motor controller provided, the motor controller appears to be made for being controlled using servo position commands. Below is some servo test code that could be used to check the calibration of the motor controller foward/stop/reverse command values.
Code: [Select]
// zoomkat 3-28-14 serial servo incremental test code
// using serial monitor type a character (s to increase or a
// to decrease) and enter to change servo position
// (two hands required, one for letter entry and one for enter key)
// use strings like 90x or 1500x for new servo position
// for IDE 1.0.5 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
#include<Servo.h>
String readString;
Servo myservo;
int pos=1500; //~neutral value for continous rotation servo
//int pos=90;
  myservo.attach(7, 400, 2600); //servo control pin, and range if desired
  Serial.println("serial servo incremental test code");
  Serial.println("type a character (s to increase or a to decrease)");
  Serial.println("and enter to change servo position");
  Serial.println("use strings like 90x or 1500x for new servo position");
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the string readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    if(readString.indexOf('x') >0) {
      pos = readString.toInt();
    if(readString =="a"){
      (pos=pos-1); //use larger numbers for larger increments
      if(pos<0) (pos=0); //prevent negative number
    if (readString =="s"){
      (pos=pos+1);
    if(pos >= 400) //determine servo write method
      Serial.println(pos);
      myservo.writeMicroseconds(pos);
      myservo.write(pos);
  readString=""; //empty for next input
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
redmug
Sorry for the late response.
Quote
Yes my grounds are tied together.
Also, In relation to the code you provided zoomkat, it still doesnt seem to have any effect on the operation of the motors, even after changing the servo position, the 2 left wheels still move at the same speed, and nothing happens with the right wheels.
This is the  closest forum post I have found on what I think I need to do to solve this issue: http://forum.arduino.cc/index.php?topic=27846.0
I need to make my arduino produce the pulses, as I am trying to control this R/C motor controller without a remote.
Also,
just thought I may add, there are switches on the motor controller itself, and these change some of the settings. Currently my configuration is:
1: Down    2: Up    3: Down   4: Down    5: Up    6: Down
Also, the 4 terminals that cannot be clearly seen on the board are:
0V, 5V, S1 and S2
Finally,
Upon turning on this controller, its now stopped displaying any status leds, even the one indicating that power is running to the controller..
Thanks
zoomkat
You might consider contacting Robot Shop or Dimension Engineering about your issue and they might help ensure your controller is setup correctly.
https://www.dimensionengineering.com/
JimboZA
Quote
Lines like this do exactly that....
Code: [Select]
  myservo.write(90);
..... except that example sends degrees not ms, and 90 degrees is 1.5ms (the mid-point).
So you can send degrees of 0 for 1ms, 90 for 1.5ms and 180 for 2ms. Or, if you need to be more specific, use the writeMicroseconds():
Code: [Select]
myservo.writeMicroseconds(1000);
//or
myservo.writeMicroseconds(1500);
//or
myservo.writeMicroseconds(2000);
// or any value between 1000 and 2000
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
redmug
I did end up contacting Dimension Engineering, and turns out that either the processor or the internal BEC on my motor controller may be damaged, as no Status Lights turn on when 12v are supplied to the controller, and this is probably why I am struggling to control these motors with an Arduino.
Thanks
JimboZA
I've never used a bec but read about them here: they need a very careful arming sequence don't they? Is that what you're doing?
zoomkat
Quote
That is strange sounding as the sabertooth is for brushed motors and a BEC is normally for brushless motors (there are brushed motor BECs).
